Tire FEATHERING: FYI
Old Jan 8, 2004 | 07:27 PM
  #1901
BROKE's Avatar
BROKE
Originally posted by bkusnir
Wow... I am actually impressed with my dealer for once. It only took them 4 days to order and receive a set of replacement Bridgestone Potenza 040's for me. We'll see how it works out.
Did they agree to replace all 4 or just the 2 fronts?
Old Jan 8, 2004 | 08:22 PM
  #1902
Boomer's Avatar
Boomer
Default Re: Had the TSB done - roar comes back
Originally posted by waldf
Just an FYI for some of the posts I have seen asking if the tire swap side to side and realignment works: I had this done at about 9000 miles. I am now on 17,000 and the roar is back in full force. The car sounds like a 4x4 - it slowly developed again just as it did in the first place.
I didn't expect any differently, but I have seen some optimistic souls who seemed to think rotation and realignment will fix this. It won't, is my experience.
I do have a question for this forum though: on the pessimistic assumption this this ain't going to be fixed by Nissan, do you think a tire with a different tread pattern would help? I was thinking it may wear differently and not roar (or at least not so much).
Get rid of the OE tires and get a Hunter re-alignment after install, the tires are lousy and prone to very rapid wear if your alignment is off. If your dealer doesn't have a Hunter alignment machine, go to someone who does.
Old Jan 8, 2004 | 10:46 PM
  #1903
farleez's Avatar
farleez
Hehe. Sounds like you need the help. Anyway, I already filed a lemon law claim and won. I guess you could say I am over it. Good luck.
Originally posted by overZealous
Outstanding work farleez! I believe we can now all put this year old 95 page thread to rest based entirely upon your words of wisdom. Have you contacted Nissan? They may want to include your verbage in their latest technical service bulletin. "If the customer complains of excessive tire noise then you are to tell them your that their car is f--ked and they should 'get over it'". Works for me. Of course you better be prepared to live by your own advice as they are all basically f--cked. Notice how many new guys are posting in this thread with one or two posts and feathered tires to their credit. Unfortunately one can't just run out and file a lemon law suit. They will need to eat up at least three sets of tires before a suit can even be filed and in some States where the period to file a claim is one year or less they may never have the opportunity. And even if they do bring the suit then Nissan will make a final repair attempt and replace all four tires with ones with an extremely hard compound and the owner will have to wear those out as well to prove that the repair attempt didn't work. Or Nissan could save us alot of aggravation and just fix it. Since they have not I guess we'll be keeping this thread around just a bit longer. If I may offer just one small peice of advice...for the people who suffer from a compulsive need to tell other people what to do...your f--ked. Get over it. Seek psychological help.
Old Jan 9, 2004 | 05:24 AM
  #1904
wskelton's Avatar
wskelton
Farleez,
Can you take me through your process? I am starting the LL process in Texas as well. Any advice is appreciated!
Old Jan 9, 2004 | 05:27 AM
  #1905
overZealous's Avatar
overZealous
I could say that you are over it but since you won your case and you are still here I would probably be wrong. So what was the outcome if you don't mind sharing? Did you get a buy back or a replacement vehicle?
Old Jan 9, 2004 | 05:51 AM
  #1906
kbsig106's Avatar
kbsig106
Default Got my Z back yesterday after Final LL repair
Nissan has certified that my Z has been completely repaired under the State of Florida LL process. So here's the run down:
The dealership called me yesterday afternoon to infrom me the required repairs were completed and she ran down the work order w/ me. Here's what was reported (I'll scan the actual report tonight):
1) Check for vibration in rear of vehicle. NNA rep test drove and found cupping on the rear tires. Replace rear tires with OEM. Ok'd by C. Smith
2) Check for customer hears single knock from right front when going from park to reverse while wheel is turned. NNA rep found a internal failure with the right front compression rod. Rod was first replaced on 8/23/03 - needs to be replaced again. Good at this time. Ok'd by C. Smith
3) Check for vehicle pulls to right and steering wheel is off center. NNA rep found excessive play. Completed alignment. Inspected by C. Smith - ok'd
So folks - that's it. I have my Z back. So here's my impressions even though my left wrist is broken (in a cast). The Z seems to be tight and she's drving straight for the time being. The wheel hop is gone and my steering wheel is straight - but the damn rattle from the rear view mirror is all of a sudden here. The true test will be in about 6 months if the problems resurface.
