Front end alignment
Old May 11, 2008 | 02:55 PM
z4tess's Avatar
z4tess
Default Front end alignment
Not sure where to post this so I thought I would post here also along with brakes/suspension.
I bought my wife a new '07 Touring model last year.The car is stock with 14,000 miles.
The car is used for commuting and has not hit curbs,pot holes,etc-.The tire pressure has been maintained.
The front tires have abnormal wear on the inside like the camber is off.
Has anyone with a newer model have this issue?I know it was a problem with the 2003/4 models.
I will be very p----- if the dealer tells me that this is not covered.I think the problem was there when we dorve it off the lot.
Thanks,Kurt.
Old May 11, 2008 | 03:21 PM
DavesZ#3's Avatar
DavesZ#3
It's probably not the camber but the toe setting. That was the cause of the infamous tire feathering on the 03/04 models. I've had mine set and 18 months later found it to be WAY out. I'm getting mine checked/redone at a minimum of once a year, maybe even twice.
Old May 12, 2008 | 12:12 AM
BRONZEE's Avatar
BRONZEE
Club Moderator
Twice is a good move. Also pays every time you pump up your tyres, just to have a look at the tyres, looking at wear, and any other annomalies.
Old May 12, 2008 | 04:56 AM
I would like to see close-up photos of the inside edge of the tire.
Old May 12, 2008 | 09:53 AM
Master Shake's Avatar
Master Shake
I had tire feathering on my 2005 -- so it's not just a 2003/2004 issue. Getting the alignment done properly seems to have resolved the issue on the new tires. I have a feeling that some Nissan dealerships (as well as other shops) might still be using the old alignment specs.
Old May 20, 2008 | 12:30 AM
jimC's Avatar
jimC
Just noticed yesterday that my tires are wearing on the outside, almost down to the wear indictors at the outside edge. Since the car has barely over 3,000 miles on it that is real bad. Anybody else have wear on the outside instead of the inside?
Old May 20, 2008 | 02:47 PM
Search “feathering.” Its a top-10 subject here. Maybe with a photo I can judge feathering from plain vanilla inside tire wear.
Old May 20, 2008 | 02:50 PM
Guess its not that important.
Old May 20, 2008 | 08:43 PM
BRONZEE's Avatar
BRONZEE
Club Moderator
How many alignments has your 2007 had since you've purchased it? Some alignment shops aren't good either, if that's the case take it to a good specialist shop that comes highly recommended.
Old May 28, 2012 | 06:27 AM
gwnguy's Avatar
gwnguy
Default 350z there is no front camber adjustment
Finally after talking to two Nissan dealers (who didn't feel the need for an alignment machine) and discussing the issue with Nissan Care canada. Two people I spoke to there didn't know what camber was! They referred me back to the dealers who didn't seem to have a clue. Do these auto makers have secret things they don't share with the public about the quality of their vehicles ..... why do they need to be sued as Nissan was to come clean???
The original response I got from them was that the tire wear was not covered under warranty and I would have to speak to the tire company. DUH!!!
I promised I would research and get back to her with the answer. Her second answer was all WRONG .... the wheels are not adjustable for camber as she told me. The last time I spoke with Jennifer she finally relented and said the part WAS NOT ADJUSTABLE and I would have to purchase aftermarket parts to correct the problem.https://my350z.com/forum/images/smilies/mad.gif
Obadabot
Jun 18, 2023 11:31 PM
Pleask
Dec 21, 2021 03:17 PM
Depravity
Oct 1, 2015 04:49 PM
