jwt intake install gone wrong...
Old Jul 17, 2006 | 10:14 AM
MyIS300's Avatar
MyIS300
Unhappy jwt intake install gone wrong...
dumb @$$ me....
I tried using the oem stock 4 bolt/screw to connect to the jwt popcharger intake.. and it seems that the 4 screws were a lil too long... and I forced one of the screws to try and push it in 1/4 of an inch and one of the screw broke clean and flush...
I can't remove the screw thats broken in the jwt popcharger...
I bought a silicon sealing adheasive/gasket maker stuff and put a nice seal between the stock plastic pipe (with the sensor attached) and the jwt popcharger.
In addition, i got some some washers that fit with the other screws and tighten the other 3 screws down, this in turn corrected the spacing of the longer screws........
The main purpose of this fix is to correct the missing screw and making sure no dirty air comes in.. I'm only using 3 screws with washers plus a silicon gel that seals the two parts...
It looks pretty good, but I was wondering what everyone here thinks...
Note: I know that I'm an idiot... please don't flame
Old Jul 17, 2006 | 10:16 AM
rythex's Avatar
rythex
I wouldn't put silicone on it, what if it gets sucked into your engine?
Old Jul 17, 2006 | 10:24 AM
MyIS300's Avatar
MyIS300
no.. the silicone dries and becomes like gasket and handles up to temperatures 500 F
http://www.accessconnect.com/gasket_maker_.htm
None will get into the engine
MyIS300's Avatar
MyIS300
note this is the same stuff used for installing the spacer to get a good seal
Old Jul 17, 2006 | 10:27 AM
Gary King's Avatar
Gary King
If you broke a screw it really needs to come out and be replaced. Go to Sears and get an EZ Out/Broken Bolt Extractor to remove you broken screw.
Gary
Alberto's Avatar
Alberto
Cranky FI Owner
Why not just drill out the broken screw and use the correct screws? Not flaming but why wouldnt you use the correct screws in the first place? I wouldnt rig anything on my car especially something like an intake....
Old Jul 17, 2006 | 10:28 AM
Malic350's Avatar
Malic350
LOL I thought I was the only one man. I screwed my JWT Pop-charger by doing the same darn thing lol. I put my factory box back on back on as I kept hearing a whistle so it seemed whenever I gave it some go(only 3 screws in though). I had to order some screws for it from nissan. If you go back to the stock air filter/box and need a bolt let me know I got em. I looked everywhere but couldn't find em till I called Nissan.
Me and a friend used a drill and everything else you can think of trying to get that broken screw out but to no avail it sits in my trunk.
Old Jul 17, 2006 | 10:31 AM
Malic350's Avatar
Malic350
They don't give u screws with the pop-charger u are to use the factory ones you have but they run a tad-bit long. (correct me if I am wrong)
apexi97tsi's Avatar
apexi97tsi
HAHah! I did the same thing. I used washers on the other three and filed down the broken one so far so good for about a year already. The three screws still provide a good seal for me for now.
Old Jul 17, 2006 | 10:36 AM
MyIS300's Avatar
MyIS300
wow.. i'm not the only dumb @$$, hope it runs good..
Old Jul 17, 2006 | 10:40 AM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
If you have a dremmel, you can cut a slit into the broken off bolt and use a flat head and unscrew it
Old Jul 17, 2006 | 10:45 AM
Malic350's Avatar
Malic350
LOL Nope !
Old Jul 17, 2006 | 10:57 AM
plumpzz's Avatar
plumpzz
very freakin smart!!! lol. BTW im going to the stealership near my work to go pick up those bolts. 26 dollars for nuts and bolts -.-
MyIS300's Avatar
MyIS300
smart.. I will try this...
Old Jul 17, 2006 | 10:59 AM
Jason@Performance
Performance Nissan
for the plenum?
Old Jul 17, 2006 | 12:11 PM
MyIS300's Avatar
MyIS300
Homedepot has similar bolts for like 5 cent a peice... with no screw slots...
Old Jul 17, 2006 | 03:21 PM
Mazinger Z's Avatar
Mazinger Z
This thread is similar to the one where the guy uses a hammer on the screws for his intake...eerily similar...
Old Jul 17, 2006 | 04:43 PM
Jason@Performance
Performance Nissan
The bolts we were talking about for $26 are the ones that are required for the upper and lower plenum...
