Window Motor Repair (replace motor brushes?)
Old May 2, 2007 | 01:15 PM
  #181
bamyi's Avatar
bamyi
AHhhhhhh crap! My driver motor went out on me again and my passenger won't stay up. It automaticly rolls down a few inches. This all happened in the hail strom yesterday.
With all the time spent cleaning the motor, I wonder if I should just by the 2007 motors from Nissan. Does anyone know if there are less problems between the 2003 and 2007 motors?
Old May 2, 2007 | 01:31 PM
  #182
Integrity's Avatar
Integrity
That's a really good question. Hopefully someone else can chime in with the info cause I'd really like to know myself.
Old May 3, 2007 | 06:43 AM
  #183
Road Warrior's Avatar
Road Warrior
autozone ($150) is probably cheaper than the dealer...and a lifetime warranty.
if you are going to replace the motor this seems the best option imo
Old May 3, 2007 | 02:58 PM
  #184
iNi_REALiZED's Avatar
iNi_REALiZED
This thread ftw! Thanks to everyone that contributed! Worked perfect. My window hasn't been working properly in a !
Old May 9, 2007 | 03:38 PM
  #185
Azn_Empurio's Avatar
Azn_Empurio
god the window motor i bought from performance nissan is faulty, ROFL
i shoulda just bought one from autozone, what a waste of money
Old May 13, 2007 | 05:54 PM
  #186
zxpwr's Avatar
zxpwr
Thanks Everyone! You just saved me over $400!!!
Old Jun 6, 2007 | 07:13 PM
  #187
bender's Avatar
bender
So I decided to tackle my window motor today.
Symptoms:
      So the project took me 2 hours (only because I screwed up). When I cracked open the window motor, there were clunks of black carbon. I used about 20 q-tips and some throttle body cleaner.
      NOTE:
      Here's where I screwed up the first time. If you look down from the top of the door near the tweeter, there's a track for the glass to sandwich in between. It's 2 metal rods going down covered in rubber. When I took took off the metal panel exposing the window motor, the glass had dropped down and moved outside the track. So when I put everything back together, the window would move up, but rub against the door panel and stop half way. I had to take it all apart again and slide it in between the track.
      So anyways, the window has been working at 100% so far. The first thing I noticed is it moved more freely and with less resistance. Hopefully I wont need to take it apart again anytime soon.
      Also, I was at Nissan the other week for something unrelated. They noticed my window wasn't working and said it would cost me $60 for them to just look at it. It's kind of bull**** considering we all know what's wrong with these things. I could only imagine how much they'd charge after replacing the thing.
      Old Jun 10, 2007 | 01:56 PM
        #188
      DRIFTU's Avatar
      DRIFTU
      ok, so my passenger side window was doing the same thing as everyone elses here until it stopped going up and down. After the dealer said i was 1 month out of warranty and would not assit but give me a retarded repair estimate, i ordered a used window motor from a junk yard (I should have check the forums before doing so but...). Anyway, i took apart the whole door panel thing and replaced the motor. It was working great but then when it goes all the way down, it doesnt want to come back up. The "Wack" technique works and that brings it up. I cleaned it out and reset it, but again, if it goes all the way down, it will not go back up unless i wack it.
      I took the junk yard motor out and i cleaned out my original one, tons of crap in there, i installed it and reset it and it went down and went up no problem, but when going up, there would be a lot of resistance, like it just iddnt have any power left in it and it eventually just died.
      I called autozone, $145 + $40 core charge, lifetime warranty, will be here in 3 days.
      Ill keep you guys posted how it works out. This better be the damn last time, screw Nissan and their ****ty *** warranty! can i get a +100!!!
      Old Jun 10, 2007 | 08:52 PM
        #189
      marco_mendoza's Avatar
      marco_mendoza
      Old Jun 10, 2007 | 09:20 PM
        #190
      Escobar's Avatar
      Escobar
      I cleaned mine as well and it seems to be working ok. However it is doing the roll all the way up and then come half was down thing, is there a particular reason why its doing this now?
