dash lights for abs are all on
my abs, vdc, ive got it all on, and the dealer tried tellin me that it was tire pressure sensors and b/c of my after market wheels they broke and that is causing the lights if i pay them the 132 dollars to get new ones then the problem will go away does this make sense??
no. the tps one looks weird. like a tire deflating (_) <sidewall bulging due to lack of air
on the far left gauge in the center dash, itll show you the tire pressures, now if you see dashes instead of numbers, then your sensors are bad,dead, or not installed
oh i know bout that, but what could cause my abs, and vdc lights and stuff to come on, right now i have no abs or traction control, i havent pushed the car to the limit of the abs engaging or vdc kicking in and if i have then it def is not working, ive tried resetting the ecu but disconnecting the battery but no deal, this is the same thing that happens to me when I go on a dyno and the lights stay on for a bit but then turn off, but they havent turned off in forever, dont know whats goin on and it bothers me b/c it makes my car like everytime i get into it feel like its broken with all these lights on in my dash
#1 check your brake fluid.
#2 check your speed sensors.
It is 9 out of 10 times one of those 2
Also remember the SEARCH function is your friend.
https://my350z.com/forum/showthread....hlight=abs+tcs
haha yea if it was something that simple i dont think i would have chimed in. No somethings seriously wrong with my car. theres a grinding noise coming from the rear at low speeds.
yea thats another one my brake light is on also, so i have no tcs nothing right now and it sux, wish their was someone i could tak it too to get rid of this problem with out getting overcharged
