How-To Repair Stuck / Broken Window Motor ...
Old Feb 24, 2010 | 11:14 AM
  #281
VO...'s Avatar
VO...
Administrator
Originally Posted by Tokyo Mike
vo7848, Thanks for this write up!! I just did the cleaning method today and seems ok for now. I'm broke so can't be buying a motor yet. Hopefully last for at least a year. It took my about 2 1\2 hrs tho. Some of you guys did it pretty quick. Anyways, thanks again.
Old Feb 27, 2010 | 03:45 PM
  #282
SmoothZ's Avatar
SmoothZ
Senior Super Moderator
I cleaned out my motor about 5 times last year. Each time the motor would last about 2 weeks before another cleaning had to be done. I finally gave up and will have to buy a refurbished motor from Advance.
What sucks is I have a 2002 Dodge Caravan with no problems on any interior electrical parts. It's got 81k miles on it.
My 2003 Z has 43k and I've had to replace one window motor under warranty and now this driver side is no longer working. Whoever designed the motor needs a can of whoopass opened on him or her.
Old Feb 27, 2010 | 04:42 PM
  #283
35oZephyR's Avatar
35oZephyR
+1, I wouldn't mind strapping them up to a pole and pegging them to death with broken window motors.
Summer is coming up soon and my window is already going to shiet. Even if you clean the motor or replace with another one, this flawed component eventually fails.
Old Mar 9, 2010 | 02:59 PM
  #284
Flick Montana's Avatar
Flick Montana
I just wanted to add that if anyone is buying a window motor from Auto Parts Warehouse, you can get 15% off if it is over $150 by using the code TRACK15 or if you get a cheaper refurbished part you can use the code AFFCJP5 for $5 off. Not much, but $5 is $5. Both codes worked as of the date of this post.
Old Mar 26, 2010 | 05:56 PM
  #285
SmoothZ's Avatar
SmoothZ
Well, I finally gave in and bought a new motor. VO, mine wasn't near as dirty as yours but dirty enough. I took apart the old motor last night and cleaned it out just to see the contacts.
As you can see, after I cleaned it out with the CRC cleaner, it looked like some corrosion on one of the contacts.
The other side was much cleaner and sprung back easier.
Anyway, I figured a newer motor was the way to go. Just finished installing it and got it to work after I figured out that I needed to reset the window motor. Success!
Old Apr 24, 2010 | 09:00 AM
  #286
ZKansasZ's Avatar
ZKansasZ
Well, I just replaced the motor again today.
So I want to say THANK YOU again to Vo for making this thread!
one concern, though:
Everytime you open the door, the window slide down just a bit, right?
But I notice that it slide down a way more than the original one. It's still normal in operation but that irritates me a bit. Should we adjust it back and HOW?
Old Apr 25, 2010 | 06:38 PM
  #287
rawley_12003's Avatar
rawley_12003
yeah man your not alone i just installed my window motor like 4 months ago and it went out again so i ordered another driver side motor good thing it was on warranty.
Old Apr 29, 2010 | 07:38 PM
  #288
will350z's Avatar
will350z
finally got around to doing this and I have got to say great writeup VO and yes painters tape works very well as I wasn't too keen on having duct tape on my tint, just glad to know it worked.
The no residue is a huge plus at the end and the window didn't even budge when i got around to pulling out the old motor!
Old May 1, 2010 | 02:37 PM
  #289
gerb's Avatar
gerb
I gone through this whole thread and no one has mention a similar problem to mines.
So here's my dilema,
My windows sometimes work and sometimes don't. Like I have notice that at times, when I close my door, the light on the window switch and all components on door are not lit up, thats when my windows don't work. I have to open the door ALL THE WAY OPEN and I see the light turn on and then my window will work, but as soon as I close the door halfway the light turns off and my window doesn't respond again lol.
Any ideas of what my problem could be?
Old May 1, 2010 | 03:00 PM
  #290
Dave 90TT's Avatar
Dave 90TT
350Z 2+2
Bad ground or power to the door. Probably ground.
Old May 1, 2010 | 03:55 PM
  #291
gerb's Avatar
gerb
Hmm I will loook into that. I hope it's something simple as that
thnaks
Old May 11, 2010 | 06:09 AM
  #292
jg425's Avatar
jg425
great write up!!!! Was able to switch window motors within an hour!
Old May 11, 2010 | 11:03 AM
  #293
ZmycaR's Avatar
ZmycaR
Originally Posted by vo7848
Here's some internal shots of the door once you've pulled the door panel aside...
anyone have a solution to the grease rubbing brush in the window when rolling it up and down?
Old May 14, 2010 | 02:31 PM
  #294
ttuberz's Avatar
ttuberz
Usefull thread. Im on my 2nd set of new motors that have failed and only 50K miles. I just tried cleaning it but looks like i'lll have to throw more money into this pos.
Had to vent. Sorry :\
Old May 17, 2010 | 08:36 AM
  #295
sixsigmalarry's Avatar
sixsigmalarry
Thumbs up Thanks! Great Thread!
My passenger side window just went out on me. After looking at the process I think I will just opt for a new motor than attempting to clean my old one (fearful that it will die on me again).
Also, this week Advanced Auto has 15% off their orders online over $100 and free shipping. That's where I'm getting mine!
Thanks again!
Old Jun 4, 2010 | 05:51 AM
  #296
az240z's Avatar
az240z
Just be sure your getting a new motor and not a rebuilt one.
Old Jun 7, 2010 | 12:05 PM
  #297
homeboynyc's Avatar
homeboynyc
very nice writeup. Guys I fixed my passenger side window that was bad for like 1 1/2 year now and went ahead bought the brushes and voila!! it works. I highly recomend this to anyone that has mechanic/electronic skills.
I followed these instructions:
https://my350z.com/forum/maintenance...-be-fixed.html
Old Jun 15, 2010 | 02:12 PM
  #298
LVZ053's Avatar
LVZ053
It's been almost a year and mine still works after fixing it.
Old Jun 15, 2010 | 03:13 PM
  #299
GT-Rob's Avatar
GT-Rob
had mine fail a few months ago (75km). Cleaned out, worked like new for about 2 months, then started to crap out again.
Dealer wants $500 for a new motor, NAPA was $280 I think (canada). Considering I won't even have windows in a year or so, Im just going to live with it. Might try and replace the brushes.
Old Jun 19, 2010 | 08:43 AM
  #300
vclilman's Avatar
vclilman
Hello, I'm new here but am having a window issue myself. I just bought the car, and the passenger window doesn't do down or up when I open my door. And also, if I pull all the way up, for the window to go up on its own, it goes all the way up and then comes down a quarter of the way. To get it to stay, I have to manually hold the switch halfway. The dealership said it's a computer issue and they can just hook up a computer to it and fix it, and that I can program my window to do whatever I want. Is this true?
