So I'm driving along today and the shifter slips out of the gate...
Old Mar 4, 2007 | 09:06 PM
GalvatronType_R's Avatar
GalvatronType_R
Question So I'm driving along today and the shifter slips out of the gate...
[Yes, I did do a search, without any success, my problem seems to be unique]
As the title states, I'm having a minor transmission problem. I was driving today and while I was in 6th cruising along, my hand was on the shifter, my foot was 100% off the clutch, and the shifter shifted out of the gate into neutral (again, without the clutch engaged AT ALL). Puzzled, I went to an empty parking lot and tried doing the same with gears 1-5, all with the same result: the shifter leaving the gate going into neutral without using the clutch whatsoever (I could not shift back into gear without using the clutch, though).
This should be covered under the powertrain warranty, I have an 03 with only 43k miles on it but before I go to the dealer, what could be the source of this issue? What are the chances of getting a new slushbox? Furthermore, will the dealership provide me with a loaner car during repair/replacement?
Before anyone asks, I did not do any tranny mods, no new clutch, flywheel, shift ****, boot, short throw rod, etc.
Old Mar 4, 2007 | 09:15 PM
ZSpectrum's Avatar
ZSpectrum
isnt it supposed to be able to do this?
Old Mar 4, 2007 | 09:16 PM
harrieyu's Avatar
harrieyu
dude....theres nothing wrong with your car ahHAh just dont try to engage gears without the clutch...
Old Mar 4, 2007 | 09:28 PM
plumpzz's Avatar
plumpzz
at lower RPMs it should be easy to let it pop out of gear w/o the clutch. Try in higher RPM's while accelerating. It won't happen.
Old Mar 5, 2007 | 06:00 AM
THE TECH's Avatar
THE TECH
Wait...you shifted it without using the clutch OR it shifted by itself?
If you are in the correct RPM range, you can shift without using the clutch.
Old Mar 5, 2007 | 06:26 AM
dmroberson's Avatar
dmroberson
If the shifter moved out of the gate by itself, then there's something wrong. If you moved it yourself, then it's fine.
Old Mar 5, 2007 | 06:55 AM
zzz350's Avatar
zzz350
operator error!
Old Mar 5, 2007 | 06:59 AM
jimmyloose's Avatar
jimmyloose
My old 318i had shot synchros, I could shift w/o the clutch all day.
Old Mar 5, 2007 | 07:59 AM
Ztalker's Avatar
Ztalker
something is definitely wrong if it jumps out of gear by itself while engaged.
Old Mar 5, 2007 | 09:11 AM
GalvatronType_R
Sorry, I wasn't clear, the stick did not come out of the gate by itself, my hand was on it and I exerted a little pressure on it towards neutral (again, without using the clutch at all) and it left the gate to go to neutral.
I've driven many other manual trannys (including my last car) and none of them did this. Still, I guess it doesn't hurt to take it to the dealer and have them look at it, all under the powertrain warranty.
Old Mar 5, 2007 | 09:35 AM
MarlboroMan's Avatar
MarlboroMan
+1, it's fine.
Old Mar 5, 2007 | 05:09 PM
julian's Avatar
julian
when there isn't any load on the trans gears you can shift out of gear without using the clutch.
to engage a gear without using the clutch the engine rpms have to match shaft speed perfectly.
Obadabot
Jun 18, 2023 11:31 PM
loudtoyz
Apr 6, 2023 04:52 AM
350Z_Al
Oct 29, 2020 07:44 PM
Mattg350z
Oct 2, 2015 06:51 AM
