Window Motor Repair (replace motor brushes?)
Old Feb 4, 2007 | 10:57 PM
  #161
jdmz33hellafast's Avatar
jdmz33hellafast
I have been having problems with the driver side. I'm going clean the brushes out and hopefully that works, can't afford new window motor/brushes at this time. I need to get get this done before summer.
Old Feb 27, 2007 | 07:25 PM
  #162
Azn_Empurio's Avatar
Azn_Empurio
damn, my window works fine until i go all the way down, then it wont go back UP
i hear a clicking sound like its trying to go up, but it cant
anyone know what the hell is wrong?
Old Feb 27, 2007 | 09:53 PM
  #163
blasian's Avatar
blasian
Have you tried cleaning the motor brushes? There is a write up towards the beginning of the thread.
I had the same problem... cleaned the motor brushes and haven't had the problem again.
Old Feb 27, 2007 | 10:42 PM
  #164
Azn_Empurio
really? exact same problem?
yea i think i got carbon buildup on mine too, got 46,000miles on this BIRD
im gonna try to find a friend to help me, or go back to the shop and ask them to help me next time when i install my sideskirts
btw how long has it been working fine for now?
Old Feb 28, 2007 | 07:14 AM
  #165
z_brit's Avatar
z_brit
Originally Posted by z_brit
Great thread. I did the clean fix a few weeks ago, but unfortunately crappy motor only lasted a couple of weeks before it died again.
I'm gonna go the autozone route, since these remanufactured versions are apparently meant to rectify all the original design issues and exceed the OEM standard.
So yeah, after cleaning mine, it stopping working again 2 weeks later (this has happened to a lot of people on this thread), I ended up replacing mine with the remanufactured ones that Autozone sells.
Now that I knew how to take apart my door and put it back together (thanks to this thread) it was a lot easier / quicker this time... and now my window works flawlessly.
Old Feb 28, 2007 | 07:19 AM
  #166
blasian's Avatar
blasian
I had the exact same problem... My window wouldn't roll back up and heard the clicking noise.
This happened about 5-6 months ago and its still working flawlessly.
Old Feb 28, 2007 | 10:27 AM
  #167
Azn_Empurio
blasian
cool i told my mechanic were doin this, haha
ill let u know what happens
Old Feb 28, 2007 | 11:41 AM
  #168
blasian's Avatar
blasian
blasian
K cool. Be sure to clean it thoroughly with the q-tips without drowning the motor in alcohol lol.
Like I said, I've done it months ago and its still working perfectly. Good luck dude.
Old Mar 6, 2007 | 12:46 PM
  #169
Road Warrior's Avatar
Road Warrior
subscribing to this thread...mine is starting to go but under warranty.
how long does it take for the DYI cleaning of the motor?
Old Mar 6, 2007 | 02:58 PM
  #170
Integrity's Avatar
Integrity
An hour or two.
Old Mar 6, 2007 | 07:44 PM
  #171
Vamos_Rafael's Avatar
Vamos_Rafael
Originally Posted by Integrity
An hour or two.
time varies with stuff f*cking up or not lol...
like with me (posted pics in earlier threads) window motor wont go back no matter what so...
i'd say from experience if u do it urself...
hook ur laptop next to the car so u can check this thread as u go along...
Old Mar 18, 2007 | 03:52 PM
  #172
chrisnathan's Avatar
chrisnathan
Man, I tried this and end up buying a replacement from Autozone. It didn't work for me. I bought $199.00 and they will give me back the $40.00 for the core.
Old Mar 19, 2007 | 09:21 AM
  #173
Starchecker's Avatar
Starchecker
I just dropped my Roadster off at the dealership, because of leaking around the passenger side window after they reinstalled a new top.
I also have the window going up and then back down using the auto up feature. Did it for a while on the passenger side and now does it on the drivers.
They said I probably need to replace the motors. I am now 4K outside of warranty(only had the car for 2 years though)
I have had the following fixed on my car.
Rear Bearings(both sides) replaced for that gravel sound at 8K
Front Control Arm Replaced at 11K
Tires replaced for feathering issue along with free alignment(of course the problem still isn't fixed)
Window Regulator replaced at 35K
Top Replaced for Common Seam Separation Issue(35K)
CD Player replaced for skipping at 38K(thankfully under warranty - a little grace)
Now Window leaks around new top and wind noise(replaced under warranty)
And now it looks like I haven't escaped the Motor Issue either.
I didn't mind all this crap while they were willing to fix it for free, but $458/motor at the dealership!
I fugure a sports car is like a hot woman - High Maintenance! But dang!
Thanks for the thread guys, if I do end up replacing them, $130 each is a lot better than $450 each!
Old Mar 20, 2007 | 09:23 PM
  #174
chrisnathan
Okay, I got a call from Autozone today, picked them up afterwork. Install is easy since I've been there. So, long story short, replacement motor works great. LIFETIME WARRANTY, can't beat that. $150 is really pain for a window motor, but at least you know you'll never gonna spend anymore on this. Good luck guys...
Old Mar 20, 2007 | 11:23 PM
  #175
flynbrin's Avatar
flynbrin
sticky
Old Mar 21, 2007 | 08:10 AM
  #176
Starchecker
That's great news. Thanks for confirming the Lifetime warranty. Yeah $150 to be set for life isn't that bad of a sacrifice for getting to ride this car.
Old Mar 22, 2007 | 05:26 PM
  #177
Zmoney's Avatar
Zmoney
My 2003 was doing this just out of warranty. When I took it in they said they had to reprogram the computer, cost $100 (prob got F'ed but it worked for 30k miles). Now at 60k miles its doing it again. I also hear a nasty rattle coming from the door. Going to open it up tomorrow and see whats going on in there.
Awesome thread guys!!!
Old Mar 23, 2007 | 08:21 AM
  #178
Zmoney's Avatar
Zmoney
Ok I attempted to do this last night in the garage, not a good idea if you dont have adequate light. On the pass side door I wasnt aware you had to take the "oh ****" handle off so I bent a little of the plastic housing, oh well...
I just got finished taking it apart the correct way, so much easier lol. I the first thing I tried was to reset the regulator and low and behold it worked. My auto up works fine and the window no longer comes down 1/3, whew! They charged me 100 bux to hold the reset switch last time, fockers!...
I also had a really bad rattle that I found to be my cross over for my door speaker. The 2 screws holding it to the door were loose, so I tightened those up. I know we all hate any kind of rattle coming from anywhere, so I killed 2 headaches in one shot. Not only that I am now an expert in removing the door panel lol.
I really want to thank everyone that contributed to this thread to help make all our lives easier, educate us and save us some damn money
Old Apr 15, 2007 | 06:38 PM
  #179
HardRocker's Avatar
HardRocker
Another thank you for the how-to. Passenger side motor working great now that all the carbon gunk has been cleaned out.
Old Apr 16, 2007 | 08:51 AM
  #180
Starchecker
You got lucky. When I had a door rattle(evertime I closed the door) it was the regulator that needed to be replaced. Fortunately under warranty. Funny thing is both my windows are acting up(going 1/3 way down) just outside of warranty. When it gets bad enough I will replace the motors on my own and save the cash and end up with better motors.
