Tire FEATHERING: FYI
Old May 8, 2005 | 11:00 AM
  #3461
cpoe52's Avatar
cpoe52
I have had my Good Year Eagle F1 Gs D3's for 7k miles.
I started to notice a slight roar when braking at 5k miles. I couldn't see any front tire wear.
At 7k miles the roar is more noticable. I still don't see any abnormal tire wear.
I run the rears at 37psi and the fronts ar 39psi.
The cupping was much worse with the three sets of Bridgestone Potenza S040's I've gone through at 5k miles.
I am going have the fronts removed from the rims, cross rotated and the front end realigned after a couple thousand more miles.
There are too many things I love about this car! I enjoy driving it every day!!!!
Old May 8, 2005 | 05:04 PM
  #3462
sluggo20031's Avatar
sluggo20031
I had my tires replaced 2 years ago and at 8000 miles now it has 24000 and the tires are still perfect - they aligned the car and tightened the frame back then. Wish you all luck -- it can be fixed
Old May 8, 2005 | 06:39 PM
  #3463
Pit Bull's Avatar
Pit Bull
Can you explain the "tightened the frame" what do you mean by that? The Z doesn't have a "frame" so I am sure you are refering to something else. Thanks
Old May 8, 2005 | 09:37 PM
  #3464
03FIDDYZ's Avatar
03FIDDYZ
My car doenst have feathering on it, do some people get lucky...or did the guy i just bought it from change the tires recently????
Old May 10, 2005 | 07:27 PM
  #3465
poseidon's Avatar
poseidon
IS the tire feathering issue solved\? What tires do you recommend
Old May 11, 2005 | 04:31 AM
  #3466
ChinaClipper's Avatar
ChinaClipper
No - you should keep your car regularly aligned to prevent the onset of feathering. Tire choice will not solve or prevent feathering, but certain tires will help delay feathering by virtue of the design of their inboard tread ribs. (Hence the redesign of the RE040).
Old May 11, 2005 | 06:19 AM
  #3467
Pit Bull's Avatar
Pit Bull
REdesign my butt, I just had two new fronts installed by Nissan and they are the same as the RE040's that came on my Z in 2003. Aren't I the lucky one.
Old May 16, 2005 | 06:47 PM
  #3468
BigNDFW's Avatar
BigNDFW
Take it back and demand the new Re040's... its the only chance you have of being satisfied...
Old May 23, 2005 | 09:18 AM
  #3469
ernie's Avatar
ernie
i was going to get a Z(probably an 03) but this tire feathering issue is making me think about it twice. has the issue been solved???
Old May 23, 2005 | 11:09 AM
  #3470
BigNDFW's Avatar
BigNDFW
Yes it has. I now have 22K on my front tires and expect to get at least another 6-8 K out of them before they are worn out. Smooth wear all the way across the tread...
Old May 23, 2005 | 12:39 PM
  #3471
Satchel's Avatar
Satchel
It sure hasn't been resolved for me. In fact they completely turned their back on me.
Old May 23, 2005 | 01:57 PM
  #3472
Pit Bull's Avatar
Pit Bull
Can you give us your alignment spec's?
Old May 23, 2005 | 02:50 PM
  #3473
bwilliams's Avatar
bwilliams
I too have resolved tire feathering on my 03' Perf.
After 36k miles of tire feather frustrations, dealer installed the 3rd set (new RE040) and aligned. I immediately went to an independent shop to "check" the alignment. It was way off! The independent set my alignment to these numbers. I've re-checked the alignment twice since then...it's holding to the numbers.
At 53k (17k on these tires), wear is even with no noise. Handling is about 90% as sharp as it was before.
total toe, 0.09 degrees
L. Camber, -0.8 degrees
R. Camber, -0.9 degrees
L. Caster, 8.5 degrees
R. Caster, 9.1 degrees
Old May 23, 2005 | 06:17 PM
  #3474
bunker's Avatar
bunker
Originally Posted by smarms
Are these 05 z's?
I bought a new touring in Feb 04 and experienced feathering at 6k. My friend had an 03 and and also had the feathering. We both traded in Aug of 04. I want an 05 and may get one when I return from the desert provided the feathering problem has been fixed. I can not get a reliable straight answer out of the dealer as to whether the problem has been corrected on the 05s. I guess I will wait and observe this site and try and talk with owners of 05s.
V/r
Bueno
Old May 23, 2005 | 06:42 PM
  #3475
BigNDFW's Avatar
BigNDFW
From Pit Bull:
__________________
Chrome Touring with Frost leather and Aero package
Sure..
L. Camber -1.1
R. Camber -0.8
L. Caster 8.5
R. Caster 8.4
Total Toe 0.09
Last edited by BigNDFW; May 23, 2005 at 06:44 PM. Reason: Left Out question from Pit Bull
Old May 23, 2005 | 08:22 PM
  #3476
ernie's Avatar
ernie
it seems that your alignment specs are different?!
Old May 23, 2005 | 10:24 PM
  #3477
AmyCroft's Avatar
AmyCroft
Default Hi Pit Bull - Specs
Big NDFW wrote:
From Pit Bull:
__________________
Sure..
L. Camber -1.1
R. Camber -0.8
L. Caster 8.5
R. Caster 8.4
Total Toe 0.09
These are partial specs... and don't say weather in Inches or Degrees...
I assume ( Spank Me ) the 0.09 Total toe is on the Front... or something
between 1/32" and 1/16" total toe - Why not have both front and Back
Specifications?
Cheers Amy -
Old May 24, 2005 | 05:13 AM
  #3478
cal_z's Avatar
cal_z
This Thread is longer than lots of books that I have read. WOW
Old May 24, 2005 | 06:08 AM
  #3479
fuzzwart's Avatar
fuzzwart
Well, that's because the problem has existed since the '03s came out and it still hasn't been fixed. I think that the jury is still out on the '05s but I am predicting that it will surface in those also.
I have been struggling with the problem on my '03 and am ready for a third set of front tires. Unfortunately, since mine is over 24 months old, NNA has turned a blind eye and my only recourse is to write the NNA executive offices. Of course, with the pedning class-action litigation I look for no relief from Nissan.
BTW, I only have 16.5K miles on the car. It is safe to say at this point that this, my third Nissan, will be my last.
Old May 24, 2005 | 07:54 AM
  #3480
DAYTONA-ZED's Avatar
DAYTONA-ZED
"if" the problem on the 05's was fixed then what was the supposed fix??? different tire design? different suspension setup?
unlike you this is my first nissan, but like you this will be my last.
