Does Grounding Kit work With Kinetix Plenium?
Old Jun 12, 2004 | 06:05 PM
Shadowrwr's Avatar
Shadowrwr
Question Does Grounding Kit work With Kinetix Plenium?
Hey i was just wondering if my grounding kit will work with the Kinetix plenium? I noticed that the frounding kit attachs to the back of the plenium, but the kinetix plenium isnt metal.
Thanks, -Rich-
Old Jun 12, 2004 | 06:18 PM
ares's Avatar
ares
Veteran
the bolt will conduct for it into the block which is metal.
Old Jun 13, 2004 | 06:54 PM
Shadowrwr's Avatar
Shadowrwr
Ahhh, i should have thought of that one.
thanks, -Rich-
Old Jun 13, 2004 | 11:22 PM
scz's Avatar
scz
The question is does your grounding kit even work? And will you really notice that ~3hp loss? And yes I have one also.
Old Jun 13, 2004 | 11:24 PM
ChuckGZ's Avatar
ChuckGZ
3hp? where'd you get that number?
Old Jun 13, 2004 | 11:28 PM
ChuckGZ's Avatar
ChuckGZ
i always just kinda thought of my grounding kit as a "peace of mind" mod. i know that sounds stupid, but like you said, who sees a difference. it's just since it's there i can go "yep, got that. no stray currents for me".
or, to put it in Adam Sandlerese: "STRAY CURRENT BAAAAADDD!!! GROUNDING KIT GOOOODDD!!!! STOP LOOKING AT ME, SWAN!!!"
...it's been a long night....
Old Jun 14, 2004 | 12:04 AM
12SecZ's Avatar
12SecZ
lol.
I have the new 7 wire grounding kit, I started with 5.
Now when I park my car I ground one wire to an old metal post that goes 12 feet into the earth.
It's a PITA when I go cruising but at least it's grounded when it's home and there aren't any extra currents floating around my car to fade the paint.
Old Jun 14, 2004 | 12:11 AM
AmyCroft's Avatar
AmyCroft
Default Re: Does Grounding Kit work With Kinetix Plenium?
Thanks, -Rich-
Sure add an extra Ground wire from the throttle body to Chassis ground.. Can't hurt..
Chris McCagle.. tried one.. Then located the problem was a V1 crack.. But it can't hurt to have one..
Several people say a aditional ground from Chassis Gnd to AT5 Transmission.. helps overcome noise as the Transmission computer talks with the ECU...
Cheers Amy -
Old Jun 14, 2004 | 07:46 AM
ares's Avatar
ares
Veteran
Originally posted by 12SecZ
lol.
heh, you should drag a peice of copper when you drive, works for blimps. maybe after you do that you can change to 11secZ
Dr.Paulyy
Jul 29, 2019 07:45 AM
OdesiTT
Sep 30, 2015 10:47 AM
cashmoney03
Sep 27, 2015 05:24 PM
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
Shane86
Sep 17, 2015 05:33 PM
