tried to replace belt and...
Old Jan 20, 2007 | 04:21 PM
andyisphat2004's Avatar
andyisphat2004
Default tried to replace belt and...
i tried to replace my airconditioner belt, but i couldnt break the nuts on the pulleys loose at all. I think they are a little corroded due to salt here in HI. anyone have any ideas?
Old Jan 20, 2007 | 04:24 PM
Sean's Avatar
Sean
wd-40 or any penatrating oil
break free is a great brand
Old Jan 20, 2007 | 04:29 PM
andyisphat2004
i actually tried a little bit of wd40 and nothing.
Old Jan 20, 2007 | 07:34 PM
Ztalker's Avatar
Ztalker
they all come loose with the right tool and leverage.
Old Jan 20, 2007 | 07:36 PM
rotaryrocket7's Avatar
rotaryrocket7
I don't have the car in my garage right now, but what size are the bolts? If they're pretty big try a breaker bar. If you can't budge it with that try alot of wd-40 and than heat it up. If no of that works, and you don;t have access to a air gun find a way to extend your socket or wrench by putting a klonger hollow metal tube over it, thereby extending your leverage. DO THIS LAST, you run the chance of actually breaking the bolt. It's pretty unlikely it would break, but I;ve broken one in the past so not impossible. Then you;re stuck drilling it out, not fun!
Good luck
Old Jan 20, 2007 | 07:58 PM
andyisphat2004
i think the problem is getting leverage and countertorque on the nut becuase of the position. there is not very much room between the pulley and the fans. i am going to try again tomorrow though
Old Jan 20, 2007 | 09:45 PM
Ztalker's Avatar
Ztalker
i've removed those belts to install the underdrive pulley before. There is enough room to loosen those bolts. No WD40 was required in my case. yes, a breaker bar comes handy.
Old Jan 20, 2007 | 11:49 PM
andyisphat2004
like i said before, i am sure there is more salt on the road in hawaii than in cali, =corrosion= nuts dont move.
Old Jan 23, 2007 | 02:34 PM
VO...'s Avatar
VO...
Administrator
+1 on the breaker bar.
Old Jan 23, 2007 | 02:38 PM
teh215's Avatar
teh215
Never used WD-40 for this but, I have used Liquid Wrench with a good bit of success.
Rev_Night
Nov 7, 2020 06:00 PM
Fixxxercask
Nov 9, 2015 11:10 AM
350z82
Oct 1, 2015 06:25 PM
