PPE Longtube Headers
Old May 15, 2014 | 10:06 AM
  #1341
Bmurray350z's Avatar
Bmurray350z
Originally Posted by Suwaidi
Look over on the 370 forums - I've only seen one PPE header pop up for sale there. When speaking to Paul at PPE though, I was told the PPE VQ37VHR headers would not fit on the HR.
So it's either a used PPE HR or FI VHR
i wonder how that works..? because if 370z headers and test pipes/cats will work on an HR, then why would the longtubes not? i think he may just be trying to play it safe assuming it wouldnt work.
Old May 15, 2014 | 10:17 AM
  #1342
Suwaidi's Avatar
Suwaidi
When I inquired about this I was told that the 370z engine bay is smaller and the PPE's are shorter for the VHR than an HR, not sure how true that is though. In any case, I've only seen one VHR PPE for sale, and one HR.
& Join the FB parts group if you haven't already!
Old May 15, 2014 | 11:21 AM
  #1343
KingBaby's Avatar
KingBaby
Hardest Setting
370Z LTH fits on the 03-09 Z with no extra modification....
Also any 03 + header/testpipe configuration fits on any 03 + model as long as the header and testpipe are of the same year.
Example:
03 header/testpipe can fit on a 07 and vice versa
What doesn't fit is interexchanging a 03 header and 07 testpipe the flanges are different and do not work.
I however have seen shops redrill them to work.
Old May 15, 2014 | 11:36 AM
  #1344
Suwaidi's Avatar
Suwaidi
The designs are a little different. The 370z tubes have less bends because the engine bay is wider. The HR headers are more compact. The 370z headers will not fit on the 350z HR.
That's what I got from Paul when I inquired about the fitment.
Old May 15, 2014 | 12:19 PM
  #1345
Nabush's Avatar
Nabush
On a DE, non-stepped vs stepped:
http://g35driver.com/forums/intake-e...eaders-22.html
Nabush, Tomei 264's. Power gains will vary from dyno to dyno, I've done a before/after with the cams and headers separately. Cams were about +11whp, can't remember torque, but the headers were +11whp and +25tq - amazing gains in pretty much every RPM range (I can't recall if cam timing were modified after cam installation, but my final tune after the headers had over 20 runs). If you are looking at cams, I'd take a look at this article:
http://www.modified.com/tech/modp-10...m/viewall.html
I settled with 264's because I wanted daily drivability, I've seen some videos of 272's idling on a Z and it seems too rough to be a daily driver. I would suggest you get the PPE headers first, see if you're satisfied with the gains, and if not, consider cams. The cams themselves are about $700 to $900, the labor however is very long. It was worth it to me because I want to stay NA, but if it's power you seek, FI is the road to go down. There's only so much we can do on the VQ NA without pouring a lot of money into them.
Hi,
I plan to stay NA because i go to the track very often and i want a reliable engine. With FI 30min of full throttle laps would be too hard i think...
I was thinking of 272 tomei, because i don't use the car on the street very often..
Do you know what's the difference between parallel merge and spike merge in terms of performance ? can't find infos on the net...
thanks
Old May 15, 2014 | 12:43 PM
  #1346
Suwaidi's Avatar
Suwaidi
I have no clue about the difference in collectors, I would email PPE and ask them about that. From the research I just did though:
http://forums.corvetteforum.com/c6-t...e-headers.html
"A stamped, non merge collector with a spike will produce less HP than a merge with out."
"The theory is simple, the space the fork takes up in the collector would be otherwise dead air space which would slow for a moment the exhaust velocity. By having the fork in place the exhaust velocity is maintained improving the overall performance of the header."
Old May 18, 2014 | 06:34 AM
  #1347
Nabush's Avatar
Nabush
There is something i don't understand...
Is stepped equivalent to "parallel merged collector" and non stepped equivalent to "formed collector with spikes" ?
