87mmFT Throttle Body Anyone?
Old Feb 11, 2012 | 04:49 AM
  #61
pcg_k25's Avatar
pcg_k25
Originally Posted by Torgus
Too bad the 'company' which made the LS2 MAFs for the titans only made 12 and are out of business...at least that is what I last read about them. Are they back in business or is someone else now making the kits?
Also, I can't use uprev with my ecu so I need a hardware fix that will let me run the ls2 TB with an 03 maxima ecu...even with a full standalone it will throw a code...
SG Motorsports couldn't get it to work correctly. That is the only 3.5DE I know of having an LS2 TB attached and semi 'working'.
Do you have a link of how to use the LS2 TB with UpRev on a 3.5DE ecu? It is amazing how incompatible Nissan made the different ECUs even different 3.5 ECUs which should basically be all the same...
If your talking about the LS2 throttle bodies (PGM) they were made by two gearheads like us. They have never said how they modified the LS2 its their secret I guess. I talk to one of those gearheads all the time and they will not say how the did it! But like I said its all in the voltage!
On the SG what code was it throwing? I going to guess low voltage.
I will be getting into the Z's throttle body wiring sunday.
Old Feb 11, 2012 | 08:15 AM
  #62
CLyons0203's Avatar
CLyons0203
Who made the adapter plate? I would like one that would allow me to bolt on a 09 maxima throttle body to the stock G35 manifold. The 09 maxima uses the same bolt spacing as the titan and has a 80mm throttle body.
Old Feb 11, 2012 | 10:06 AM
  #63
pcg_k25's Avatar
pcg_k25
Originally Posted by CLyons0203
Who made the adapter plate? I would like one that would allow me to bolt on a 09 maxima throttle body to the stock G35 manifold. The 09 maxima uses the same bolt spacing as the titan and has a 75mm throttle body with no taper.
We are making the spacer plates
Old Feb 12, 2012 | 04:08 AM
  #64
Torgus's Avatar
Torgus
It would throw a code every time the engine was started as it detected a throttle fault, and the code would have to be cleared to take the DBW out of failsafe mode. No idea what the actual code was unfortunately I guess we could ask them. Having to clear a code every time I started my car is just not an option as mine is my DD again.
90mm LS2 pinouts are as follows....
PIN ID LS2 90mm
A.) ACT2
B.) ACT1
C.) +5v TPS Reference
D.) TP1 Signal 0-5v
E.) Common Ground
F.) TP2 Signal 5-0v
stolen from corvetteforum.com
Let me go find the 350z an 02-03 maxima pin outs.
I read that if you have Osirus you can flash the ecu to ignore the throttle code, that is what people do when they want to use a cable driven throttle body. Not sure if this is true. And I know it doesn't help me with my maxima ECU as we can't use Osirus(fwiw almost nothing works with our damn bastard of an ecu)
I am in 100% agreeance it is all in the Voltages...
All of the resistance and voltage values are easy to find in the FSMs. I just looked both up. I guess the real question is what does the GM unit produce?
Old Feb 12, 2012 | 01:28 PM
  #65
pcg_k25's Avatar
pcg_k25
PIN ID LS2 90mm
A.) ACT2
B.) ACT1
D.) TP1 Signal 0-5v
E.) Common Ground
F.) TP2 Signal 5-0v
All i need is the 350z pin outs! I have the LS7 working great on my titan, so does nicks titan. We are working on the 350z wiring now
Old Feb 12, 2012 | 01:33 PM
  #66
kacz07's Avatar
kacz07
Would love to try this out w my tuner. Have stock MAF, GTM 3" MAF, and Z1 82mm MAF as well. Also looking to port my Cosworth manifold. I have a built NA motor w cams.
Old Feb 13, 2012 | 02:09 PM
  #67
CLyons0203's Avatar
CLyons0203
02 maxima wiring is the same as G35\Z at the throttle body
Old Feb 13, 2012 | 04:04 PM
  #68
Torgus's Avatar
Torgus
so...
PIN ID LS2 90mm..............................................02-03max/g35/Z Stock Throttle body
A.) ACT2......................................................Br own Motor 2
B.) ACT1......................................................Ye llow Motor 1
C.) +5v TPS Reference....................................Red Input
D.) TP1 Signal 0-5v........................................White Output 1
E.) Common Ground........................................Black Common Ground
F.) TP2 Signal 5-0v........................................Blue Output 2
is this right? I guess i could go get my trusted multimeter...
If the ECU just saw a constant voltage what would happen? Assuming you are running a full stand alone...couldn't you just fool the ecu to thinking it is at idle?
Old Feb 14, 2012 | 04:23 AM
  #69
titanss's Avatar
titanss
Thanks for the pin out info, this is going to kick this project into high gear.
Old Feb 21, 2012 | 11:08 AM
  #70
str8dum1's Avatar
str8dum1
update?
Old Feb 21, 2012 | 11:31 AM
  #71
pcg_k25's Avatar
pcg_k25
Work in progress bro. We are working on the wiring, hopefully we will have video of the throttle body hooked up to the Z working rite or wrong!
Old Feb 28, 2012 | 09:57 PM
  #72
kacz07's Avatar
kacz07
Done?
Old Mar 5, 2012 | 01:53 PM
  #73
Torgus's Avatar
Torgus
Would love an update! Or to hear what problems you are running into.
Old Mar 16, 2012 | 11:42 PM
  #74
pr-g35driver's Avatar
pr-g35driver
can't wait to see where this goes
Old Mar 17, 2012 | 05:24 AM
  #75
kacz07's Avatar
kacz07
Has gone nowhere in the past month...
Old Mar 17, 2012 | 07:04 AM
  #76
pcg_k25's Avatar
pcg_k25
I am out of town working. Kind of hard to drive 5hours aday work 10hrs and work on the Z! Should be home in about 2 weeks.
Rome wasnt built in a day. Just hang tight guys.
the LS7 was just dynoed on the titan, and yielded 16.5rwhp. So i'll be happy with 8-10rwph if we can get it working correct on the Z!
Old Mar 17, 2012 | 08:08 AM
  #77
rich2342's Avatar
rich2342
Originally Posted by JCITY
I've got a Mine's throttle body on my Z.
To be honest,don't really know the mm diameter.
Maybe,3mm over stock?
It is visually larger than the OEM T body.
In addition,inner surfaces and all parts of the veturi
are highly polished to almost a gloss.
The performance gain is excellent.
Dyno proven?
What does it entail for neccesary parts etc?
Old Mar 18, 2012 | 08:43 AM
  #78
kacz07's Avatar
kacz07
Originally Posted by rich2342
Dyno proven?
For reference:
http://www.ppi-mines.com/350Z.html
Old Mar 18, 2012 | 06:04 PM
  #79
SurraTT's Avatar
SurraTT
wow for at 2.5 mm increase thats pretty costly...
The 09 Maxima TB at 75MMM is a much better option cost wise.
Old Mar 18, 2012 | 07:03 PM
  #80
INTIMAZY's Avatar
INTIMAZY
Dyno proven?
That only applies if you use magic air from Mount Fuji.
A handful of us have been running bored throttlebodies from Proflow and 350Evo with really next to nothing for gains.
That's not to say that there are NO gains to be seen from this. I still feel the upper manifold+throttlebody+MAF combo can make some nice gains just not through non-revup cams.
There is no single factor that prevents these cars from making more power beyond boltons. I feel it's multifactorial and we won't see crazy numbers anytime soon until someone (besides SG) addresses ALL the problems.
I've been wanting to try out a spare LS2 throttlebody from my TrailSS just didn't have the motivation...
