Advanced Resonance Tuning (ART pipes)
Old Jul 1, 2013 | 02:40 PM
  #881
(ZzzzzZ)'s Avatar
(ZzzzzZ)
does anyone know how I can get in contact with Tony? Looks like their profiles are either gone or haven't logged in in a while
Old Jul 1, 2013 | 08:34 PM
  #882
F2CMaDMaXX's Avatar
F2CMaDMaXX
Yes, definitely give them a call, you'll get through.
Old Jul 3, 2013 | 08:57 AM
  #883
Z33Garage's Avatar
Z33Garage
I have a Utec that I rescued from a bad flash by the old owner. I have a set of test pipes to install on the 05 DE, I have read several tuning threads but I am still not sure if I can run just res test pipes without a tune without running dangerously lean?
If I need to tune I will wait off till I can afford the other mods. Thanks for the time
Old Jul 3, 2013 | 03:28 PM
  #884
freddys 350z's Avatar
freddys 350z
after i put on art pipes i was at 14.4 afr during the dyno pull. after tuning it was at 12.6. its not dangerously lean, but not optimal either.
Old Jul 3, 2013 | 10:47 PM
  #885
F2CMaDMaXX's Avatar
F2CMaDMaXX
It will depend on a bunch of things, you're perfectly safe to fit them, just be wary of going on full throttle (less throttle is fine as the AF ratio will be pretty close with the wide bands)
Old Jul 4, 2013 | 12:00 AM
  #886
F2CMaDMaXX's Avatar
F2CMaDMaXX
Feels great to me
Old Jul 4, 2013 | 10:49 AM
  #887
RiskyBidness's Avatar
RiskyBidness
New 350z Owner! I have researched these ART pipes on and have found a little info but not a great amount for my application. I have an 07 HR, everything stock except KN drop ins. I am more interested in these pipes for sound improvement than performance improvement (although a bonus). I would like to eventually get the MD Shockwave exhaust system when $ permits. Any suggestions running with ART pipes and stock everything else? Would the sound/performance improvement be worthwhile without a tune? (forgive this 1st poster if he has inflicted undue burden due to ignorance).
Old Jul 4, 2013 | 12:22 PM
  #888
zerafian's Avatar
zerafian
I have art pipes on my stock exhaust(G35)...it makes it a tad bit louder and theres obvious rasp after 3k RPM. There is a little more low end power though. I would honestly suggest having an aftermarket exhaust before getting the art pipes. Possibly something with at least 2.5" piping at least.
Old Jul 4, 2013 | 01:59 PM
  #889
RiskyBidness
I see. I may just have to save and buy the Shockwave first. I didn't know if maybe the ART pipes could be an "appetizer' before I get the exhaust.
Old Jul 4, 2013 | 02:26 PM
  #890
travlee's Avatar
travlee
Master
if i were you i would invest in them, i have them on my 08 HR with invidia exhaust and takeda intakes.... throaty but not obnoxiously loud.... butt dyno says there is a differnce. my suggestion is to do all the mods you want before tuning, i changed intakes, went from HFC to ART pipes, and after doing that i dyno'd 10 hp less than when i tuned. now that i have swapped all that i am about to pull the trigger on the TDX2, luckily the guy that tuned me is going to retune for 200. dont waist the money on tuning if you think you are going to change things later on. btw, get what you can afford.... if you have the 1600 for exhaust get that first, if not get the ART pipes. last when i looked into the exhaust it was a 45-60 day turn time
Old Jul 4, 2013 | 02:30 PM
  #891
travlee's Avatar
travlee
Master
but... do you have the DE or HR motor..... the HR's dont have rasp with them
Old Jul 4, 2013 | 02:53 PM
  #892
F2CMaDMaXX's Avatar
F2CMaDMaXX
If you need a slight change in note, get the ART pipes now, if you need a larger one, get the TDX2 first and add ART later, such sweet sweet note
Old Jul 4, 2013 | 03:11 PM
  #893
travlee's Avatar
travlee
Master
haha, he doent NEED anything.... he WANTS
Old Jul 4, 2013 | 03:59 PM
  #894
RiskyBidness
This will probably be what I do.
Old Jul 4, 2013 | 04:01 PM
  #895
RiskyBidness
So very true. But isn't that the essence of Z cars?
Old Jul 5, 2013 | 04:38 AM
  #896
travlee's Avatar
travlee
Master
once you start modding, it will only get worse.
Old Jul 11, 2013 | 09:51 PM
  #897
freddys 350z
no ****..my mods cost as much as my car.
Old Jul 23, 2013 | 06:53 PM
  #898
Nino135's Avatar
Nino135
So excited, just bought the ART pipes and the TDX2 off a user on here. Hopefully have them arrive in a few days and get them installed and tuned in.
I've got an 07 HR with Nismo intakes. I have heard nothing but great things about this exhaust system.
Old Jul 24, 2013 | 08:16 AM
  #899
travlee's Avatar
travlee
Master
you should love it, when i put the art pipes on i had an ear to ear grin, my tdx2 is set to ship on 8/2
Old Jul 26, 2013 | 04:41 PM
  #900
Nino135's Avatar
Nino135
I'm so stoked to get it all put on, just waiting on gaskets from Motordyne to come in, should be here the 30th. So hopefully I'll be able to install next weekend!!
