MD Plenum Spacer Install Help
Old Mar 25, 2007 | 05:41 PM
jumpin800agl's Avatar
jumpin800agl
8 to 11
Default MD Plenum Spacer Install Help
Attempted to install my new 5/16th MD Isothermal spacer. While reassembling I followed the instructions to put the correct sized bolts in the correct numbered lower plenum slots. The long bolts fit but the medium bolts fall in without hitting any threads. I did not leave the stock gasket in btw. Any help is greatly appreciated. I am not sure what I did wrong. Thanks in advance.
Old Mar 25, 2007 | 06:05 PM
first350's Avatar
first350
are you using the supplied bolts from MD? There's about 11 shorter bolts that go around the outside...are those the ones that aren't fitting correctly? if you have pics, it's make it a bit easier to help.
Old Mar 25, 2007 | 06:16 PM
jumpin800agl
8 to 11
The 70 mm bolts on the lower plenum fit, but the medium length bolts do not fit right. I am talking about bolts on lower plenum, not the shorter ones on outer edge of plenum. Wish i had pics, but broke my camera recently. lucky me.
Old Mar 25, 2007 | 06:17 PM
Then something is wrong. The bolts supplied by Motordyne should work. Measure the bolts. Are they the length stated on the packing slip?
Old Mar 25, 2007 | 06:21 PM
jumpin800agl
8 to 11
I was going by the numbering system supplied in the instructions. I did not measure the bolts. just put them in the corresponding mubered slots. Will have to measure tomorrow then.
Old Mar 25, 2007 | 08:28 PM
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
You reuse the stock bolts on the lower plenum.
The bolts in the MD kit are for the upper plenum.
Tony
Old Mar 26, 2007 | 05:46 AM
jumpin800agl
8 to 11
Tony
Thanks for the help Tony. I will try this today afterwork.
Old Mar 26, 2007 | 06:06 AM
first350's Avatar
first350
Tony
nice catch...something wasn't adding up. The ISO thermal gasket doesn't add much thickness, if any, so the lower plenum OE bolts are re-used.
Old Mar 26, 2007 | 07:35 AM
Mazinger Z's Avatar
Mazinger Z
Tony
Yep - since there is no space difference, use the stock bolts. The supplied bolts go in the middle/outer parts of the upper plenum. Good luck and bolt the nuts to MD's supplied spec.
Old Mar 26, 2007 | 08:14 AM
blknjz's Avatar
blknjz
does any one know ther specs on the stock upper plenum bolts. the longer bolts on the outside. i was installing an mrev2 and crawford plenum and lost the last bolt
Old Mar 26, 2007 | 08:28 AM
jumpin800agl
8 to 11
I believe my kit came with 70 mm bolts.
Old Mar 26, 2007 | 08:50 PM
jumpin800agl
8 to 11
ok i finished the install with no real issues other than the strut bar being a pain in the **** to get back on right. Everything is idling fine. Go for a quick test drive and hear no issues, get on it one time 3rd to 4th gear and then I start hearing a loud knocking noise so I immediately pull over and shut it off. I am scared I have messed something up but I have no idea what it could be. This sucks. I rechecked everything before leaving. . . I am racking my brain to figure out what happened.
Old Mar 27, 2007 | 05:55 AM
Hydrazine's Avatar
Hydrazine
Give me a call. Trouble shooting will progress alot faster over the phone.
We'll figure out what it is.
Old May 4, 2007 | 08:31 PM
Track's Avatar
Track
Was this ever resolved?
So far, I plan on ordering this on Monday (as soon as I can find out if it is worthwhile to get the MREV2 along with it while everything is taken apart (I have an '03).
Old May 4, 2007 | 08:41 PM
Track's Avatar
Track
Okay nevermind.
Further searching (yes, I've been on this for a couple of days) has revealed, once again, that Wired 24/7 has already done this and posted an EXCELLENT review of his results.
Thanks once again, Wired.
Old May 5, 2007 | 05:15 AM
jumpin800agl
8 to 11
yeah it was my fault. something had fell down in the motor during the install when i wasn't looking. Found metal shavings there, cleaned it out and runs fine now. Happy with the mod. Thanks to Tony again for taking time to trouble shoot over the phone, great guy.
Old May 5, 2007 | 09:38 AM
Track's Avatar
Track
Wow! Thanks for the quick reply, Jumpin! I'm glad to hear that's all it was.
I've been reading about these spacers and lower collectors for hundreds of hours now and, if there is one thing I've learned, it is that Tony does rock and his attitude and approach inspires confidence on both the product and the company that sells them. This is a mod I will definitely be doing... starting tomorrow with my order.
Old May 5, 2007 | 04:06 PM
Hydrazine's Avatar
Hydrazine
Thank you Track!
My business philosophy is to treat people like I want to be treated. Helping people out is easy 99% of the time anyways.
The results of our choices and actions always come around full circle.
Old May 5, 2007 | 06:40 PM
Mazinger Z's Avatar
Mazinger Z
Thank you Track!
Great biz philosophy, great company, Tony's a kick-*** guy~! hahah
Old May 5, 2007 | 11:20 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Originally Posted by Track
Okay nevermind.
Wow someone used the search function and it worked!!
