Sputtering During Warm-up
Old Oct 22, 2009 | 03:04 PM
  #361
diablo25mn's Avatar
diablo25mn
Same exact problem, and I was the one that started this thread. I have 55k bought on the car and it was purchased in early 07. Does it everyday. I actually start my day with 20-30 min cruise at 2.5k every morning... (commute)
Old Oct 22, 2009 | 03:11 PM
  #362
bapestah's Avatar
bapestah
I'd light my car on fire if it made me wake up 30 minutes earlier everyday Imo 5 mins of sputtering is better than 30 wasted
Old Oct 22, 2009 | 03:18 PM
  #363
diablo25mn's Avatar
diablo25mn
You're right thats why I drive it over 2k every morning by the time I get off the highway and drive in the streets I don't notice it.
Its when its out of that routine that you get reminded...
Old Oct 22, 2009 | 04:01 PM
  #364
warmmilk's Avatar
warmmilk
our drivetrain warranty goes to 60k, this is the drivetrain. you should take it to the dealer. they shouldn't have any problems reproducing it since it happens every cold start. although you may have to leave it there overnight...
Old Oct 23, 2009 | 09:35 AM
  #365
bapestah's Avatar
bapestah
Lmao, if only it were that easy ...............
Old Oct 23, 2009 | 10:57 AM
  #366
uglyduc's Avatar
uglyduc
hmm, havent noticed this problem in my 08, but after seeing the vid at least I know what to look for.
For the record, I dont think it's possible to fit the MAF sensors backwards, I've tried the screws don't line up.
I'm running ingen longtubes, HFC, bassani dualies, and an uprev tune.
Ive run Mobil1 15-30, 0-30, Castrol euro 0-40.
Put everything from Arco 87 to Chevron 91
Old Oct 25, 2009 | 04:40 PM
  #367
uglyduc's Avatar
uglyduc
Quick follow up, tried reproducing this during cold, warm and op temp with valero 91 in the tank. Was not able to reproduce.
Old Oct 26, 2009 | 10:51 PM
  #368
stylett9's Avatar
stylett9
consider yourself very fortunate.
Old Oct 28, 2009 | 01:02 AM
  #369
dirtbikr's Avatar
dirtbikr
Just wanted to let you guys know I just started getting this. 2007 auto with 36k on the clock. I let it warm up for about 2 or 3 minutes, then by the time i get to the first stoplight out of my community (usually the first stop, takes about a minute and a half to two minutes) it surges right at 1800 RPMS and then it does it at the next light about 30 seconds away. Then i get down to the third light which is about a two minute drive and it's gone by then. Just started getting colder here, and I originally thought it was the tranny, but definitely not anymore. Glad I found out it's not just me... but it is slightly annoying. Does it whenever there's a full cold start. I'll try the holding the RPMS in neutral next time, very curious now.
Old Oct 28, 2009 | 05:00 AM
  #370
Tac-M's Avatar
Tac-M
if you keep the revs around that 1500-1800 area wile it is glitching, they will bounce up and down for a few minutes and might throw a " misfire " code...
Old Oct 28, 2009 | 01:32 PM
  #371
dirtbikr's Avatar
dirtbikr
I tried it this morning and there was definitely something funny when it his the 1750 RPM line, it would hold for a second or two, drop down, then go back up. I found thought that my takeoff glitch isn't really caused by that though, although it's extremely similar. When I take off in the morning it's rarely over 1400 RPMS just because I'm easy on it. The sharp stab at the throttle is more to blame for me I think, although I do completely notice the glitch at around 1700 RPMS. I'll data log it and see. What sensors should i include to get a good feeling for it? TPS, MAF, RPMS, and...? load? I dunno. This is weird
Old Oct 28, 2009 | 09:38 PM
  #372
stylett9's Avatar
stylett9
I'm willing to bet your take off glitch is the aftermath of the initial sputter. I noticed that after it bounces around 1700 RPM, at around 1100-1200 with every gear change it will glitch once. If you feather the clutch you can feel and hear the engine pulse.
After the initial bounce around 1700, if you are just parked and you tap your throttle, and pay attention closely, you will see and feel the pulse down low at 1100 also. Don't necessarily have to be driving.
Old Oct 28, 2009 | 11:23 PM
  #373
dirtbikr's Avatar
dirtbikr
Well I'll be honest, I'm just extremely glad it's not my transmission. I never wanted an auto but didn't have a choice in the end, and I've had nothing but trouble with them in the past. And since others have this and their cars are fine, i'll take it as a glitch and get used to it until something is figured out. One other thing I noticed is it started happening within the time period of about three fill ups after i ran out of my additive that I put in all my vehicles. I add 1.5oz per fill up of yamaha ring free additive just from my experiences with it on boats and dirtbikes. I'm going to buy another bottle and go through a couple fill ups and see if that helps. Kind of like the Heet thing, but a different package. This stuff is made under Chevron and is literally just their techron additive super - thick. It literally pours slow We'll see, if not then oh well, it is what it is. Powertrain warranty ftw.
Old Dec 15, 2009 | 12:31 PM
  #374
GSXRChino's Avatar
GSXRChino
*Sputtering ONLY at idle (whether at first startup, during warmup, after warmup, cold startup, no-cold startup, etc.)
*No sputtering during driving
*2003 Manual Enthusiast w/ AEM Intake
*93 Exxon gas w/ 5W30 Mobile Extended Performance
-I highly doubt that it is an oil issue...My thing is it feels like there is an ARC in the Spark Plug Wires if the car had them...I cleaned the Throttle Body one time and it helped and started coming back slowly...I've changed fuel to Chevron once and didn't do a thing
Old Dec 16, 2009 | 07:02 PM
  #375
Tac-M's Avatar
Tac-M
^ not the same problem.
Old Mar 2, 2010 | 10:27 AM
  #376
Zian's Avatar
Zian
I'm aware that this is a revival, but I may be in a position to help. My 07 has 26000 miles and has had the original problem (stuttering between 1700 and 2200 RPM with light, even throttle input when the vehicle is cold) for probably the last 9k miles.
I am currently sitting in the service department of Performance Nissan, and I successfully replicated the issue for the tech this morning. I have had the vehicle in 3 times for this problem, and what I did this morning was make an appt for 7am, show up at 5:30am and pop the hood to let the vehicle cool off.
For those with the problem, this was an effective method of replicating it.
I will post here when I get more information. Hopefully we can get some resolution after all.
Old Mar 3, 2010 | 09:29 PM
  #377
stylett9's Avatar
stylett9
I took my car to Performance atleast 4 or 5 times. They blamed it on me not knowing how to clutch... Tell them to look up the service records for Michael Hoang, 07 white Z
Old Mar 10, 2010 | 10:55 PM
  #378
stylett9's Avatar
stylett9
so what was the outcome?
Old Mar 15, 2010 | 11:34 PM
  #379
whoisthis's Avatar
whoisthis
i think this thread is old but since this is a big issue, i'll revive this thread lol
If the throttle body or throttle position sensor is the problem then can't you either just replace those with OEM parts or get aftermarket intake?
Old Mar 25, 2010 | 09:25 AM
  #380
bapestah's Avatar
bapestah
Holy thread revival batman!
The throttle components haven't been confirmed as the problem so that's why we can't just swap them. Plus, for those of us that are under warranty and have taken it to a dealer the same response is inevitable: "You just don't know how to shift/clutch/drive." >_>
