Anyone interested in a new custom intake for the DE motor?
Old Mar 9, 2011 | 01:18 PM
  #161
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
Glad you did the dyno comparisons the proper way (several pulls for both set ups and using the highest numbers), because the ECU does compensate for the WOT pulls you're doing on the dyno and adjusts accordingly.
I'm a bit disappointed that I'm not seeing any nitrous numbers, though.
Old Mar 9, 2011 | 04:33 PM
  #162
ChrisNelson's Avatar
ChrisNelson
We hit 320 hp on nitrous but had a problem with the fuel delivery - didn't even get one full run in on spray...
I think the fuel pump needs to be upgraded and then we'll try again.
Old Mar 9, 2011 | 04:39 PM
  #163
ChrisNelson
Originally Posted by rich2342
Interesting, but what advantage given a plenum spacer nets about the same for what about 200 bucks?
I don't know much of anything about the plenum spacer benefits as I've never looked up dyno test comparisons for any of them. I'll have to go looking.
I believe that this manifold has the capability of supporting further HP gains than the stock manifold with a spacer. (If all you did was either this manifold, or just the spacer, then maybe there is no reason to do the manifold...) The car this piece was tested on was basically stock, what if it was boosted, had upgraded cams, pistons or a full header/test pipe exhaust system? This manifold flows better than the stock unit so with even more supporting mods, this unit can perform better than just a spacer further down the line of performance modifying.
Of course it would be very difficult to test - you'd have to have 2 days worth of dyno time and working on the car to test the full capability of the two setups.
(ie: start with a stock car, then add a spacer, then do this manifold. Then go back to the stock manifold and do an exhaust system, then the spacer, then this manifold. Then go back to the stock manifold and do cams and an intake, then a spacer, then this manifold... etc...)
Does that make sense? If not I can elaborate.
Old Mar 9, 2011 | 05:03 PM
  #164
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
Interesting. Looks like a nice piece and it appears that it has significantly more plenum volume than the Kinetix SSV. Congrats on the results.
Old Mar 9, 2011 | 10:29 PM
  #165
ChrisNelson
Here is the botched nitrous run. As you can see we barely got into it and managed to pull 320hp anyways. I think 375 is easily attainable.
This graph shows HP vs. AFR. Notice first it spikes lean really hard like a dry shot and then gets insanely rich. This is showing the 500 RPM lag between the nitrous kicking in and the fuel coming into play.
Old Mar 13, 2011 | 02:07 PM
  #166
boostedforlife's Avatar
boostedforlife
Originally Posted by Voboy
results are nice, solid gains throughout the powerband. wonder how it'd do with cams and a bump in the rev limiter.
if u can get OP to ship it to me, id glady like to test it on my car, i have cams and 8k rev limited( on rev up)
Old Mar 13, 2011 | 02:21 PM
  #167
2004Black350z's Avatar
2004Black350z
Exhaust Whore
what intake did u use? i seen a popcharger. After my recent tune at CIN with my popcharger and temps im either gonna fabricate my on heat box or buy momentums cold air intake
Old Mar 13, 2011 | 06:58 PM
  #168
03basesedan's Avatar
03basesedan
The spacer gives similar gains, but your manifold likely holds power much better after 6500rpm.
Old Mar 21, 2011 | 02:47 AM
  #169
Venom8.1's Avatar
Venom8.1
very good 3d
Old Mar 22, 2011 | 05:38 PM
  #170
350z-900whp's Avatar
350z-900whp
any info on boosted cars ?
Old Mar 22, 2011 | 08:59 PM
  #171
ChrisNelson
Not yet.
Old Mar 22, 2011 | 10:17 PM
  #172
03basesedan
Yup, I see you're coming around to the importance of temps.
Are you talking about this one?
http://www.momentumperformance.com/p...old_Air_Intake
It's an interesting idea, but I don't like how the MAF necks down. Is the built-in MAF in the stock location? I always thought that was pretty important.
Old Mar 23, 2011 | 05:45 AM
  #173
rich2342's Avatar
rich2342
^ Tony's always said the 06 airbox was best due to heatsoak issues..
Old Jun 16, 2011 | 07:07 PM
  #174
ChrisNelson
<iframe width="425" height="349" src="http://www.youtube.com/embed/ho6wXN2ZBZQ" frameborder="0" allowfullscreen></iframe>
Old Jun 16, 2011 | 07:24 PM
  #175
DaveJackson's Avatar
DaveJackson
Master
Thumbs down
^^ That video was about as informative and useful as an episode of 2-and-a-half Men.
Old Jun 16, 2011 | 08:24 PM
  #176
2004Black350z
Exhaust Whore
lol +1
Old Jun 16, 2011 | 08:43 PM
  #177
SirSpeedyZ's Avatar
SirSpeedyZ
not enough info in the thread?
Old Jun 19, 2011 | 01:05 PM
  #178
ChrisNelson
exactly
The video is to show what it looks like on the car, what it sounds like, and show that it's being used successfully.
Old Jun 19, 2011 | 04:32 PM
  #179
2004Black350z
Exhaust Whore
didnt hear it in the vid and def didnt see any successful show. thx though....
Old Jun 19, 2011 | 07:31 PM
  #180
DaveJackson
Master
Yep. I stand by my initial statement, too.
