NWP 75mm throttle body
Old Aug 31, 2013 | 06:48 AM
  #181
mw9's Avatar
mw9
Originally Posted by 1cockyZ
I think the upper plenum sucks. So you can put whatever size throttle body you want on it and you will get small changes. It's awesome we have this upgrade available and its so easy to do but it doesn't fix what's right behind it. It seems the FWD vq manifolds are better than the upper plenum nissan put on their sports car. I've read about the maxima guys getting gains with a 4" intake but not Z cars. I would love to swap a Kinetix velocity manifold on this car with the throttle body in place but its out of my hands. Although the new owner of the engine is definitely very engaged about the car.
Is there any proven aftermarket plenums out there?
Old Sep 1, 2013 | 02:41 PM
  #182
2004Black350z's Avatar
2004Black350z
Exhaust Whore
Mw9 shin beats has an Interesting thread on kinetix v+ I think. I bet with that tb and cams you would see huge gains to over 7k plus
Old Sep 1, 2013 | 03:00 PM
  #183
Shin Beats's Avatar
Shin Beats
Its the Velocity manifold not the V+. Big difference between the two!!
Old Sep 3, 2013 | 02:38 PM
  #184
the3kgt2's Avatar
the3kgt2
Placed an order. Will see how it does with a Vortech, built motor, and a tune.
Old Sep 3, 2013 | 07:39 PM
  #185
waldo36's Avatar
waldo36
My guess is you'll lose both HP and TQ. Engine won't be able to handle the extra air flow.
Old Sep 3, 2013 | 07:51 PM
  #186
Pholicious's Avatar
Pholicious
Big Update:
I traded my car and cash for a built 2JZ swapped IS300 550whp@19psi pump gas
Old Sep 3, 2013 | 08:26 PM
  #187
KingBaby's Avatar
KingBaby
Hardest Setting
Sad news...
Old Sep 4, 2013 | 01:21 AM
  #188
2004Black350z
Exhaust Whore
Awesome. Thx for helping out the Z community before you left. ........
Old Sep 4, 2013 | 10:17 AM
  #189
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
I don't ever foresee anyone doing an independent dyno with just this TB as the only change. People are going to tack on other mods and/or tune then claim gains.
Old Sep 4, 2013 | 10:27 AM
  #190
the3kgt2's Avatar
the3kgt2
I don't care about gains before a tune. For all we know the larger throttle body is just leaning out a previously rich tune, making it look like the part is superior instead of it just altering your A/F ratio.
Old Sep 4, 2013 | 10:32 AM
  #191
2004Black350z
Exhaust Whore
Three5 im going to have a independent dyno however wont b 4 like 2 months
Old Sep 4, 2013 | 11:17 AM
  #192
3hree5ive0ero
Retired Admin
^ Sweet. Looking forward to it.
Exactly. Who's to say that your previous tune was spot on or that your new tune won't be done better?
I'd rather have 1 variable than 2.
Old Sep 4, 2013 | 11:44 AM
  #193
1cockyZ's Avatar
1cockyZ
If everyone is waiting for a back to back definitive dyno, its not worth waiting for. The dyno I posted has AFR for both throttle bodies and the timing was untouched. Different days, hot/cold, this is not the silver bullet.
Old Sep 4, 2013 | 11:47 AM
  #194
3hree5ive0ero
Retired Admin
I wouldn't say I'm waiting for a back to back dyno. I was just saying I'd like to see one pop up sometime. I'm not interested in getting this so the existence of said dyno doesn't really affect me.
Old Sep 5, 2013 | 07:45 AM
  #195
str8dum1's Avatar
str8dum1
Exactly, butt dynos lie as is obvious with all the so called "reviews"
Old Sep 6, 2013 | 12:29 AM
  #196
Patty's Avatar
Patty
I'm wondering about the fact, that AFR is changing extremly lean and the gain after the tune is that less. In theorie changing a pipe diameter from 70mm to 75mm gains 30% more flow. When now the engine run lean that goes with the theorie, but the gains after tuning will not.
Interesting, what else is going wrong there.
However, even the 75mm throttle with a 3" single piping in front of is too small for that kind of engine. When you compare the cross sectional areas from the lower plenum runners to the area, what is left through the single pipe section (throttle body & intake system) even a 4" piping equals not the surfaces from the runners. Shows how restrictive the intake of the Z really is and that every opening of this pipe section should show hp gains especially with cams and higher rpm limits.
Patty
Old Sep 6, 2013 | 05:52 AM
  #197
1cockyZ's Avatar
1cockyZ
The intake pipe is flowing continuously, the intake runners are flowing air one at a time.
Old Sep 6, 2013 | 07:03 AM
  #198
Patty's Avatar
Patty
you're right, but under high rpm take care of the pulse frequence @ each runner surging for air. Should be near to a continuous flow.
Old Sep 6, 2013 | 10:50 AM
  #199
Epstein's Avatar
Epstein
Be careful not to directly correlate flow and cross-sectional area. One pipe with 10sq-in will have more mass flow per pressure drop than ten 1sq-in pipes, assuming equal lengths.
The severe leaning out of the AFR after the change is from people tuning fuel incorrectly. Basically, people are actually flowing more air, which is putting them on a new section of the MAF table. Everyone should be tuning on the fuel compensation table and not the MAF table. Tuning on the MAF table is basically turning the ECU into a giant S-AFC. Welcome back to the 90's, guys. A properly calibrated mass-flow system should have already added the appropriate amount of additional fuel to match the additional air.
Old Sep 6, 2013 | 12:19 PM
  #200
DirtyMech.'s Avatar
DirtyMech.
Ding Ding Ding we have a winner!!!!
Soo as results of my tuning was from a starting point of the day 249whp with one pull. Was unsafe to do another. After a lot of fuel added it came to 262whp with the first dyno session of the day. After letting it cool and trying again. We got it up to 264whp. Let it cool again for a longer period. And tried again. Final PEAK number 267.8whp.
The tuner and shop kinda laughed at the 15whp alone. And I had to agree but a bigger carb is a bigger carb. If you know what I mean. Best $300 I ever spent... I'm talking about the tune not the Throttle Body.
