PPE Longtube Headers
Old Oct 3, 2014 | 09:27 AM
  #1381
Classy's Avatar
Classy
Originally Posted by The_Assassin
Oh ur running 370z obx long tubes ?...what gains did u get from them
they were for a 350Z, man, I would have to dig up realllllly old dynos to tell you. I haven't had a 350Z for almost 3 years.
  #1382
travlee's Avatar
travlee
Master
you prob need to retune. i was tuned when i had my art and gemini exhaust, and when i swapped out to the tdx2, i got the codes again.
Old Oct 3, 2014 | 09:53 AM
  #1383
cyc5181's Avatar
cyc5181
Just looking back at my last datalog about a yr ago (I have not made any changes to the car since), at cruising between 60-70mph, the AFR range is mostly between 13-15, with majority of the time in the 14.xx range.
So i guess most of you don't use non-foulers and just plug the rear o2 into the J connector?
Old Oct 3, 2014 | 09:55 AM
  #1384
travlee's Avatar
travlee
Master
were you tuned before the headers though?
edit... i see where you said nothing changed.
  #1385
Classy's Avatar
Classy
wait, you were between 13-15??? That is bad! you should stay at about 12.5 ish for an NA application
Old Oct 3, 2014 | 10:13 AM
  #1386
cyc5181's Avatar
cyc5181
my AFR is in the 12 range when it's WOT. Should cruising (partial throttle) have the same AFR as WOT?
Old Oct 4, 2014 | 03:24 PM
  #1387
0jiggy0's Avatar
0jiggy0
No cruising should be a close to 14.7 as possible
Old Nov 21, 2014 | 10:42 AM
  #1388
Knifey McStabb's Avatar
Knifey McStabb
Question for everybody here. Did you guys diy or pay for the headers to be installed? I have a set of ppe's sitting at home waiting to be hooked up to a stillen y pipe and agency power single. Unfortunately I don't get a whole lot of time off of work and my z is my daily so I cant afford too much down time. I've read a few diy's and I know it's very time consuming and my biggest fear is that I won't be able to finish the install before i need to go back to work but on the other hand there aren't a whole lotta reputable import shops near me.
Last edited by Knifey McStabb; Nov 21, 2014 at 10:43 AM. Reason: I can't spell haha
Old Nov 21, 2014 | 02:16 PM
  #1389
The_Assassin's Avatar
The_Assassin
To diy with long tubes that would take you a very long time.
Old Nov 21, 2014 | 03:23 PM
  #1390
Knifey McStabb
I understand that. Most of the diy's I've seen take 20+ hours total which isn't a completely unreasonable amount of time but it's hard when you only have 2 days off a week and you have a family. I guess the question I should have asked is if I pay for a shop to install the headers is it gonna be worth the amount that a shop is gonna rape me for or should I suck it up, grab some friends, and try to knock it out myself during a weekend?
Old Nov 21, 2014 | 06:00 PM
  #1391
KingBaby's Avatar
KingBaby
Hardest Setting
Not sure how it is stateside but here on Oahu, Hawaiii it's would cost close to a grand in labor...they might even say you have to drop the motor to install causing more time and labor charges!
DIY is easy, once you have all the tools! Tools tools tools....the rest is straight forward.
Old Nov 21, 2014 | 07:32 PM
  #1392
Classy's Avatar
Classy
I would highly suggest DIY. It really isn't that bad, in fact, my second time doing it I did it in about 12 hours.
Old Nov 21, 2014 | 09:29 PM
  #1393
Knifey McStabb
I'll have some r&r when I get home plus I'm gonna take some leave on top of that so I guess after I do all my stuff with the wife and family I'll have to dedicate some time to the car before they start working me like a slave again.
Old Nov 22, 2014 | 10:38 AM
  #1394
KingBaby's Avatar
KingBaby
Hardest Setting
Then start buying your tools!
I'm a family man myself and know the pain in sneaking away to the garage! I've found that preparation helps with jobs since time is short.
Old Nov 23, 2014 | 09:51 PM
  #1395
Blackheart's Avatar
Blackheart
Been seriously considering these PPE longtubes for a while now. So far from all the threads on 06 NA revup engine builds, they make decent gains. I was considering Tomei headers for a while but PPE seems the better way to go.
Old Nov 24, 2014 | 03:27 AM
  #1396
Classy's Avatar
Classy
I hate to **** on the PPE parade, but they make very simular gains that my OBX longtubes made... for $300
Old Nov 24, 2014 | 07:24 AM
  #1397
Conway_160's Avatar
Conway_160
Yes but how is the fittment that is the main problem with OBX "Ebay Exhaust"
Old Nov 24, 2014 | 07:38 AM
  #1398
travlee's Avatar
travlee
Master
a local admin to me has them, he said fitment wasnt the greatest
Old Nov 24, 2014 | 08:25 AM
  #1399
Bmurray350z's Avatar
Bmurray350z
Plus it has a lot more to do with just the headers. A local here switched from obx to ppe and picked up a ton of power throughout the whole powerband.
Old Nov 24, 2014 | 09:16 AM
  #1400
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
There's a reason why the cheap ones are so cheap:
-terrible fitment
-poor welds
-no proper merge collector
