how difficult would it be to space this down a little?
Old Jul 27, 2010 | 07:51 PM
Entaille's Avatar
Entaille
Default how difficult would it be to space this down a little?
I had my berk HFC's installed today. Had to use two gaskets to get it to seal but that's another story.
the still existing problem is that this brace now seems to touch part of my exhaust at times, slight rattle at idle (sometimes) and sometimes not.
is it possible to use washers where this brace bolts up, to lower it slightly?
I found a photo and circled the brace I'm talking about. thanks in advance for your input.
(doubt this belongs here but can't think of where to ask )
Attached Thumbnails how difficult would it be to space this down a little?-350z_unterboden.jpg
Old Jul 27, 2010 | 08:20 PM
adamciya350's Avatar
adamciya350
Sub'd...my ART pipes do the same dam thing, installed them saturday
the rattle is so dam annoying
Old Jul 27, 2010 | 08:26 PM
Entaille's Avatar
Entaille
for some reason, installing the HFC's, lowered the height of the mid pipes, so by the time it goes under the mid brace it was low enough to touch it at times.
hopefully that is the same issue you're having : ) I will let you know what I do because I will not just tolerate the rattle.. something shall be done! spacers or some way to adjust the hangers but I dunno how .. : P
Old Jul 27, 2010 | 08:31 PM
kramykram's Avatar
kramykram
yes you can use washers on the brace, thats what i did with the old style agency power to keep it from ratteling on the brace.
Old Jul 27, 2010 | 08:32 PM
Entaille's Avatar
Entaille
if you confirm that you have the same issue I'll pm hydrazine or the other motordyne rep, they are very responsive and helpful and probably have some ideas for us.
uh .. yeah, it's my motordyne plenum spacer causing the mid pipes to hang lower, please help sir!
Old Jul 27, 2010 | 08:34 PM
Entaille's Avatar
Entaille
thanks Kram! do you recall what size washers you needed? not sure how thick the bolts are there.
Old Jul 27, 2010 | 08:59 PM
JasonZ-YA's Avatar
JasonZ-YA
The bolts are M10x1.25, so just go buy some 7/16 washers, or even some 3/8 cut washers will work as they are over sized.......just jack the car up, remove one of the bolts and take it with you to verify when u swing over to autozone/homedepot and find some washers. longer bolts too if you want depending on how thick you go...its your car you decide.....
they are the nissan green bolts so if you want to keep things the same, get some 10.9 grade bolts to have equivalent strength........
Mine was actually rattling there but not because of my berk HFC or custom exhaust, but because my brace is all beat to hell..........
I actually had to simply get some channel locks and bend it back straight. I plan on buying another one and replacing it cause its all banged up bad. Probably nab one from a junk yard front end wreck z....
You can also probably wrap that brace with some exhaust wrap...
-J
Old Jul 27, 2010 | 09:53 PM
Entaille's Avatar
Entaille
thanks, perfect info there.
Old Jul 28, 2010 | 05:35 AM
NismoZ123's Avatar
NismoZ123
Default Picture
Could you post up the original picture you used? I've never seen that view before, thanks.
Old Jul 28, 2010 | 05:47 AM
Entaille's Avatar
Entaille
surely
Old Jul 28, 2010 | 08:48 AM
Entaille's Avatar
Entaille
here's another good one
https://my350z.com/forum/attachments...ts-zbottom.jpg
Old Jul 28, 2010 | 03:20 PM
GeauxLadyZ's Avatar
GeauxLadyZ
Cool pic, saved for reference.
Old Jul 28, 2010 | 09:11 PM
BoomerZ33's Avatar
BoomerZ33
hmm i never got any rattle when i put my berks on
Old Jul 29, 2010 | 07:00 PM
Entaille's Avatar
Entaille
you probably don't have the bassani exhaust. every set up is different.
rattles gone - used a couple of washers. if you want an easier to get to bolt to reference before you jack the car up and start working, the bolts are the same size as the ones that hold on your strut tower brace. pop one off and go to the hardware store.
Old Jul 29, 2010 | 08:43 PM
Frostydc4's Avatar
Frostydc4
Did you use longer bolts or did you reuse your old bolts?
Old Jul 30, 2010 | 09:57 AM
Entaille's Avatar
Entaille
reused the old bolts. we only spaced it down maybe a quarter of an inch and it gave enough clearance - the bolts still worked perfectly well
SharX59
Sep 27, 2015 09:23 AM
wayneside
South East
Sep 23, 2015 02:38 AM
wayneside
North West
Sep 23, 2015 02:23 AM