Since this was the "final" repair - if the same problems resurface, NNA does not have the option for another "final" repair. We pretty much go staright to settlement per BBB and Attorney General. This can happen any time between now and 1/25/05. So I have 12 months to figure out if he problem returns. I have new rubber on the front and the back (about 700 miles apart in age). So, the road noise should come back (cupping) if the rapairs do not hold up.
I've had (2) compression arms and (4) alignment's and (4) new tires since 1/25/03. Totally unacceptable if you ask me - this isn't a "abused" car.
I'm going to scan the alignment spec's and post them tomorrow.
Good luck and I'll keep everyone posted.
Old Jan 9, 2004 | 06:35 AM
  #1907
Vestas's Avatar
Vestas
Add my name to the list of folks who have the feathering problem. Bought the Car in August 2003, 18,000 miles on it and tire roar is very loud. However the problem only really developed in the last 3,000 miles.
I travel a great deal for work, I bought the car in NJ, live in NY and currently work in Washington D.C. So no clue which lemon law I'd apply to even if I was within it's particular limits (think NJ has a the 12,000 mile/1yr rule).
That said, the dealer down here is excellent. I reported the problem, he determined it was this issue, ordered new front tires even though the TSB says to just swap 'em and they have 18k miles on 'em, will give the tires to me for free and do the alignment. Sadly the tires are not in (probably on backorder) yet so I sit and wait, with tire roar.
I love the Z, I have very minor window grease issues (took months for any appreciable grease to show up). Cleaned the windows and the grease has not come back. The only other issue I've had is that my passenger side in-dash cup holder is a bit sticky (doesn't snap open when you push it) and that the rear view mirror plastic molding rattles (solved by squeezing it tight again).
Honestly if I my problem is such that every 20,000 miles or so I'll need new front tires and an alignment, that's about what I expected for a perf car (note: the tread wear on the rest of the tire has plenty of life left on it, just the inside edge shows serious feathering). However I'm worried that aftert his tsb "fix" the tires will wear sooner (now that the problem has surfaced).
What's not clear to me on this thread or through the rest of the board (I lurk obsessively) is if aftermarket tires and/or suspension really solve the problem or not. SOme folks say it does but I have yet to see credible proof (i.e. someone who HAD the problem, had the TSB done, got the problem back (proving the issue is not fixed by the TSB) then got new tires OR a new suspension and after another 10-20k miles the problem has not resurfaced).
Old Jan 9, 2004 | 06:49 AM
  #1908
grifferjr's Avatar
grifferjr
from what i understand the tire itself plays some fault in this also. granted most of the blame is with nissan and the setup of the car, but the OG bridgestones were way too soft of a tire. I have heard some other people say that other cars with this tire have some similar issues, granted not to the extent of the 350Z. that is why when my dealer gave me new "shoes" at 15k we put a harder compound tire. worked out decent for me cause being in ohio and winter setting in it was an all weather version. as far as the suspension i have that same question. does the nismo-s suspension solve this issue. (oh yeah, the harder tire thing was and still is a guess cause i am not quite yet to 1000 miles on the new ones but to date my wheel is dead straight and absolute min drift to right, mainly on the slope of the road. so we will see).
Old Jan 9, 2004 | 06:57 AM
  #1909
ezchief's Avatar
ezchief
Griffer,
Which brand and type of tire? Do you know the UTOQ rating?
Old Jan 9, 2004 | 07:57 AM
  #1910
grifferjr's Avatar
grifferjr
Originally posted by ezchief
Griffer,
the ones they gave me free were still bridgestone potenzas but they were the all weather, not the v rated which were the softy ones on the original. as far as the details i can get to that at another time, i am at work and cant check on that right now. I think when i have to change these out i am going with another brand all together, and maybe even harder compound.
this was the choice of tire because of the supposed "fix" that was going to come in january of this year, which I am beginning to get skepitcal on. if you read some of my past posts, my dealer told me that they were informed from nissan of a possible recall in the next month or two and the tires were going to be these. needless to say i am not holding my breath.
Old Jan 9, 2004 | 08:14 AM
  #1911
wayne55's Avatar
wayne55
Default New Zs still having these problems?
