List some outcomes of improper install of 5/16 Spacer...
Old Oct 10, 2007 | 09:25 PM
SniperHunter's Avatar
SniperHunter
Default List some outcomes of improper install of 5/16 Spacer...
Hey guys, I'll be picking up an MD 5/16 Iso Thermal Spacer in a few days, hopefully. So before I have it installed, in case something goes wrong with the install, what are the symptoms I should look out for?
I hear a noticeable loss of power (almost as if the car is engine braking?) is likely an air leak. Is that about all that can go wrong or is there anything else?
Clearly, a sudden rise in power means the installation went A-ok. Thanks, fellas.
Old Oct 10, 2007 | 11:21 PM
gsazabi's Avatar
gsazabi
I think you've answered your own question.
Old Oct 10, 2007 | 11:28 PM
SuperBlack350z's Avatar
SuperBlack350z
You can strip bolts VERY VERY VERY easy. IF you have an air leak, your car keeps shutting off when you try to start it. you will hear a slight whistle near the intake manifold as well.
Old Oct 11, 2007 | 12:23 AM
chadalac350z's Avatar
chadalac350z
Another question I would love to know about this is can you use a kinetix upper plenum the black one, with a 5/16 spacer or is this to much?
Old Oct 11, 2007 | 12:29 AM
SuperBlack350z
It's too much. I would think it hit the hood after that.
Old Oct 11, 2007 | 12:59 AM
chadalac350z
lol really no one has tried this?
Old Oct 11, 2007 | 01:03 AM
NissanZfan's Avatar
NissanZfan
If you installed the spacer/plenum wrong, you will know it! The car will run rough, if at all because of the vacuum leak.
Old Oct 11, 2007 | 07:03 AM
VO...'s Avatar
VO...
Administrator
Read this thread:
https://my350z.com/forum/intake-exhaust/299010-5-16-md-plenum-spacer-installed-having-idling-problems.html
Old Oct 11, 2007 | 07:15 AM
marques1's Avatar
marques1
Make Sure You Don't Strip The Plenum Bolts Like I Did Its A Pain In The *** They Break Very Easy. If You Happen To Strip Them Thought Go To A Bolt Store And Pick Some Up For About A 1.00.
Old Oct 11, 2007 | 09:47 AM
roast's Avatar
roast
Read over the online instruction manual a few times, and bring the printed instructions with you during the install for reference. I followed the instructions on the torque down sequence with a slight alteration... I didn't use a nut driver or a torque wrench... just a socket wrench with an adjustable head (can be used like a nut driver)... I put them all on in sequence by hand, then used the "nut driver" in sequence with moderate pressure, then again with as much as I could do by hand... and then one more VERY slight nudge with the wrench in the normal position... I had absolutely zero problems with the install.
The only thing I regret is not doing this mod sooner!
Old Oct 11, 2007 | 10:34 AM
chadalac350z
No one has tired this to see the outcome?
Old Oct 11, 2007 | 02:25 PM
SniperHunter
Thanks fellas. A local friend and MY350Z member/vendor will be helping me out with the install. Got the MD today. =)
RXKevin = Visionary Racing. Drop him a PM.
Old Oct 11, 2007 | 02:43 PM
Members get into trouble by breaking bolts. Be realistic with torque. Follow the instructions.
Old Oct 11, 2007 | 02:46 PM
It may be intuitive that bigger is better, but this is not the real word case. You get to a point where bigger gets worse. Study the charts at motordyne.com.
