Post oil change oil pressure
Old Jul 31, 2007 | 11:33 AM
Lenski's Avatar
Lenski
Default Post oil change oil pressure
So I changed my oil this weekend for the first time (Mobil 1 5w30), and I am noticing higher oil pressure both at idle when warm and under throttle. Even at like 3500 RPM its pegged on 120 psi. I looked around a bit and found a few similar comments, but no consensus. Anyone else observe the same thing.
Car is an '07 by the way.
Old Jul 31, 2007 | 11:35 AM
VO...'s Avatar
VO...
Administrator
Have you check your dipstick to see how high your oil level is?
Old Jul 31, 2007 | 12:58 PM
Lenski's Avatar
Lenski
Yes no problems there...
Old Jul 31, 2007 | 01:43 PM
usmanasif's Avatar
usmanasif
That is a known issue with Mobil1 in the VQ; I have seen many threads on that. Change to another brand and you'll be fine.
Old Aug 6, 2007 | 09:27 AM
VeeTec's Avatar
VeeTec
Mobil 1 5W30, reading up to 120 lbs under full throttle, after oil change, by 3,500 rpms.
The oil level is spot on, so I assume this oil just puts the pressure up a bit too high. I will probably drain it and go with another brand.
Old Aug 6, 2007 | 09:30 AM
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
Mine also did the same thing with Penzoil Platnum Synthetic 5w30. Oil level was fine. I believe this is normal and there is nothing to worry about. Synthetic flows better and the sensors might be a bit more sensitive for dino oil.
Old Aug 6, 2007 | 11:38 AM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
It will be fine... high oil pressure then the engine is cold is ok, but it's best not to push your car to the limit until it's fully warmed up.
Keep in mind, your oil will still be "cold" (i.e. not fully warmed up) long after your temperature gauge reaches normal operating temperature (middle of the gauge)
and cold oil always shows higher oil pressure.
fresh oil changes usually show higher oil pressure as well.
Old Aug 6, 2007 | 01:42 PM
Lenski's Avatar
Lenski
Got it. I appreciate the reassurance / guidance guys...
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