      Old Jun 11, 2007 | 06:27 AM
        #191
      marco_mendoza
      cuz it's broken. face it guys, you only extended it's life span a couple more times. Time to buy a new one from Autozone, lifetime warranty, and replace it.
      Old Jun 11, 2007 | 07:29 AM
        #192
      tmounk's Avatar
      tmounk
      Another victim of the window problem. Mine has been not been able to come up after it has been down all the way. I tried wacking it and slapping it but no outcome. After some time, it would magically work again. Where on the panel do you guys smack to make it come up again?
      Old Jun 11, 2007 | 09:22 AM
        #193
      marco_mendoza
      Ha ha, right above the window control console. Above the armrest.
      Old Jun 11, 2007 | 11:06 AM
        #194
      tmounk's Avatar
      tmounk
      I keep on smacking, but it doesn't want to *** up......
      Old Jun 11, 2007 | 02:17 PM
        #195
      marco_mendoza
      Your only choice now is to replace it.
      Old Jun 12, 2007 | 07:01 AM
        #196
      Jcolman's Avatar
      Jcolman
      Don't count on replacing your motor and never having to worry about it again. I did the Autozone replacement and nine months later the motor died. Fortunatly Autozone lives up to their "lifetime warranty" and replaced the motor for free.
      The upside is that I'm getting pretty good at replacing the motor.
      Old Jun 12, 2007 | 08:39 AM
        #197
      350fly's Avatar
      350fly
      cant believe it!!!!.. i fixed my window motor by taking it off from the regulator... i open it...and close it.... and it works man!!!! ****in crap these motors!!!!!!!!!!!!!
      Old Jun 12, 2007 | 03:48 PM
        #198
      3hree5ive0ero's Avatar
      3hree5ive0ero
      Retired Admin
      OK, it seems like I did everything that was written in the how-to.
      After I put all the bolts back on, I tried the window switch. My window (which was rolled down all the way before starting) did not come up. I took off the bolts again and saw that I can hear clicks everytime I push down or up on the driver's window switch and the motor gets warm. However, the window does not move at all. What could be the cause of this?
      Don't tell me to reset, since in order to reset, the window needs to be functioning. I already cleaned it, so cleaning won't help, neither.
      Edit -
      I found the solution. You cannot screw in the coil/magnet piece (the one you need to clean) all the way. If you do that, then the motor will not function. You need to just make sure it's in place (in the hole just enough) so the gold cover can be screwed on.
      Old Jun 12, 2007 | 05:14 PM
        #199
      redman333's Avatar
      redman333
      I cleaned mine out and it worked good but after a week it started to malfunction again. I figured it would happen but I was hoping it would last a little longer. Oh, well to autozone I go.
      Old Jun 13, 2007 | 04:15 PM
        #200
      DRIFTU's Avatar
      DRIFTU
      UPDATE!
      My autozone window motor came in and i installed it in 5 minutes thanks to all the experience i have had!
      Anyway, the new motor is working great, manually goes up and down. I messed up on initially resetting it, i held the reset button and put the window up, and then i shut the door and held the reset button and put the window back down. Then i help the reset button again and put the window up, then when i opened the door, the window wouldnt go down the 1/2 inch or so... I should have had the guide with me but i was lazy.
      So anyway, i got the guide and i did it the right way, with the door open, i put the window up, then i shut the door. Then i held the reset button and opened the window. Then i let the reset button go and i closed the window. I opened the door and the window works fine, it comes down the 1/2 inch when i open the door, however, when i shut the door, it goes up the 1/2 inch, and then automatically goes back down!!!
      Also, the automatic opening does not work properly. When i push all the way down, it will not automatically go down. When i push all the way up, instead of going automatically up, it goes automatically down. WTF is wrong with this thing!! The worste thing is that when i close the door with the window being up, it will just go down by itself!
      Any ideas?
