PPE Longtube Headers
Old Jul 20, 2014 | 06:34 AM
  #1361
HarleyDobbs's Avatar
HarleyDobbs
Finally have the time to get the car dyno tuned this weekend with the headers. I'll give and update once I get the numbers. I going from ART and stock headers to PPE's and I know a lot of people have that set up. Hoping to hit 300 whp and 400+ with nitrous.
Old Jul 24, 2014 | 06:59 AM
  #1362
HarleyDobbs
Finally got to tune my HR for the headers. Gain of 33whp NA and 40whp Nitrous. Needless to say...PPE's were more than worth it! I feel its a combo of the tuner but the quaility of the stepped headers. Each time it was tuned it was on a DynoDynamics dyno. The current tune was done on a newer dyno vs the prior one was on a dyno that was 8-9 years old.
Shout out to Hill's Garage for the tune! Wasn't expecting a gain for 30+ across the board.
Old Sep 19, 2014 | 08:22 AM
  #1363
A-Town-Z's Avatar
A-Town-Z
It seems like most, if not all of you guys are running PPE's with a single exit or dual exit setup. Anyone in here running true dual's? I'm curious to hear how that would sound.
Old Sep 19, 2014 | 08:41 AM
  #1364
travlee's Avatar
travlee
Master
i am thinking of them, and paired with my tdx2, think it would sound good... if i do pull the trigger on them it will be after the holidays
Old Sep 19, 2014 | 09:36 AM
  #1365
DarkZ03's Avatar
DarkZ03
I think the general consensus is that they work best with a single. I think it would sound pretty sick with the motordyne TD.
Old Sep 19, 2014 | 10:30 AM
  #1366
Suwaidi's Avatar
Suwaidi
I've had the PPE's with both the Motordyne TDX2 and the Invidia Gemini (current setup). I am cammed, so exhaust sound is slightly deeper, but:
With the Motordyne TDX2: clean, droneless sound 3500RPM+. At WOT, it literally screams. I actually had someone get out of their car at a stoplight, come over to my car and ask what exhaust setup I was running.. thought I was going to get robbed <.< As a daily driver though, there is some drone presence at low RPM. The setup is loud, but sounds amazing overall.
As for the Invidia Gemini, much much quieter.. I would say a good 25-35% reduction in noise level (which was my reason of swapping - noise regulations). It's actually slightly quieter than the TDX2+ART's, but deep at low RPM. Still sounds decent, but no where near as aggressive as the TDX2+PPE.
I was happy with both setups. If I didn't have local noise regulations, I would've gladly kept the TDX2+PPE.
Old Sep 19, 2014 | 01:18 PM
  #1367
Bmurray350z's Avatar
Bmurray350z
They sound insane with my Momentum single.
Old Sep 19, 2014 | 01:45 PM
  #1368
67ZNISMO's Avatar
67ZNISMO
Got any sound clips?
Old Sep 19, 2014 | 03:36 PM
  #1369
travlee's Avatar
travlee
Master
second this..... bmurray yours sounds great, i want to hear with tdx2
Old Sep 20, 2014 | 02:30 AM
  #1370
Suwaidi's Avatar
Suwaidi
I'll try to dig something up but I don't think I have any clips with the PPE's. Best way to explain it would be it sounds the same as ART+TDX2+Stock Headers up to ~2500 or ~3000rpm, then opens up to a clean, race-like note. Some rasp, but sounded great IMO.
Old Sep 20, 2014 | 04:49 AM
  #1371
waldo36's Avatar
waldo36
are you running a catalytic? If so, how do you have it setup for true dual?
Old Sep 20, 2014 | 06:45 AM
  #1372
Suwaidi's Avatar
Suwaidi
No emissions testing where I am -- no cats.
On a side note, for those who can pass with HFC's, Motordyne does make HFC (200-cell count) midpipes that you can order separately, or as an additional charge if you're placing a new order (for their TDX2 that is).
Old Sep 20, 2014 | 07:17 AM
  #1373
waldo36's Avatar
waldo36
Lucky bastard, but at least I'm not in CA.
The only problem with the XYZ mid-pipe is I want to keep my Gemini setup. So that's the only thing holding me back from swapping. I need LTH, w/cats, and maintain true dual...ya I'm needy.
On a different thread a guy suggested welding in stillen cats like these (below) I guess. The tough part about that is, I would be fully committed to that setup since it would need to be welded in. And I would probably have to cut out the resonators on the Gemini to put the cats right there. So I would probably lose that nice low tone. So much fab needed, so little money, and definitely more questions than answers.
(http://www.stillen.com/product/catal...ia-112924.html)
Old Sep 20, 2014 | 07:34 AM
  #1374
Bmurray350z
Saw these on PPE's instagram page. PPE custom made some VQ longtubes with HFCs built in.
Old Sep 20, 2014 | 08:25 AM
  #1375
waldo36's Avatar
waldo36
Hmm, that doesn't look too much different than my current setup. It just looks like regular shorties welded to a cat...not saying it wouldn't perform better, it just seems like its the exact same setup I'm running now.
To me, this doesn't look like a LTH setup with a cat. I figure if you're going to add a cat to LTHs, it would be near the end. In my simple mind the pic below makes sense to me on where to the cats. But PPE knows what they're doing, I'm just skeptical of their setup.
Old Oct 3, 2014 | 09:08 AM
  #1376
cyc5181's Avatar
cyc5181
Default CEL P2A03 and P2A00
Anyone with PPE have these codes pop up? My PPE came with the J connectors for the rear O2 sensors, so I thought i wouldnt need to do the non foulers.
I've had these codes twice, just want to see if adding the non-foulers will help with this.
Thanks.
Old Oct 3, 2014 | 09:10 AM
  #1377
travlee's Avatar
travlee
Master
are you tuned or no?
i am guessing no because you are running lean
Old Oct 3, 2014 | 09:14 AM
  #1378
Classy's Avatar
Classy
Thanks.
I ran OBX Long Tubes on my car untuned, I never threw a code, but when I finally did take it in to get tuned, I was running pretty lean. I suggest getting tuned for what you got and it will be allllll better.
Old Oct 3, 2014 | 09:22 AM
  #1379
The_Assassin's Avatar
The_Assassin
Oh ur running 370z obx long tubes ?...what gains did u get from them
Old Oct 3, 2014 | 09:25 AM
  #1380
cyc5181's Avatar
cyc5181
Forgot to mention this, but yes I am tuned. Using Osiris and its tuned by a forum member here.
These codes came on while cruising on the highway. At the track the CEL never came on.
I've had p2a00 & p2a03 combo twice and one time it threw a p0137 & p2a03 combo.
even with the cel, the car drives fine.
