TSB: Clunk Noise Question with pics.. - Warning Large Pics Inside
Old Jun 29, 2006 | 12:41 PM
KuNGF00Chris's Avatar
KuNGF00Chris
Default TSB: Clunk Noise Question with pics.. - Warning Large Pics Inside
Hey guys,
I recently bought my Z and herd a strange clunk noise from the front suspension when backing out and down a slope and sometimes in other conditions. Anyways, did a search and found the TSB for the upper link bolts.
I jacked up the Z and and looked at what I thought I had to loosen one turn and re-tighten. I am unable to get my torque wrench with the correct socket on the bolts.
Here is a picture of both tires. I have circled the bolts I thought the TSB pointed to. What is the trick here?
Drivers Side:
Passenger Side:
Thanks
-- Chris S.
Old Jun 30, 2006 | 07:20 PM
Netko350Z's Avatar
Netko350Z
take your tire off
buy a different torque wrench?
Old Jul 12, 2006 | 02:51 PM
Rog1206's Avatar
Rog1206
I've had the same problem for 7 months now and it started after I installed the Cusco sways. I thought it was the swaybar bushings not be lubed enough but after taking the sways off and lubing the bushings, the noise was still there. I noticed that it only comes from the front passenger side when one wheel is higher than the other, such as driving on uneven roads or pulling into sloped parking lots entrances. It sounds more like high pitched clicks instead of clunks. I couldn't even get a torque wrench in there so I still have that noise.
Old Jul 12, 2006 | 04:00 PM
KuNGF00Chris
Yeah, even with the tire removed the torque wrench I have just wouldn't fit. So I just grabbed the wrench of the same size and just tightened it myself a little more. I hardly applied any pressure, but that seemed to do the trick. No more clunking noise....
I think it was a 14mm if I remember corretly...
-- Chris
Old Jul 12, 2006 | 06:53 PM
Rog1206's Avatar
Rog1206
Tried that and it still makes noises. Maybe mine is coming from somewhere else.
Old Jul 13, 2006 | 08:53 AM
VO...'s Avatar
VO...
Administrator
The ball joint in the middle was defective on my 03 model. They had to replace it.
Old Jul 13, 2006 | 08:59 AM
bmac03z's Avatar
bmac03z
I just used a swivel to torque mine.
Old Jul 13, 2006 | 09:00 AM
Rog1206's Avatar
Rog1206
Are you talking about the big one that sits right underneath the knuckle? I've already replaced that along with the knuckle itself since they are one peice and mine was torn up pretty bad. I tightened the nut that connects the endlink to what I think is the lower control arm last night and the noise seems to have gone away.
416blueZ
Jun 11, 2024 10:56 AM
issyz
Jul 2, 2017 03:04 PM
Justin100
Nov 29, 2015 03:58 PM
kyin
Oct 15, 2015 05:54 AM
416blueZ
Sep 24, 2015 02:11 PM
