Hello guys. Need your help about how to eliminate the "rasp" noise. I installed headers, test pipes, cancel the resonator and add 2" all the way from catback. I was told that installing back the oem catalyst will cancel the "rasp". Support please............
If you let the car warm up the rasp will pretty much go away. You can swap the test pipes out for high flow cats as well, if you can't handle the rasp.
Does you exhaust have a muffler? Get rid of the test pipes and get either hgih flow cats or if you if you got the cash, then get the Fast Intentions resonated high flow cats.
Put the largest inline resonator you can fit back in the OEM location, or at least as close to OEM location as possible. The completely stock exhaust rasps when the OEM resonator is removed. I can't prove that it will eliminate all rasp, but due to it's effect on the OEM exhaust alone, I can't imagine it's absence is helping at all.
+1
Rasp will reduce a bit when the exhaust warms up. It wont go completely away but it wont sound as raspy.
Don't worry about it. If you keep driving the car as is, pretty soon you will be so deaf that you hear the rasp. Problem solved. In the mean time, just crank up the volume of your music to compensate.