Hello there:
I ordered my 350Z T Roadster toward the end of December. It should be in around March. How likely is it that I’ll have these same issues? Is Nissan Actually still producing cars that have a know problem? That seems a little strange. I guess sales are still up. Any info would be appreciated.
Thanks
Nagle
Old Jan 9, 2004 | 08:26 AM
  #1912
wskelton's Avatar
wskelton
It seems to be related to early productions. The NNA representative I regularly talk with indicated it was due to a "shipping problem" not sure how reliable this information.
Old Jan 9, 2004 | 09:09 AM
  #1913
kbsig106's Avatar
kbsig106
Default Build Date
My build date was 12/02 and I thought the problems had been fixed by then.... Nope
Old Jan 9, 2004 | 11:50 AM
  #1914
ezchief's Avatar
ezchief
Check if they are the REO 92 All Weather. I believe they are 220 rated. Tire Rack does not show a size to fit the rear 17" wheels. I can see NNA having this be the fix and realize "Oops, no match for the rears. Well who cares, put the 040's on the rear!"
Old Jan 9, 2004 | 12:14 PM
  #1915
ezchief's Avatar
ezchief
I just went to Tire Rack and checked on the RE 92 High Performance All-Weather Tire. When I replaced my 17" tires a few months back, I did a thorough search of all types of tires to put on. All season's and Summer High Performace tires. From Michelin to Bridgestone to Kumho and all in between. The RE 92 had been put on my car as front replacements with out my knowledge. Take them or wait months they said. I did a search on Tire Rack and was shocked at the reviews. Also, at that time they did not have the 235/50/17 for the rear wheels. I am certain of this because when the rears wore out, that is when I had to go out and get 4 new tires.
This is long winded to get to this point but, guess what? Now they have the 17" size for rear tires on Tire Rack. However, they do not have the 18" sizes. The tire is V rated (149 MPH) and has shi++y reviews. MY experience is they suck big time. They are 160 UTOQ rated.
I hope this is not the anticipated fix but it is coincidental.
Old Jan 9, 2004 | 05:20 PM
  #1916
bkusnir's Avatar
bkusnir
I believe I was told just the front tires, although what's the point of having front tires with less mileage than the rear tires? I don't want to be buying two tires at a time. I guess I will tell my service advisor that I was under the assumption that a 'set' of tires is all 4 tires. Might as well ride this pig out, I guess I will have to wait and see when I have them put on next Tuesday. I am very curious to see how the W Rated Michelin Pilot series would wear on the vehicle ... but for $1,100 I'll wait.
Old Jan 9, 2004 | 05:43 PM
  #1917
BlueDragonZ's Avatar
BlueDragonZ
Originally posted by johnwoo
this thread and the tire feathering issue is what is keeping me from purchasing a z. hearing all of the horror stories and the need to drop money on a problem that nissan needs to fix is really turning me off to this car.
what do you guys suggest if you could do over again about purchasing a z? does an aftermarket suspension system such as the tein basic or nismo really cure the tire feathering? i really do not understand why nissan has not stepped up to the plate on this with a recall.
thanks for your replies.
You know regardless of the problems that I've had with my Z I would most certainly do it all over again. I love my Z and I'm sure that whatever problems that will come my way I'll get it fixed and keep the BIG SMILE on my face every time I'm driving.
Old Jan 10, 2004 | 04:48 AM
  #1918
ChinaClipper's Avatar
ChinaClipper
Thumbs up Completely agree!
I am with you BlueDragonZ. I definitely would do it all over again! Despite having to solve the tire problem, I just LOVE this car! 28,400 miles so far and still going!
Old Jan 10, 2004 | 07:06 AM
  #1919
mrice's Avatar
mrice
Default Re: Completely agree!
same here
Old Jan 10, 2004 | 01:42 PM
  #1920
BIGSHOT's Avatar
BIGSHOT
sounds quite terrible & hopeless. I have only 5500 mi on a pre ordered Enthus. Z I recieved Sept 02..the wear problem is starting & dealer says the alignment will cure the problem. Unfortunatley the cupping is now started on the outside edge also...sure would like to get to the bottom so i can upgrade wheels & Tires. The 19" ers are sure expensive to replace evry 5kmi
