05 Clutch slave cylinder replacement?
Old Jun 2, 2008 | 07:51 PM
JPsZ's Avatar
JPsZ
Default 05 Clutch slave cylinder replacement?
Does anyone know how hard it is to replace the slave on an 05? My clutch is sticking halfway when hot and my year doesn't fall under the recall =( I was thinking of just changing the fluid but if the slave cylinder is cheap I might as well replace that all at once. Has anyone done this? About how much is the slave at dealer? Thx in advance
Old Jun 3, 2008 | 07:51 AM
Art Vandaleigh's Avatar
Art Vandaleigh
I actually had the same type of issue where on very hot days or in stop and go traffic, my clutch would start to stick. I changed the fluid to a higher temp type, and swaped the stock rubber clutch line to a SS one. No problems since.
Old Jun 4, 2008 | 06:36 PM
35Z's Avatar
35Z
Default Clutch Fluid
Which clutch fluid did yoy go with?
Old Jun 4, 2008 | 07:44 PM
BallZdeepNYC's Avatar
BallZdeepNYC
ditto? what brake fluid did u change to?
Old Jun 5, 2008 | 02:42 PM
Art Vandaleigh
I used ATE Superblue for the clutch fluid.
Old Jun 7, 2008 | 05:12 PM
runnun's Avatar
runnun
I have an 03 and in hot weather my clutch makes a squeaking noise when it is low to the ground maybe an inch an a half from the floor, is that the slave cylinder? I dont really feel as though it is sticking. I'll have to give a better diagnose later
Old Jun 7, 2008 | 05:13 PM
runnun's Avatar
runnun
are the '03's under man recall for the slave cylinder?
Old Jun 7, 2008 | 05:24 PM
runnun's Avatar
runnun
Old Aug 12, 2008 | 11:27 PM
DRELOC's Avatar
DRELOC
Sorry to bring this up from the dead but i have the same issue like you do OP and the same year Z also did you ever get this issue resolved?
Old Aug 19, 2008 | 11:37 AM
UMW350Z's Avatar
UMW350Z
yea +1 i want to know as well
Old Aug 19, 2008 | 11:45 AM
UMW350Z's Avatar
UMW350Z
Old Aug 19, 2008 | 11:46 AM
blasian's Avatar
blasian
My roommate has an 05 Grand Touring and had this issue. When he replaced his slave cylinder it stopped it.
07ZEKE
Aug 23, 2021 09:15 PM
sherm
Apr 11, 2020 05:21 PM
350z82
Oct 1, 2015 06:25 PM
