Motul brake fluid
Old Jul 21, 2006 | 04:24 PM
Raceism's Avatar
Raceism
Default Motul brake fluid
wsup fellas!! I own '03 350z Track. I plan on changing rotors and pads next weekend. Any suggestions for brake fluid?? I heard Motul brake fluid is pretty good. But i don't know which one to get. My Z is completely stock.
please provide me with some feed backs on Motul or other brake fluid suggestions.
Thanks!!
Old Jul 21, 2006 | 05:04 PM
DavesZ#3's Avatar
DavesZ#3
Motul (RBF600) is what people are using when they track their's Zs. It's expensive and probably a bit of overkill for the street.
I'm using Valvoline Synpower brake fluid. It has a higher wet and dry boiling points than the "normal" brands. More than sufficient for street and occasional autocrossing.
Search the Motorsport->Autocross/Road forum for "brake fluid" and you'll find all kinds of threads discussing high performance brake fluids like Motul.
Old Jul 21, 2006 | 06:32 PM
Mike Wazowski's Avatar
Mike Wazowski
I use ATE Super Blue Brake Fluid. No complaints.
Old Jul 21, 2006 | 07:15 PM
Fluid1's Avatar
Fluid1
Check this out:
https://my350z.com/forum/autocross-road/204761-scary-brake-fade-failure.html
and this:
https://my350z.com/forum/autocross-road/205150-450-for-brake-pads-feeling-a-little-ill.html
Old Jul 21, 2006 | 07:16 PM
DavesZ#3's Avatar
DavesZ#3
Another great choice. That's what I wanted to go with but couldn't find any locally. It's what I'll use next time.
Old Jul 21, 2006 | 07:58 PM
Tekwon-V's Avatar
Tekwon-V
Elf Frelub 650. well, i cant recommend it yet. bottles are sitting in my room haha. price is good and i wanted to try it.
i got it from greg @ mossy.
Old Jul 21, 2006 | 08:26 PM
Mike Wazowski
ELF make quality products. I used to run their oil before switching to Royal Purple.
Old Jul 22, 2006 | 12:44 AM
sillyhenwee's Avatar
sillyhenwee
those who have used ate super blue how often do you have to flush? once a year? or depends on how aggressive you use the brakes? i ideally would like to not bleed the brakes as often
Old Jul 22, 2006 | 05:19 AM
DavesZ#3's Avatar
DavesZ#3
If you're doing normal street driving, then replacing the fluid annually is more than enough. If you talking about taking the car on the track, then depending on how often and how hard it's going to be driven, your replacement time may vary from every 6 months to as often as before each event.
Old Jul 23, 2006 | 02:55 PM
Raceism's Avatar
Raceism
thx for all the info's and feed backs!!!!
Old Sep 12, 2006 | 09:26 AM
Spoiled Z's Avatar
Spoiled Z
Valvoline Synpower brake fluid is synthetic isn't it? I thought the manual says not to use synthetic brake fluid.. hmmmm
Old Sep 12, 2006 | 09:28 AM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Really? Where?
It says to use DOT3, but I don't see where it says not to use syn
Old Sep 12, 2006 | 02:12 PM
Spoiled Z's Avatar
Spoiled Z
Originally Posted by Wired 24/7
Really? Where?
Let me think I think its on page 8-13 or 8-14 Yeah I almost bought synthetic brake fluid last night. But it says in the manual not to use synthetic.
Old Sep 12, 2006 | 02:46 PM
DavesZ#3's Avatar
DavesZ#3
Synthetic means different things. You can't use DOT 5 brake fluid, which is a synthetic silicone based brake fluid. Synpower is DOT 4 and is a synthetic glycol based fluid. It's the silicone that kills the rubber seals in our brake systems, not the fact that it's "synthetic". Motul is a DOT 5.1 which is acceptable too.
Old Sep 12, 2006 | 03:05 PM
corsair's Avatar
corsair
ATE Super Blue.
+1
lapham3
Oct 7, 2022 03:15 PM
samansharif
Sep 25, 2015 12:31 PM
