Question about HKS exhaust
Old Mar 21, 2007 | 05:18 PM
koolzero's Avatar
koolzero
Default Question about HKS exhaust
Just got done installing my HKS exhaust. The directions that came with it are terrible. Nothing like my Nismo where it has nice detailed drawings bleh...
After I finished the install I ended up with some extra washers nuts and one bolt... I'm a little confused at what I missed. Everything that was supposed to be bolted is...
Here are some pictures:
Opening the box ooooooh
laying everything out
extra pieces?
The bolt that is left is shorter than the other bolts. One spring washer and many regular washers etc.... Please let me know where these go!
Too dark to get any really nice pictures
Old Mar 21, 2007 | 05:25 PM
TimeAttkZ's Avatar
TimeAttkZ
I got the HKS .. looks about right to me. I know theres a couple alan screws in the titanium tips for adjustment but those look like there in the pictures. Hmmmm
Old Mar 22, 2007 | 03:43 AM
koolzero's Avatar
koolzero
Yeah I got the bolts on the tips, i'm assuming the thumb screw goes on the outside of the ti cover? and on the inside I did flat washer first then spring washer then nut.
Old Mar 22, 2007 | 03:49 AM
2TH PWR's Avatar
2TH PWR
I'm subscribing to see what happens. I'm installing mine in a couple weekends as soon as it's warm enough
Old Mar 22, 2007 | 03:31 PM
turbotoy's Avatar
turbotoy
Default Take a look inside your pipes!
https://my350z.com/forum/intake-exhaust/253302-hks-hi-power-very-bad-quality.html
Old Mar 24, 2007 | 10:35 PM
brigz's Avatar
brigz
I believe the shorter bolt attatches to the left muffler that has a square-ish fold to it. From there connects a type of grounding wire (not too sure what its for). Are you using 2 washers per bolt?
Old Mar 26, 2007 | 10:21 AM
koolzero's Avatar
koolzero
Originally Posted by turbotoy
Yeah I saw that thread, mine looked perfect! That had to be bad run or knock-off...
Old Mar 26, 2007 | 10:22 AM
koolzero's Avatar
koolzero
Oh nope I didn't user 2 washers per bolt... I bolted up the grounding wire in the back to a little bolt and nut that was going to my nismo exhaust... Do I have to unbolt everything and use 2 washers or will I be alright with just one washer/spring washer and nut??
Old Mar 26, 2007 | 03:00 PM
labelworkshop75's Avatar
labelworkshop75
most exotic exhaust out there
Attached Thumbnails Question about HKS exhaust-dsc01774.jpg   Question about HKS exhaust-dsc01797.jpg   Question about HKS exhaust-dsc01831.jpg
Old Mar 27, 2007 | 10:36 AM
brigz's Avatar
brigz
Im guessing you should be fine. I dont see how it could be such a big deal.
Old Mar 28, 2007 | 01:38 AM
CaliTouring's Avatar
CaliTouring
i have to disagree. i have to say that the SES is better looking
Old Mar 29, 2007 | 07:03 AM
2TH PWR's Avatar
2TH PWR
SO does anyone know where some really good instructions can be found? I'm gonna tackle this soon.
Old Mar 29, 2007 | 12:44 PM
cubu's Avatar
cubu
don't need instructions for an exhaust... lube all the bolts then take off the old exhaust, take the rubber hangers off the car not take the exhaust off the hangers, a long wrench would be a good idea for taking the stock y pipe off, put the new exhaust on but don't tighten the bolts all the way down till you piece it all together, get the tips lined up then tighten everything down, then lastly install the TI tips and adjust length to your liking... and remember to attach the grounding strip
Old Mar 30, 2007 | 05:43 AM
DRIFT ZZ's Avatar
DRIFT ZZ
I just installed mine yesterday, piece of cake...no need for instructions...! NOTE, the exhaust is louder on the HR motor than the DE !!
Hughie..PSL, FL
Old Mar 30, 2007 | 05:55 AM
koolzero's Avatar
koolzero
I still think for the price they could have provided some more detailed instructions. But maybe I'm just spoiled from the nice instructions Nismo provided...
Old Mar 30, 2007 | 07:26 AM
BaTMan_4's Avatar
BaTMan_4
Exotic HKS...please . Exotic=Amuse or Fujitsubo full Ti (not just the tips)
Old May 1, 2007 | 06:16 AM
koolzero's Avatar
koolzero
My friend just pointed out that the passenger side exhaust is just barely touching the evac shield. I haven't noticed any rattles and I don't think it's dented the exhaust but it may be scratching it just slightly. Should I modify it or do you think it will be okay?
It said that the 2006's need to be modified but mine is a 2003...
Mattg350z
Oct 2, 2015 06:51 AM
nanotech
Oct 2, 2015 05:02 AM
Li1ag
Sep 28, 2015 02:07 PM
