ses light and wont go away
Old Feb 8, 2006 | 11:22 AM
faster than u's Avatar
faster than u
Default ses light and wont go away
my car is is pretty much stock but when i changed the spark plugs i put the sensors in the wrong place which caused the ses light. i had autozone remove it 2 times and it keeps comming back, Its a cylinder miss fire code , why cant i just clear the code, the car drives fine there is no cylinder miss fire
Old Feb 8, 2006 | 11:32 AM
Ztalker's Avatar
Ztalker
what kind of spark plugs you replaced with...have you tried disconnecting the battery overnight to reset?
Old Feb 8, 2006 | 03:31 PM
DavesZ#3's Avatar
DavesZ#3
Put what sensors in the wrong place? Maybe you fried something in the coil pack(s)?
Old Feb 8, 2006 | 04:42 PM
dscheers's Avatar
dscheers
Default Reset the ECU
ECU Resetting Procedures
Timing is extremely critical. If it is NOT DONE within the specify time, the ECU will not reset and the Check Engine Light (CEL) will continue to remain ON.
A stop watch or an analog clock with a second’s needle will be useful.
Operations Procedures
1. Confirm that accelerator pedal is fully released, turn ignition switch “ON” and wait 3 seconds.
2. Repeat the following steps (2a and 2b) procedures quickly five times within 5 seconds.
2a. Fully depress the accelerator pedal (HARD).
2b. Fully release the accelerator pedal.
3. Wait 7 seconds, fully depress the accelerator pedal and keep it for approx. 10 seconds until the CEL starts blinking.
4. Fully release the accelerator pedal (while the CEL is still blinking)
5. Wait about 10 second.
6. Fully depress the accelerator pedal and keep it for more than 10 seconds.
7. Fully release the accelerator pedal (The CEL light will continue to blink).
8. Turn ignition switch to “OFF” position and now you can start the car. The CEL light should be gone.
If the CEL light continues to remain ON, repeat the above steps. Timing is EXTREMELY critical to resetting the ECU
From the TecnoSquare website
Old Feb 8, 2006 | 06:39 PM
faster than u
1 step colder plugs for nitrous , i dont see how i could have fried the coil pack, wouldnt that make the car not run right, and that resetting is a bunch of bs, i have not disconnected it over night but i did do it for a while, i think it will still come back on
WTF!!!!!!!!!!!!
Old Feb 8, 2006 | 10:12 PM
bacalhau16's Avatar
bacalhau16
ya you would know if the coil pack was really gone, because you would have cylinder misfire that was noticeable. If its not noticeable its just your car being dumb because you switched the sensors. If nothing is truly wrong, wont the code just clear itself after driving around for a while?
Old Feb 9, 2006 | 11:17 AM
faster than u
damn it wont go away and i cant take it to nissan cause i have test pipes on my car
Old Feb 9, 2006 | 11:18 AM
faster than u
i want to put the cats back on but there a pain in the a$$
Old Feb 9, 2006 | 11:59 AM
blasian's Avatar
blasian
I brought my Z in with test pipes on to get some work done recently.
Old Feb 9, 2006 | 09:06 PM
bacalhau16's Avatar
bacalhau16
ya you could always bring your car to nissan, and say you need service. They may not notice that your car has test pipes, and if they do, your test pipes arnt the mod that messed up your car, so they really cant say much. Its the same as them denying a warranty because of an exhaust!
Old Feb 11, 2006 | 10:30 AM
faster than u
well im willing to take the risk cause i need a new tranny and i dont want any crap
Old Feb 11, 2006 | 01:53 PM
PapaTango's Avatar
PapaTango
You're worried about taking your car to the dealer for the transmission because you have test pipes? WTF do you think they're gonna say when they see your nitrous setup?? I guarantee you a truckload of woe trying to get the transmission replaced once the dealer discovers that little modification.
Old Feb 11, 2006 | 01:56 PM
faster than u
oh the nitrous is out , ive had it out for like 2 weeks now
loudtoyz
Apr 6, 2023 04:52 AM
Uriyo_
Sep 8, 2021 08:46 AM
350z82
Oct 1, 2015 06:25 PM
Sleeper_Z
Sep 30, 2015 10:25 AM
samansharif
Sep 25, 2015 12:31 PM
