Advanced Resonance Tuning (ART pipes)
Old Apr 9, 2012 | 12:21 PM
  #741
F2CMaDMaXX's Avatar
F2CMaDMaXX
Originally Posted by Trendkill
Sooo now we need to move on with another topic!!!! Lmfao
Anyone have a ART pipe vs Test pipe dyno comparo???
Yes Trendkill, i will help you out here, i'm not sure why so many people feel the need to post 'use the search' They're on the first page of this here thread.
Originally Posted by Motordyne
Regular test pipes always result in a large loss of low end torque. Compared to test pipes, the ART pipes produce a large gain in low end torque that is clearly felt and can be very usable for auto-cross or powerful launches in drag racing.
Old Apr 9, 2012 | 08:51 PM
  #742
alfhasg35's Avatar
alfhasg35
Cool
I tried that and didnt get much... I guess you dont have one?
You tuned?
That was just a discussion also no dyno...
Wow . I guess u really don't search do you.?? Post #10 in the link I posted has a link to ALL THE DYNO COMPARISONs..
Not JUST a discussion..
All I typed in was Art pipes in the search and it took me all but 1min to find out a question that has been asked way too many times..
Good luck mang...
Old Apr 9, 2012 | 10:42 PM
  #743
G35_FTMFW's Avatar
G35_FTMFW
Originally Posted by e30cabrio
I tried to leave this alone but just can't I'd appreciate insight into how Tony sending you a new set and return label leaves him in the wrong when you kept his pipes?
I have a set of V2s that cracked WHEN I BOTTOMED THEM. I paid 35.00 having them welded, good as new and all well.
You bottomed them out? How is that even possible, and they just cracked?
Old Apr 10, 2012 | 10:32 AM
  #744
F2CMaDMaXX's Avatar
F2CMaDMaXX
If you bottom out hard enough to reach up there, there isn't much that won't crack.
Remember, there are helmholtz resonators attached to the ART pipes.
Old Apr 23, 2012 | 07:37 PM
  #745
Gozirra's Avatar
Gozirra
I have stock cats with an HKS replica CB and a motordyne xpipe (decreased drone and removed rasp completely, but also made the exhaust much more quiet). Would you recommend these ART pipes to increase how deep the exhaust is? I also want to increase volume without making my exhaust raspy. Let me know!
Old Apr 23, 2012 | 07:57 PM
  #746
F2CMaDMaXX's Avatar
F2CMaDMaXX
ART pipes handle their own rasp control, but you may experience some rasp if the rest of the exhaust has any lips between the sections.
ART's will give some bass and some volume increase, but not too much. Most importantly, they will increase power and torque, even in the low revs.
Old Apr 24, 2012 | 04:12 AM
  #747
Z_enthusiast's Avatar
Z_enthusiast
Hello tony, any word on the production line yet?
Old May 10, 2012 | 11:11 AM
  #748
Deteria's Avatar
Deteria
Question about the VQ35HR throwing CEL. So I understand the HR is more likely to throw a CEL. And after reading the threads & posts, I believe I read somewhere that the CEL will affect mpg? So if I simply get tuned (which I am going to do this summer after installing the ART pipes), and I know UpRev Osiris can disable the CEL, does that fix the issues? Passing emissions in TX should be pretty easy, but I'm concerned about the mpg drop that some people have stated
Old May 10, 2012 | 11:59 AM
  #749
F2CMaDMaXX's Avatar
F2CMaDMaXX
CELs are not thrown for the cats with ART pipes, they have anti foulers installed for this reason.
The people reporting MPG drops have been throwing CELs for lean codes on one bank, it doesn't even appear to be that common. I showed a very marginal increase in my daily driven MPG and i cannot repro the lean bank code.
As for tuning, you can leave them in the anti-foulers, or do what some others have done, and have a standard bung welded in almost anywhere on the ART pipe and use Osiris to disable the cat CEL code. Another user has just unplugged their rear O2 sensors to fix their lean bank code.
Old Jun 4, 2012 | 10:52 PM
  #750
User 42426's Avatar
User 42426
sorry if this has been mentioned before, but don't want to go through 37 pages. Can the stock header and stock cat gaskets be used for the v2 art pipes on an hr? I only got some rtv sealant....
Old Jun 5, 2012 | 08:43 AM
  #751
F2CMaDMaXX's Avatar
F2CMaDMaXX
I believe you just use the RTV, sealant, if you use the gaskets, they'll blow out.
Old Jun 5, 2012 | 09:03 AM
  #752
Deteria's Avatar
Deteria
My ART Pipes came with 2 gaskets and silicone sealant. Use the gaskets on the ends that match up.
Old Jun 5, 2012 | 10:13 AM
  #753
User 42426's Avatar
User 42426
^^Which side of the art pipes did you use the gaskets on? the header or y pipe? I don't have any gaskets, just the sealant
Old Jun 5, 2012 | 10:14 AM
  #754
User 42426's Avatar
User 42426
was going to use stock ones
Old Jun 5, 2012 | 02:14 PM
  #755
Deteria's Avatar
Deteria
I forgot, but the gaskets only match one of the ends of the ART pipes. I think it's between the ART and Y pipe.
Old Jun 5, 2012 | 04:29 PM
  #756
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
^Correct. That is how they go together.
Old Jun 16, 2012 | 09:57 PM
  #757
User 42426's Avatar
User 42426
do you sell gaskets for the header/art flange? I just used the rtv black silicone that was included, is that enough?
Also, I currently dont have the o2 sensors installed on the art pipes, so the bung is wide open, I will get them installed soon. However, right now, the car sounds like a super loud bumble bee. I can't believe that plugging that hole is going to quiet it down to almost stock level. Is this correct? Just amazed that it can be this loud just because that little hole is open. Unless I have an exhaust leak, which is why I am asking, thanks
Old Jun 16, 2012 | 09:59 PM
  #758
User 42426's Avatar
User 42426
oops I guess my first ? was already answered above me, rtv it is
Old Jun 17, 2012 | 07:33 AM
  #759
Hydrazine's Avatar
Hydrazine
Yes, if you are running the bungs empty and without a cap or sensor a lot of noise will come out of the opening.
Old Jun 18, 2012 | 11:48 AM
  #760
(ZzzzzZ)'s Avatar
(ZzzzzZ)
I lost my support bracket when I took off my stock cats a while ago. Do you think the v2 art pipes will crack if I don't have that? I know you added the braket mounts but will it be okay without it? Or are they sure to crack...