If so the gain of parallel merged collector are only 2 hp in the high rpm and a big loss between 3 and 4K rpm ?
Thanks.
Here are the answer of PPE to a contact form question i sent them :
Hi Alexandre,
The parallel merge collector flows a little smoother and will give you a little more scavenging. Depending on what your goals are on your car, it may be worth the extra money.
If you are building a high-rpm Naturally Aspirated motor and trying for every last bit of power, the parallel merge collector will give you the most power gains.
If you are building a street car with just bolt on modification, the formed collector with spike would be good enough.
If you are building a supercharged car, the standard formed collector with spike is good enough as the exhaust is pressurized and scavenging doesn't make a big difference.
Here is some information on the formed collectors we use:
http://www.coneeng.com/results.html
Let me know if you have any other questions or if you would like to order a set.
Best Regards,
Paul Prentis
PPE Engineering LLC
Old May 18, 2014 | 07:42 AM
  #1348
Suwaidi's Avatar
Suwaidi
^ Pretty much clears up the collector question. I believe the DE's are non-stepped and HR's are stepped, except during that dyno the owner requested a custom-made DE stepped header.
Old May 18, 2014 | 07:48 AM
  #1349
secwind's Avatar
secwind
370z longtube will hit the steering column on the HR. You can still make it fit by putting a dent in the header where it's touching.
Does anyone has TDX2 with their PPE? I'm wondering how bad is the drone with this combo?
Old May 18, 2014 | 09:00 AM
  #1350
Bmurray350z
How does that add up though?
If you can fit the 370z shorty headers and cats on a 350z with 0 problems, why wouldnt you be able to fit the LTHs?
Old May 18, 2014 | 05:20 PM
  #1351
HR.R-CING's Avatar
HR.R-CING
Just wait for Tony to release his LTH from Motordyne.
OHHHHHH MANNNNNNNNNNN.
Old May 18, 2014 | 05:32 PM
  #1352
Bmurray350z
damn, didn't even know they had any in production! but i can confirm this guy is right!!! well, i will definitely be holding out on purchasing PPEs or FIs then.
Attached Thumbnails PPE Longtube Headers-screen-shot-2014-05-18-at-9.31.33-pm.png
Old May 18, 2014 | 05:53 PM
  #1353
Suwaidi's Avatar
Suwaidi
I inquired about LTH's from Motordyne a year or two ago and Tony said there were no plans, wondering if that has changed.
Old May 19, 2014 | 11:47 AM
  #1354
Nabush's Avatar
Nabush
So, for the one who have PPE long tubes, did you take "regular" steel or stainless steel ?
I can't figure what to choose...
Regular Steel : 1485$
Stainless Steel : 1685$
+171$ for the shipping
+ 300-400$ of customs in France
Old May 19, 2014 | 11:54 AM
  #1355
Suwaidi's Avatar
Suwaidi
I chose Stainless Steel with Ceramic Coating because of the environment my car will be in (high temperatures, high humidity). There are several members that have had their mild steel coated headers for years with little issues - refer to post #1292, where there is a bit of rust at the flange and bends. I believe he's had them for 2+ years now.
Old May 19, 2014 | 01:31 PM
  #1356
0jiggy0's Avatar
0jiggy0
I may have missed it, what cams do you have Suwaidi?
Old May 19, 2014 | 02:32 PM
  #1357
Suwaidi's Avatar
Suwaidi
Tomei 264's
Old May 29, 2014 | 12:26 PM
  #1358
Nabush's Avatar
Nabush
Just ordered the PPE Long tube headers for my HR.
I took: parallel merged collector and stainless steel.
Old May 29, 2014 | 12:50 PM
  #1359
vex008's Avatar
vex008
Just curious...Any benefits going with the 370 header vs the 350 spec one?
Old May 29, 2014 | 04:21 PM
  #1360
2004Black350z's Avatar
2004Black350z
Exhaust Whore
My set up makes power all the way to 7500 rpm on a De
