"Service Engine Soon" Light Came On
Old Dec 19, 2002 | 05:41 AM
BigZ's Avatar
BigZ
Default "Service Engine Soon" Light Came On
So... I did a bit of playing last night in the parking lot ... showing a friend how well the VDC and TCS work when doing donuts. He was completely amazed.. and it was a blast.
Several minutes later... I noticed my "Service Engine Soon" light come on. I mentioned it later to my wife and she said: "What did you do... O.K. I don't even want to hear it!"
I hope it was just a sensor issue or just for saftety reasons when the computer recognizes a lot of activity from the VDC controls.
Anyone else see this?
Old Dec 19, 2002 | 05:49 AM
lauderdale75's Avatar
lauderdale75
Well, when that light comes on, the first thing I would do is unscrew the gas cap and rescrew it allowing a couple clicks. This seems to be the most apparent cause of the light, however I don’t see how it would be connected in this case. My service engine light came on recently and the service tech told me that most instances are triggered to a vacuum problem (e.g., improper gas cap fit). Unfortunately in my case, it was connected to a bad valve. In any event, I suggest that you take the car in and have them run a computer diagnostic.
Old Dec 19, 2002 | 05:51 AM
BigZ's Avatar
BigZ
Default Not the gas cap
Thanks,
I filled my tank up after the light came on last night and that didn't solve it. I plan on taking it in and having them hook her up!
Old Dec 19, 2002 | 07:56 AM
jelledge's Avatar
jelledge
Default Electronic Throttle
Some people have reported problems with the electronic throttle position sensor causing this. Seems that the encoder that monitors the throttle butterfly can start to lose its position info and then start giving the ECU bad data.
When ECU detects a problem it will trip the check engine light. The Nissan dealers had to replace the throttle position sensor in these cases.
Old Dec 19, 2002 | 09:00 AM
BigZ's Avatar
BigZ
Default Re: Electronic Throttle
Thanks! Is there anything I would notice performance wise to recognize this may be the cause of the light?
Old Dec 19, 2002 | 09:18 AM
BigZ's Avatar
BigZ
Old Dec 19, 2002 | 09:20 AM
BigZ's Avatar
BigZ
Old Dec 19, 2002 | 09:53 AM
jelledge's Avatar
jelledge
Default Maybe
Really depends on how bad the problem (if that's the problem) is.
In the cases I had read about the position sensor would fail so bad that the ECU went into "Limp" mode and the car lost almost all power.
In any case you need to get the car to the dealer ASAP to find out what is wrong.
loudtoyz
Apr 6, 2023 04:52 AM
Uriyo_
Sep 8, 2021 08:46 AM
Fixxxercask
Nov 9, 2015 11:10 AM
samansharif
Sep 25, 2015 12:31 PM
