Larger MAF housing, Intake pipe and TB installed
Old Sep 8, 2012 | 06:50 PM
  #101
npr350z's Avatar
npr350z
you can pick up maf houseings pretty cheap. 70 and up if i remember correctly. i know alot of gm's and fords use hitachi style maf housings. i know the ls series have them i cant remember the exact sizes on all of them but i know they use hitachi style. like the c5 comes in 85 and reduces to 80
http://www.shopreckartperformancetun...ing_p_387.html
a 5 sec search and rough example.
i would like to see a 90mm hitachi dbw tb, a 90 mm maf and the 3.5inch tubing all used. if thered be a large amount of tq loss. what did you use to tune for the difference aceman. i read the thread but i dont recall. utec nvm.
Old Sep 8, 2012 | 07:54 PM
  #102
350z006's Avatar
350z006
I got the 3.5" treadstone for my modified Vortech setup, so that my Uprev MAF GT could handle ~600whp (with the stock 2.75" MAF tube the MAF GT could only handle ~500whp max)
Originally Posted by slow03z
Anyone out there have a treadstone maf housing? I've been wanting one of these for a long time but have never gotten around to it.
http://www.treadstoneperformance.com...+Hitachi+Style
Old Sep 8, 2012 | 08:03 PM
  #103
npr350z's Avatar
npr350z
whatd you have to do with osiris to make it run right ?
Old Sep 8, 2012 | 08:10 PM
  #104
350z006's Avatar
350z006
Just a good tune, that's all...
Old Sep 13, 2012 | 01:18 PM
  #105
PhoenixBazoli's Avatar
PhoenixBazoli
bump, is that large intake tube necessary for the set up?
Old Sep 14, 2012 | 08:09 AM
  #106
350z006's Avatar
350z006
What setup? Vortech?
Old Oct 9, 2012 | 12:19 PM
  #107
marsboy999's Avatar
marsboy999
Would it be possible to use the factory MAF sensor on the treadstone MAF housing? Since the factory MAf doesn't need to be upgraded on a NA car, just the diameter of the pipe. Anybody know if this would work?
Old Oct 9, 2012 | 01:46 PM
  #108
350z006's Avatar
350z006
Yes, it has been done many times...just make sure you get the right housing that will work with the Nissan MAF...
Old Oct 10, 2012 | 08:31 AM
  #109
marsboy999's Avatar
marsboy999
But if I understand this correctly, the car won't run, or run right until it has been retuned for the larger housing. Is this something that can be done with an email tune, say using an Uprev, or does the car need to be dyno tuned?
Old Oct 10, 2012 | 09:42 AM
  #110
350z006's Avatar
350z006
That is correct, you will need a new tune with a different sized MAF housing...I'd like to say that you will need a dyno tune no matter what when you make these changes, but you should to contact Uprev to see if they have a canned/email tune for different sized MAF tubes; I doubt they have it, but its worth a try...
Old Jan 19, 2013 | 02:39 PM
  #111
CLyons0203's Avatar
CLyons0203
Dynos?
Old Jan 19, 2013 | 06:38 PM
  #112
mw9's Avatar
mw9
high or low treadstone?
Old Jan 19, 2013 | 10:02 PM
  #113
350z006's Avatar
350z006
3.5" Low was good enough for +600whp w/ Uprev Maf GT...
Or I suppose you can also get a 3" tall...
Old Jan 19, 2013 | 10:06 PM
  #114
350z006's Avatar
350z006
Originally Posted by CLyons0203
Dynos?
Old Sep 7, 2013 | 08:32 AM
  #115
DirtyMech.'s Avatar
DirtyMech.
All you need is to have the MAF scaled. There is a lot of people/tuners that have the formulas already for larger MAF housings.
Sleeper_Z
Sep 30, 2015 10:25 AM
codek
Sep 28, 2015 03:03 AM
