How-To Repair Stuck / Broken Window Motor ...
Old Jun 27, 2009 | 07:45 AM
  #221
freefallin's Avatar
freefallin
Vo - Thanks a ton for posting this. Saved me 400 bucks that the dealer quoted for a new window motor!
Old Jun 28, 2009 | 02:23 PM
  #222
AcidJake75's Avatar
AcidJake75
Living in 350Z
Just did mine and it works like a champ now. i hope it lasts longer than 2-3 months which is what is usually lasts.. It was easy too.. screw stealership prices..
Old Jul 1, 2009 | 07:32 AM
  #223
StreetOC192's Avatar
StreetOC192
VO, thanks a ton man!!!!! Just did mine as well.
My window was down last night when the skies opened up and I couldn't roll the passenger side window up. The inside of my car is soaked.
I followed your instructions here, except obviously my window was in the down position. It was easy getting it apart, but I had to roll the window up a little bit in order to lift up on it to get the track to line up with the panel when reassembling.
Old Jul 3, 2009 | 02:38 PM
  #224
Nismokingz33's Avatar
Nismokingz33
So I did this to my window motor and one of the brushes is not making contact with the internal spinning part. So I put it all together and it dosnt work at all now I tried punching the door pannel but I got nothing could the brush be the reAson why?
Old Jul 11, 2009 | 02:43 PM
  #225
kof0127's Avatar
kof0127
Great job, vo7848. this DIY save many Z members so much money, I am one of them, just did that today. $200 for part, and 1 to 2 hours worth of labor, freak that, by following this DIY and clear the dirt off the motor, then save me around $300, this is the $#!+.
Old Jul 24, 2009 | 09:43 AM
  #226
Zquicksilver's Avatar
Zquicksilver
Originally Posted by vo7848
Yup, I was pretty disgusted at how gunked up it was also...
SB! i'm back and using this DIY tutorial... drivers side finally quite on me.
not bad... 104k on the OD
Zquicksilver
Old Jul 26, 2009 | 05:45 PM
  #227
stereoneeds's Avatar
stereoneeds
im one of the few whose problem wasn't fixed by doing this. when i push up or down on the window button, nothing happens, and when i let go i hear a "click" coming from the passenger's side window control in the armrest. has anyone else had this problem? is my motor shot?
Old Jul 26, 2009 | 09:27 PM
  #228
LVZ053's Avatar
LVZ053
I had the same clicking sound and the DIY fixed it
Old Jul 27, 2009 | 05:27 AM
  #229
ajw101's Avatar
ajw101
Will brake cleaner work instead of that electronics cleaner? I'm thinking it will, and that will save me a trip to the store... Anyone experienced with this?
Old Jul 27, 2009 | 11:23 AM
  #230
stereoneeds
after having this not work i thought it might have been due to the fact that i did not clean the part thorough enough. so today i sanded it and cleaned it with a needle. it looked much different than the first time i cleaned it. but i ended up with the same results. so its time to get a new one i guess. is autozone the best place to pick one up, or does anyone have anywhere better?
Old Jul 27, 2009 | 03:07 PM
  #231
Zquicksilver
^ advance auto cost $10 less and in my area they could get them in 3-days.
THANKS OP, this "fix" worked out great!!
And to Izzeing... Your suggestion were spot on, except for the jewelers screw driver on the back of the carbon contact. I popped one of the contacts out and it was insane trying to put it back in... those contacts will crumble under any type of pressure, just a warning to others. I suggest the steps you mentioned, but pushing on the back of the actual spring is better. It will also prevent you from pushing the contact out of the motor casing.
I'll post pics soon... I just set the inner metal panel on my rocker and against my seat while I worked on things. I also removed the motor completly from the door, its easy to do.
Zquicksilver
Old Jul 31, 2009 | 07:15 PM
  #232
tnk210's Avatar
tnk210
My passenger motor went out again. I ordered a refurbished one from Autozone and got cracking on it today. Installed everything and went for the test. The window rolled down then died. It sounded like crap. I banged it a few times and it unrelentesly moved a few inches before totally stopping. Dammit.
I opened up the refurb motor and one of the brushes is completely stuck inside. While I was at it I went ahead and opened up my old motor again. Have it some more cleaning and then attached it to the power. Viola. The old one sounded new again. I didn't install it back yet as I want to see if I can get a new one from Autozone for my troubles.
Old Aug 4, 2009 | 01:07 PM
  #233
VO...'s Avatar
VO...
Administrator
Wow, haven't check this thread in a couple months. Glad I could help all you guys out!
Old Aug 6, 2009 | 02:46 PM
  #234
350z-bra's Avatar
350z-bra
thank you soooo much for writing this thread up.. the pics helped a bunch, my motor had been crapping out on me on and off for about 2 months, and it finally got stuck DOWN so i went ahead and cleaned the motor.. now it works great!! thanks you saved me like 300 bucks!! since it was stuck down, i couldnt use duct tape, but some how everything worked out
Old Aug 7, 2009 | 06:21 AM
  #235
DFW 350G's Avatar
DFW 350G
It sounds like no matter what, this is only a temporary fix. Replace OR clean.....its gonna fail again . Does anyone know if a window motor from another Nissan product would work (and not just for a short time) ???
Old Aug 11, 2009 | 07:27 AM
  #236
VO...'s Avatar
VO...
Administrator
Yes, the cleaning was a temp fix. I ended up replacing it with a refurbished one from Advanced Auto Parts. It's been awhile now. It still works great...
Old Aug 12, 2009 | 06:58 AM
  #237
GT-Z's Avatar
GT-Z
Just did mine. works great now thanks!!!!!!
Old Aug 13, 2009 | 11:01 AM
  #238
35oZephyR's Avatar
35oZephyR
*sigh*
After cleaning it once, the window worked for awhile until it completely crapped out on me. Must be something with the brushes.
Old Aug 22, 2009 | 11:09 AM
  #239
SILKZ03's Avatar
SILKZ03
Wow...guess I better get started. Tired of banging on the Door...people see ya...kinda embarassing.
Old Aug 22, 2009 | 11:32 PM
  #240
350z-bra's Avatar
350z-bra
yea my window is starting to sh*t out on me again, so i guess ill just have to swap out the motor..
it was a good temp. fix though..
