Better Heat Sheild for the Pop Charger
Old May 10, 2007 | 02:44 PM
jondimellow's Avatar
jondimellow
Default Better Heat Sheild for the Pop Charger
Summer is just about here in Cali.... has someone written up a DIY or know somewhere to buy a "cost effective" heat shield for the pop charger?
Old May 10, 2007 | 03:14 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
stillen intake or 06+ intake box, your choice.
Old May 10, 2007 | 03:26 PM
jondimellow
Let me rephrase, I want to keep the Popcharger, and I don't want to spend $200+ bucks for a stillen intake when my popcharger was half that.
Old May 10, 2007 | 03:28 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Someone has made their own, but the details of the project elude me. Let me see if I can find the thread. Other than DIY, your only options are what I listed above.
Found thread, see posts by Zquicksilver
https://my350z.com/forum/intake-exhaust/219263-ok-i-m-going-to-do-it-that-s-right-i-m-buying-a-popcharger-and-i-m-not-even-a-newb.html
Old May 10, 2007 | 04:37 PM
jondimellow
yea, I remember some guy used a rubbermaid like container. it sounds kinda ghetto, but it actually looked really good. If I remember correctly, there weren't any instructions..... =(
Old May 10, 2007 | 07:11 PM
LG_z33's Avatar
LG_z33
+1 on the 06 box, or an entire 06 set-up with k&n.
Old May 10, 2007 | 10:22 PM
FairladyZX's Avatar
FairladyZX
i don't think it's necessary, but that's jus me
Old May 11, 2007 | 09:59 AM
Zquicksilver's Avatar
Zquicksilver
I wish I could help you Jondi, but the boxes I've created are more complex than people realize. Even if I supplied a template, it would be a PITA to replicate. I used a heat gun, pop-rivets and a lot of trial and error to get my boxes to friction fit in areas of the cavity. This new box I created for my FUJITA-5 setup is virtually air tight, I'm pretty happy with it!
I wouldn't go with the Stillen setup, there is a large hole in the bottom of the heat reflector. The radiator fans blow hot air right into it, lol!
GL,
Zquicksilver
Old May 11, 2007 | 10:11 AM
Mazinger Z's Avatar
Mazinger Z
Driving in So Cal:
During the day engine goes: woooootttt
At night the engine goes: WOOOOOOOT!!!
Old May 11, 2007 | 10:17 AM
Chebosto's Avatar
Chebosto
does the fujita have a similar velocity stack that the pop charger has?
anyone done the research in viable plastics that are resistant/have high heat resistance.. i would think something with a ceramic coating (think your a/c vents) would have a good thermal protection..
i think people are probably suffering more from heat soak than actual warm air being sucked in? if thats the case.. vents in your hood ftw
Old May 11, 2007 | 10:34 AM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
I did measurements with cipher during a 1/4 mile run.
Basically, the engine bay started out heat soaked. It did not cool down to ambient until halfway through 3rd gear.
So for the first 2 gears, I was probably down about 15-20hp ...
Zquicksilver - that intake looks really nice. I'm also interested in what kind of velocity stack that thing has.
Old May 11, 2007 | 11:09 AM
Reyes5937's Avatar
Reyes5937
Zquicksilver thanks for posting the picture looking really nice. But can you tell us how did it feel before and after the airbox?
Old May 11, 2007 | 11:18 AM
Zquicksilver
"does the fujita have a similar velocity stack that the pop charger has?
i think people are probably suffering more from heat soak than actual warm air being sucked in? if thats the case.. vents in your hood ftw"
^^ No, I wish it did. But what it does do is eliminate the rubber-accordion and MAF housing, smoothing the airflow into the TB.
HDPE (high density polythylene) is failry stiff and cabable of tolerating high temps. Its a plastic used for garbage cans, detergent bottles, toys and wire insulation to name a few.
The problem... the hood when shut creates a seal. If you have any gapping around a heat shield or holes, its going to draw in that hot air. This is why the OEM box is so effective, it seals out the engine bay heat and only allows air in from inlet within the frame. All my box does is replicate this OEM setup, and it give me the room necessary for a conical filter.
Zquicksilver
Old May 11, 2007 | 12:36 PM
Rev-em-hard's Avatar
Rev-em-hard
hey wired,
did you ever mount the P.O.P velocity ring in the stock airbox and test it?
very interested.
Old May 11, 2007 | 12:58 PM
gothchick's Avatar
gothchick
Hmmm, so it's looking like a popcharger would be happiest with a varis duct and vented hood....
Attached Thumbnails Better Heat Sheild for the Pop Charger-varis_duct_005-1-.jpg   Better Heat Sheild for the Pop Charger-varis_duct_006-1-.jpg
Old May 11, 2007 | 01:20 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Well, that may be true, but I know for a fact that when the radiator fans are blowing, the intake temperature shoots WAYYYYYY up with the popcharger.
If you can keep those fans off, then those items would help.
I wouldn't expect a huge noticable difference though, unless you constantly run at the drag strip.
Old May 11, 2007 | 01:29 PM
Track's Avatar
Track
What????
I've never seen this (never seen one in-person). Can the hole be "plugged?" WTF would Stillen put a hole in their heat shield? They all have this?
Old May 11, 2007 | 01:30 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Originally Posted by Rev-em-hard
hey wired,
very interested.
No, in fact I've never gotten my hands on an 06 intake yet hehe but when I do, I will swap it out and maybe try something.
I am thinking a simple fiberglass kit would do the trick.
Old May 11, 2007 | 01:33 PM
Rev-em-hard
I may try this as well.anybody selling a pop charger for dirt cheap? lol
Old May 11, 2007 | 01:42 PM
AroundMyHorn's Avatar
AroundMyHorn
hmmm, so im going to lose power with the popcharger in the summer?
