PPE Longtube Headers
Haven't seen anyone running that setup yet, I know the videos on YouTube consist of PPE + S-Tune / Invidia Gemini / Shockwave (Motordyne V1) / Tomei TI / AAM Single. Personally I'd get the PPE's installed before swapping exhausts, that way you'll know how it sounds paired to your current setup. If you swap both at once, you might not like the result.
Just call and talk to Tony or his wife and let them know you want HFC's in the midpipe rather than the standard. It'll cost you a bit extra, but cheaper than if you order the HFC midpipes alone after.
Also, PPE has stopped using Jet Hot and does all their coatings in house now (called Evolution Coatings, I believe it's operated by his brother). No clue about the rust issue though.
Yes and I've had mine the longest out of anyone. I told Paul about it most of the rust is at the flange and the bends.
Anyone with a xyz pipe and nismo s tune?
figure probably not...
So question posed, would the nismo a tune hinder my performance at this point? Or will it suffice for na?
figure probably not... So question posed, would the nismo a tune hinder my performance at this point? Or will it suffice for na?
If you want some video clips I'll post some
Here are some exhaust clips for those interested . Hope the links work on here.
08 350Z fly by PPE headers Nismo exhaust: https://youtu.be/ClsU-O5RwEs
08 350Z bolt ons 95°F 297whp: https://youtu.be/9H261bDX6hA
Saturday Shop shenanigans: https://youtu.be/oUbB30japXk
08 Z start up and idle: https://youtu.be/SpMyCG2l-h8
Haha I'm working on it. Im working on either a 3.5" or 4" intake (I want to keep the strut bar though) with a 2k9 max or 2k6 m45 tb bored out to 80mm into the kinetix velocity intake mani I have. If that doesn't get it I figure some 264s or 272 and a redline of 7200rpm will get me there.
Youre definitely going in the right direction, I've seen some very impressive results coming from those mods. I believe theres a slightly bigger TB that you could use too, slightly smaller than 90mm
The gm 87mm? I've read that, it's just the it some how magically worked thing. I've looked at the voltages on it, and it seems like the pusher motor is way off, but that the ecu can auto compensate. But idk if it's a fluke it worked for fixer, and everyone else would fry their ecu. Or if you just leave the ecu off long enough and it'll fix it.
I'm wondering power-wise if the Invidia Gemini with 60mm (2.36in) piping would be a restriction, especially considering how the headers have a 2.5 exit, but the Invidia is also a true dual design.
Thoughts?
Thoughts?
I posted a thread already [in the tuning sub forum] but to consolidate information heres my cars dyno. PPE with reducer.
**Gains are from the tune ONLY, not stock manifold to PPE.**
Mods: Revup - Motordyne Mrev2, 5/16th spacer, Injen intake, PPE headers with reducer, and custom exhaust (2.5>Burns collector[2.5>3"> cone to 4"]> Vibrant resonator>Borla Xr1)
Tune by Vince at R/T Tuning
.. taken from his other thread.
https://my350z.com/forum/tuning/5930...l#post10376457
