Nismo Exhaust Install ?
Old Feb 17, 2007 | 03:45 PM
zand02max's Avatar
zand02max
Default Nismo Exhaust Install ?
Tried the search, nothing.
Curious as to the install, does it take 2 people to do, as in lifting the muffler and installing. I will have access to a lift. Just wondering as I will end up telling my wife she has to assist at the lift,
Old Feb 17, 2007 | 03:47 PM
philude's Avatar
philude
i did it by myself with little trouble. it's a PITA getting the rubber mounts off at times, but it's basically a piece of cake.
Old Feb 17, 2007 | 03:51 PM
zand02max's Avatar
zand02max
Yeah, I heard to use a lot of WD-40 on the mounts and they will come off.
Old Feb 17, 2007 | 04:00 PM
BhashaZ's Avatar
BhashaZ
With one person, it's definitely doable, especially if you have access to a lift. Having another body just makes it easier.
Old Feb 17, 2007 | 04:19 PM
zand02max's Avatar
zand02max
Looks like the wife is my helper. She won't mind, she helped me paint my calipers on my 03 Z,
Old Feb 17, 2007 | 08:19 PM
philude's Avatar
philude
bad idea to use WD40, i heard it dries and cracks the rubber eventually if you use too much. i forget but i think it's better to use white grease or something from pep boys or something. pretty sure KY works too
Old Feb 18, 2007 | 02:35 AM
sheck4's Avatar
sheck4
Default Removal
Hey zand02max
Did mine.
Hope this helps, I coudnt get the stock canister off either, but this was fairly quick to do
The best way is to remove the 2 metal hangers mounted from the underside of your car 'with' the rubber mounts. You will need a long extension for your ratchet, but removing the 3 bolts from each side will easily drop your rear muffler.
Take off the 3 rubber hangers and put them on the new exhaust.
Once you have the Y-pipe on and the straight pipe mounted to the mid-rubber hanger, get someone to hold the rear canister in place as you re-mount the 6 bolts in place, and the hard part is done.
Old Feb 18, 2007 | 02:39 AM
zand02max's Avatar
zand02max
Originally Posted by sheck4
Hey zand02max
Did mine.
Thanks man.
Old Feb 19, 2007 | 08:19 AM
Z04's Avatar
Z04
i installed a catback on a different car once. it took about 1.5 hours and did not need a second person. it really helps to have the right tools to cut down on time.
Old Feb 21, 2007 | 04:47 AM
halfass872's Avatar
halfass872
Paid dealer $100.00, waited 30mins, retained 3yr 36,000mi warranty on product.
Justin100
Nov 29, 2015 03:58 PM
nanotech
Oct 2, 2015 05:02 AM
Li1ag
Sep 28, 2015 02:07 PM
