HR/VHR Headers on DE?
Old Mar 30, 2011 | 07:01 PM
phunk's Avatar
phunk
CJ Motorsports
Default HR/VHR Headers on DE?
If used with HR/VHR Test pipes, will it all bolt up?
Old Mar 30, 2011 | 07:24 PM
singh's Avatar
singh
_______________
well i know that DE headers can fit on the HR engine..
Old Mar 30, 2011 | 07:29 PM
phunk's Avatar
phunk
CJ Motorsports
Yes they attach to the engine just the same. But the flange at the cat/test is different. Y pipes are the same tho. So will HR mani/test combo bolt to DE is the question
Old Mar 30, 2011 | 07:30 PM
phunk's Avatar
phunk
CJ Motorsports
Pretty sure answer is yes. Also meaning long tubes for 350z de/HR and 370z would all be compatible.
Old Mar 30, 2011 | 07:41 PM
bimmertech's Avatar
bimmertech
from the research i have done on the topic, fast intentions stated that they did fit Z34 headers on an HR Z33 but it did require cutting out a section of one of the primaries and altering it a bit. i do not recall the specifics of the modification, but hope that helps.
edit:
Originally Posted by FastIntentions
The headers will currently have available fit the 2008+ G37 coupe & 2009+ 370Z. They fit the 350Z HR with minor modifications. Now I did a test fit and sent the 350Z HR on his way. However if I decide to put the headers into production for the 350Z HR I will have to make a permanent change. It is nothing major it is just routing one tube on the driver side slightly different to give more clearance between the header and floorboard.
Old Mar 31, 2011 | 04:37 PM
phunk's Avatar
phunk
CJ Motorsports
thanks. i will share my findings.
Old Mar 31, 2011 | 08:11 PM
shiftdrift06's Avatar
shiftdrift06
HR Headers will only work with HR Cat or Testpipes. Bolts up to DE Y-pipe fine.
Here are some pics of me putting HR OEM headers with HR Testpipes when i swap my engine...
Old Apr 1, 2011 | 02:54 PM
phunk's Avatar
phunk
CJ Motorsports
thanks for the pics
Old Apr 3, 2011 | 05:04 PM
12AutoX's Avatar
12AutoX
I have a how-to around here somewhere if you search my posts from last summer. You have to pull the manifold mounting studs from the middle pipes and swap the holes that they are in. They go from / to \ if you know what I mean. I used CNT Racing resonated test pipes for an HR. They were around $200. Not much gain best I can tell.
Old Jun 19, 2013 | 07:47 AM
vito350zed's Avatar
vito350zed
What about the sound? will it give the vq35de that good HR sound?
Old Jan 29, 2014 | 11:46 PM
Himebaugh86's Avatar
Himebaugh86
no putting the HR headers on a DE won't give it that good HR sound, reason being the engine itself gives the HR its sound because the HR motor is 80% different from the DE.
Old Jan 29, 2014 | 11:50 PM
Himebaugh86
I have DC sports headers that came off an 04 DE and I have a 07 HR i haven't installed them yet but I did come to that realization when looking at the stock headers bolting up to my cats that the HR triangular flange is a more narrow triangle than the symetrical DE flange so I'll probably have to get DE test pipes to make everything work. thanks for the help guys
Old Jan 30, 2014 | 05:08 AM
MeinVinyl's Avatar
MeinVinyl
I think the people from 2011 might be a little off. I'm looking at LTH for my HR and the 3 manufacturers I have looked at all say the 350Z DE, HR & 370Z have the different LTH setups. They stated that the same goes for if you were to run DE headers/test pipes on an HR would not fit properly. I'm not sure why this is besides just the flange from the header to cat/test pipe. I know they'll bolt up to the heads, but beyond that I don't know.
I also noticed my Y-Pipe was not the same as my DE Y-Pipe. When I put on the exhaust from my 2003 350Z, it took a little bit of bending to mount to the HR as it was a very minor angle difference as well.
For these reasons I'm personally going with an HR specific LTH setup, but the Tanabe Y-Pipe and a single exhaust (selling my dual exhaust setup).
Old Jan 30, 2014 | 03:36 PM
Suwaidi's Avatar
Suwaidi
DE Headers/Test pipes will fit on an HR/VHR, as long as they're both DE (Headers/Pipes). Some people with the HR have done this with the Tomei test pipes / Expreme headers, and the VHR guys have done it with the Momentum replica (Z1 Headers).
LTH's are a bit different. PPE's 370z LTH's have less bends as the engine bay is wider, whereas the HR headers are more compact (so they're not interchangeable). I've heard however that the FI LTH will fit on a 350z with some modification.
Old Mar 4, 2018 | 01:48 PM
Jcamarillo6's Avatar
Jcamarillo6
Default Megan racing headers 2006 to a 2007 350z
does any body knows if the megan racing headers for a 2006 350z would fit a 2007?
Old Mar 4, 2018 | 02:36 PM
MicVelo's Avatar
350Z/370Z Tech Moderator
Looking at any of our vendor catalogs it's apparent that the DE and HR exhaust setups are different. Would presume for a couple reasons: port config and engine width/height. Either way, why not get the right set to begin with? (I'm guessing you're talking about a used set...)
Old Mar 4, 2018 | 02:41 PM
Jcamarillo6
no its cause i bought this headers but i think the description is wrong and i barley notice
dkmura's Avatar
dkmura
General & DIY Moderator
Besides bumping a thread that's over FOUR years old, why even try using parts designed for one engine on another? Even if they marginally fit, the design is not maximized for an HR engine. It makes no sense to try to save a few bucks while using a part that downgrades the performance of the engine you're fitting it to.
Old Mar 4, 2018 | 02:51 PM
travlee's Avatar
travlee
Master
Prob came from honda world where megan is da shiznit, not to mention a balla on a budget
B Esquire
Sep 24, 2015 07:52 AM
z33z_nutz
Sep 23, 2015 07:22 PM
EnjukuRacing
Sep 9, 2015 06:42 AM
