Sputtering During Warm-up
Old Aug 27, 2011 | 11:04 AM
  #641
GERRY#1's Avatar
GERRY#1
Hi Guys.
Just a big thank you to everyone who contributed to the spluttering during warm up problem!
Changed my oil to Shell 5w40 and problem solved.
Thanks again.
G
Old Aug 27, 2011 | 05:38 PM
  #642
srsairbags's Avatar
srsairbags
Question
Originally Posted by GERRY#1
Hi Guys.
Thanks again.
G
how are the oil pressure reads ? is it stuck at high ?
Old Aug 28, 2011 | 12:25 PM
  #643
GERRY#1's Avatar
GERRY#1
Nope, oil pressure is at about 3 at idle and fluctuates with revs as you drive.
Old Aug 28, 2011 | 12:56 PM
  #644
srsairbags's Avatar
srsairbags
thanks G . . . gonna try Mobil1 5w40 and see if that helps
Old Aug 29, 2011 | 03:51 PM
  #645
SE5spd's Avatar
SE5spd
Originally Posted by srsairbags
let us know, how it goes
will do, hopefully they find something
Old Aug 30, 2011 | 06:45 AM
  #646
Rudiger's Avatar
Rudiger
I have the same issue:
- 07' 350 Z HR with roughly 50000 km. The issue began after 15000 km driven.
- Few little jerks when starting with cold engine in the range of 1500-2100 rpm or...
- The same but followed by just one hard jerk (same conditions, same range), then it runs smooth.
Using Mobil1 5-50.
Old Aug 30, 2011 | 10:59 AM
  #647
FastGreg's Avatar
FastGreg
Using Mobil1 5-50.
Swap to Mobil 1 0W40 New Life, or other oil with a density less than 0,85, and let us know!
Old Aug 30, 2011 | 10:52 PM
  #648
Rudiger's Avatar
Rudiger
I'll do it in the next maintenance service, in September...
What about swap to the original factory oil?
Anybody know what its density is?
Regards,
Old Sep 2, 2011 | 08:01 PM
  #649
singh's Avatar
singh
_______________
i've used castrol 0w30, 5w30, and mobil 0w40
i've had sputtering problems with all of the above
Old Sep 2, 2011 | 11:54 PM
  #650
midz350's Avatar
midz350
Anyone running the Haltech EMS? do you still have this problem?
Old Sep 4, 2011 | 10:29 AM
  #651
SE5spd's Avatar
SE5spd
People with haltech = ballin'
Old Sep 4, 2011 | 10:11 PM
  #652
Rudiger's Avatar
Rudiger
D'oh!
Old Sep 4, 2011 | 10:30 PM
  #653
midz350's Avatar
midz350
I don't know if you read my old posts, but my car used to sputter most of the time like crazy. But it stopped completely right after installing the Haltech.
If you have a Haltech or Osiris tuner and your car sputter please PM me. There are couple things that I want to try .
Old Sep 5, 2011 | 05:00 AM
  #654
mw9's Avatar
mw9
I think I have figured mine out, coil pack was going bad. Kept moving the coil pack around and followed the codes, wherever I moved the bad coil pack, the codes seemed to follow. Car has 110,000 miles on it
Old Sep 5, 2011 | 01:16 PM
  #655
SE5spd's Avatar
SE5spd
I know but ive also red your other threads and you = baller! lol
I PMd you!
Old Sep 5, 2011 | 05:58 PM
  #656
srsairbags's Avatar
srsairbags
same here . . . changed to 5w30 and 0w30 of many brands and sputter is still there
Old Sep 5, 2011 | 09:15 PM
  #657
midz350's Avatar
midz350
I PMd you!
And I'm regretting all of that.
PMed you back.
Old Sep 6, 2011 | 11:05 AM
  #658
FastGreg's Avatar
FastGreg
Did you try to change the solenoïd, I guess it's the last issue
Old Sep 7, 2011 | 07:29 AM
  #659
srsairbags's Avatar
srsairbags
no . . . didnt even think about it . . ( isnt that like 1500$ or more ?) was hoping to disable vct using uprev for low temps
Old Sep 7, 2011 | 09:38 AM
  #660
FastGreg's Avatar
FastGreg
140 bugs, really easy to change: http://www.courtesyparts.com/kb_search_result.php?keywords=[23796]+\%28z33&cPath=714_715_716_725[/URL]
Just try to disconnect the exhaust one, and test if sputter still there.
