Cracked ART Pipes? Art Pipe Making Noise
Old Jul 2, 2011 | 01:49 PM
Shawz1102's Avatar
Shawz1102
Default Cracked ART Pipes? Art Pipe Making Noise
Update: Hey guys just took my car to a local muffler shop and they removed it for me. Turns out it was my stock y pipe making the ringing noise. The ART pipe was hitting the heatshield so i thought it was the art pipe that was causing the weird noise. I've decided to buy an aftermarket y pipe to get rid of toe POS OEM y pipe but have already removed the heat shield so it's not making the rattling noise anymore
Good to know it was not an expensive to fix problem
Old Jul 2, 2011 | 01:58 PM
ChriZTT's Avatar
ChriZTT
Interesting. Unfortunately I have no clue what could be causing the problem, but I am interested in seeing what Tony has to say about this.
Old Jul 2, 2011 | 04:18 PM
Wu-Watt's Avatar
Wu-Watt
Have you removed them from the car and inspected them? I had cracked mine, and had them welded up. I didnt have that rattle tho...
Old Jul 2, 2011 | 04:36 PM
Shawz1102's Avatar
Shawz1102
My car is pretty low, and I bottomed out.
No, that's be way too much pain to do... I've never bottomed out, scuffed or anything.
What's weirder is that when i put my palm against the helmoltz resonator to try to hold it still while i bang it, it eliminates the sound. When i let go, the rattle/ring comes back. If something was loose inside, then the rattle/ring would persist regardless of whether i had my palm on it or not.
Old Jul 3, 2011 | 06:06 AM
Itzcashew's Avatar
Itzcashew
Take it off and shake it to see if the material in the resonator is moving.
Old Jul 3, 2011 | 07:07 AM
2004Black350z's Avatar
2004Black350z
Exhaust Whore
What exhaust do u run?
Old Jul 3, 2011 | 10:43 AM
thekinn's Avatar
thekinn
I'm guessing skittles.
Old Jul 3, 2011 | 01:25 PM
Shawz1102's Avatar
Shawz1102
Stock exhaust.
Old Jul 3, 2011 | 01:29 PM
ChriZTT's Avatar
ChriZTT
Originally Posted by Shawz1102
Stock exhaust.
I wonder what significance, if any, this might have.
Old Jul 5, 2011 | 03:55 PM
Itzcashew's Avatar
Itzcashew
Some exhaust are known to crack test pipes such as the Nismo exhaust Y pipe.
Old Jul 5, 2011 | 04:45 PM
2004Black350z
Exhaust Whore
ding sing sing we have a smart member lol. And YES you're right cashew. That was the reason for me asking
Old Jul 6, 2011 | 08:52 AM
ChriZTT's Avatar
ChriZTT
Although this is true, the OP does state that the welds on the ART pipe were all checked and showed no cracks. I am not refuting the stock exhaust may of had some thing to do with the problem, rather I am just wondering if the problem could simply be ART pipe related.
Old Jul 6, 2011 | 09:04 AM
Vivid Racing's Avatar
Vivid Racing
Vivid Racing
The resonator has come loose inside. Pull the test pipe and check it.
Old Jul 6, 2011 | 09:41 AM
ryanm8's Avatar
ryanm8
Afaik, the helmholtz resonator is hollow. There's nothing inside like regular resonators. I'm not sure what could be rattling... Maybe a piece of steel wool from the non-foulers
Old Jul 6, 2011 | 11:32 AM
TheSyn3rgist's Avatar
TheSyn3rgist
Hey guys, i've had the ART pipe on my car professionally installed for almost a year now and just this past week, it started making a weird sound. At first, i thought it was the heatshield hitting it (unlikely since it was fine for almost a yr) so i removed it, but the sound still persisted. I started banging on the art pipe lightly with my hand to find out where it was making noise from and it seems like it's making noise from the helmoltz resonator
It seems like something inside the resonator is loose ... I have a video if you guys watch, i bang it in several places to find out where the problem was coming from. Also, i checked the welds and the pipe. Nothing is cracked, so it's coming from the inside. It's not loose bolt from the y pipe either, that's already tight.. I tired banging the resonator on the passenger side and it was fine - made no noise. Does anyone know exactly what's causing the sound?
Here's the vid: http://www.youtube.com/watch?v=vzgT1KF60NM
The other day when I was swapping back to cats for emissions I noticed that my ART pipes sound like they have sand in the resonator. I didn't think too much about it, but I guess I should have...
Old Jul 6, 2011 | 12:06 PM
Shawz1102's Avatar
Shawz1102
The problem started when i had the Motordyne dual exhaust with the XYZ on the car, it still persisted after i went back to stock (which i currently run if that's what you meant). The ring/rattle is just more pronounced when i have a quiet (stock) exhaust.
Old Jul 6, 2011 | 12:49 PM
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
There is a metal screen inside the helmholtz resonator. It may have come lose. Contact us for warranty details. (661) 298-7555
Justin100
Nov 29, 2015 03:58 PM
Sleeper_Z
Sep 30, 2015 10:25 AM
codek
Sep 28, 2015 03:03 AM
samansharif
Sep 25, 2015 12:31 PM
