Just installed Strup TP's
Old Nov 22, 2006 | 06:12 PM
Joey47's Avatar
Joey47
Default Just installed Strup TP's
Just had one question. After installing my TP's I reset the ECU start the car and let it sit for 10 minutes so it gets used to the TPs. So I drive it around the block, at my first run at WOT its fine, my second time around the block, I go WOT then it stalls. Is there a reason why it stalled if so then what is it? Thanks.
Old Nov 23, 2006 | 12:35 AM
undrgnd's Avatar
undrgnd
Had it happen to my Z and several other cars, immediately after resetting the ECU when going WOT. I assumed it had something to do with the ECU learning process, because it didn't do it any time after that. Sorry I can't tell you why, but you're not alone, and these cars were in perfect working condition, some modded and some not.
Old Nov 23, 2006 | 12:39 AM
Joey47's Avatar
Joey47
i think im going to reset the ecu again and let it sit for a lil bit. then take it out driving. no WOT just daily driving.
Old Nov 23, 2006 | 02:10 AM
Azn_Empurio's Avatar
Azn_Empurio
installed mine recently
no problems at all
i didnt reset the ecu
Old Nov 23, 2006 | 09:01 AM
Question
Did you install non-foulers?
Old Nov 23, 2006 | 10:44 PM
nasty50's Avatar
nasty50
sorry for the stupid question but whats a non foulers?
also iam about to buy a set of test pipe and just wondering if this will set off your check engine light?and if so is there a way around this?
thanks in advance.
Old Feb 7, 2007 | 04:46 AM
ZLadie2000's Avatar
ZLadie2000
^^+1
Old Feb 8, 2007 | 07:13 AM
clipso 01's Avatar
clipso 01
bump
Old Feb 8, 2007 | 08:38 AM
dougrace zs's Avatar
dougrace zs
If you have a produstion date of 06/04 or earlier the car will most likly not through a cel with test pipes, later production cars will through a light unless you run high flow cats or extend the o/2 sensors out of the main exhaust stream ie non fowlers
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
