Tire FEATHERING: FYI
Originally posted by Pit Bull
Steve, I hope you enjoy the G35. Don't understand your warranty problems. Your Z only has 11K miles on it and everything but the brake job and new tires is covered under warranty. With 11K miles I would try and get free new front tires if it is the feathering tire issue. Also if the rotors need replacement I would also try and get them replaced under warranty. I'm married too and I understand that you used all of these reasons to convince your wife that you needed the G35
But Steve your talkin to car guys now and that BS won't float.
But Steve your talkin to car guys now and that BS won't float. 1) Not possible, 2) "It doesn't have a back seat???" (Her Day 1 comment on the Z)
Like I said, lots of reasons, not all have anything to do with the car directly...things change.
Originally posted by Boomer
PB, I'm afraid while I've been playing w/myself, waiting for the Konis to save my Z, I've also strayed from the purer path. There is a G35 Coupe with all the options I would want at the local Infinity dealer right now.
The Z is a bargain at its price but not if I should have to dump money into new springs/shocks and who knows what else...I'm all for upgrades, but usually wait until the first set has some real wear on them...good luck!
Then, what's your time worth? I'm cutting my losses and walking before I go from losing next to no $$$ to $10k or more in a year due to depreciation and or low resale value due to crap like this tire issue.
Originally posted by SteveZ
Well, there is one point there Boomer - why should you have to spend money replacing a new suspension (I say new as in about a year), buying new tires because the first set puked due to some mystery problem...you get my point.
Time is very important to me and I value it highly as I grow older, if I were not retired, the Z would have been sold long ago, but I have only 7880 miles on it and it is still holding its value in kbb and Edmunds, so I will continue to wait for the Konis. I too, have another car as well. I am not waiting patiently, however.
Originally posted by grifferjr
through talking to nissanusa and my case manager that i got involved with, there is some decent talk/rumor of a recall in january.
Originally posted by bkusnir
I can confirm this, as this was told to me by a very reliable source from within NNA which I cannot disclose. They told me that their WILL be a fix in January, and they WILL NOT leave their customers behind.
thanks for the follow-up. that makes me feel better that i was not the only one to have heard this. I am very new at dealing professionally about personally owned vehicles, being in my mid-twenties, and its nice to know that i was not given a run-around or a quick answer because i might be a little "green around the edges", all which i have heard from other dealers in the past when dealing on cars. every time which i have walked away.
I second that Boomer.
PS- My tranny just went out and is being replaced. 23k miles and started buzzing like a bee hive. I hear they are on the 4th gen tranny now. And they are replacing my clutch pedal. Why? I do not know.
Anyone?
Anyone?
What did the Nissan engineers have to say about your car? Did they comment on the extra toe in you are running?
They told me my tires were normal -- meaning massive heel - toe wear is expected at 6000 miles.....
Basically, a waste of time as far as input goes. Hopefully the output from the inspection goes as good as some here are stating. I left my car while I went to work. The techs were gone when I picked it up in the evening. The write up said the toe was in spec and tires are normal. The end. Hope the data helped them with a fix.
Anyone?
Anyone?
https://my350z.com/forum/showthread....8&pagenumber=3
No one really knows why the clutch pedal assembly is being replaced. But, the latest news is that it's not being replaced anymore. Check out:
https://my350z.com/forum/showthr...38&pagenumber=3
__________________
Yeah and most likely it will be cancelled prior to the install anyway.
Thanks
__________________
Thanks
ok,
regarding the purported "fix" that is coming in January...just for clarification - this is an expected NNA fix for the front end alignment tire feathering problem? and if so, how do ya'll think being offerred this 'fix' will be impacted by our having aftermarket tires & wheels? Is there anything to be concerned about...that we won't be eligible or something?
Maybe I answer my own question...that it's a suspension/vehicle problem, not a tire or wheel problem, so aftremarket rubber/rims is not relevant.
__________________
Thanks
__________________
Thanks
Mechanical noises like that which slowly get louder and more vibration usually don't go away. W/o any pride, I have had dead transmissions on other cars, usually either cooked the main shaft bearings (Altima), lost synchros (Ford), or lost just one gear (5-speed in a Turbo Capri). If anything, a transmission properly maintained should be just as quiet as new with fresh fluid at 11k - it was not.
Ok thought I'd post again on the Feathering thing. Went to the Dealership for my second set of front tires. It's getting me kindof upset now. I guess I'll just get my tire change at every oil change. It seems the Dealership is getting furstrated with Nissan because of all the return for getting new tires. Damit NISSAN HOOK IT UP!!!!
Just got back from Christmas in NYC.... 5 new pages - wow!!
Any ways - I'm 6 days away from turning in my Z for the final repair. I received my FedEx letter and I'm ready to go. My Z is in full bloom with her problems. So I'll report back on Monday after I turn her in - I hope I'm able to take the Tech for a "ride" before they give me a loaner car. The Tech has 10 days to fix the car (till the 15th)....
So I guess we'll see....
cheers!
cheers!
I hope you guys are right....but my synical side tells me otherwise.
I can hear it now. NNA 1/21/04 Press Release
All Nissan owners and techs are morons. No one in the USA can align a car properly. Nissan sent out Japanese techs to inspect hundreds of cars and came to this conclusion. American's are fat, lazy, improper toe setting slugs. We take back the armistice and declare war on you slugs. If you can re-open Iraq, we can re-open the South Pacific.
For questions, please call NNA. They too are slugs. In fact, we are closing that office. Direct calls to Carlos Ghosn, that great French man who loves cheese and wine. All hail Carlos.
Man I have gotten synical.
Too much time on your hands!
I certainly hope both of you are correct. Many of us have waited over a YEAR for a fix.
I talked to the Service Manager at my dealership. He has been very upfront with me throughout this totally horrible experience. I mentioned to him that there seems to be strong rumors of a fix for the feathering problem. He acknowledged that he too had talked to the folks at corporate and said there was nothing new. I hope your right and he is wrong!!!!
Lew
