OEM battery lasts forever.
Old Aug 24, 2009 | 08:52 AM
  #81
Eddie@Performance's Avatar
Eddie@Performance
Performance Nissan
The factory Panasonic/Yuasa battery will actually last a little longer if you maintain the distilled water in the battery properly. My Panasonic battery is 8 years old and still kicking strong and has no signs of acid build up on the terminals either.
Old Aug 24, 2009 | 02:48 PM
  #82
mw9's Avatar
mw9
Originally Posted by LaoSiFu
Had the original battery since June of 2003. I really should replace it before I get stuck somewhere.
~Robert
Yes, soon after I posted how proud of how long my 03 battery lasted, it died while I was at work.
Old Aug 24, 2009 | 02:58 PM
  #83
LaoSiFu's Avatar
LaoSiFu
funny it happen to me too. I got the Optima Yellow as a replacement.
~Robert
Old Sep 21, 2009 | 02:24 AM
  #84
jmark's Avatar
jmark
Lasted slightly over 2 years. I don't drive it much but I keep it on a Battery Tender jr. and it says the battery is charged with a green light. Open the door and try to start it and it just clicks..... Is the battery gone?
Old Sep 21, 2009 | 11:30 PM
  #85
350ZTheStandard's Avatar
350ZTheStandard
Mine went out last Monday, had to get a jump to get to my local NiSSan stealership. They only sell a 84 month battery costed about $111.00 with tax & install . Lasted 54 months & the mechanic said my stereo killed the battery long before it's time.
Old Sep 22, 2009 | 12:47 AM
  #86
quakerroatmeal's Avatar
quakerroatmeal
Is it turning over? If it just click it could be more then the battery..
Just replaced mines with the Duralast Gold since mines was starting to struggle a little.
Weighs like 1lb heavier then OEM.
Old Sep 22, 2009 | 02:28 AM
  #87
jmark's Avatar
jmark
Open the doors and it buzzes like coming from the door motors. Then insert the key and try to start it and it clicks. I am out of town now. When I get home I'll see if it is charged. If not I guess I'll jump it off or take the battery out and get her tested.
Old Sep 22, 2009 | 07:27 AM
  #88
j.arnaldo's Avatar
j.arnaldo
Aha, and I made the b-i-g mistake of getting a "Titan(???)" from Advance Auto, when the OEM one went! Whenever I need another one, I'll get the original! It's the "School of Hard Knocks" teaching me! I purchased an emergency booster at Pep Boys, which I keep at home---just
in case.
Old Sep 22, 2009 | 07:49 AM
  #89
BornSlippyZ's Avatar
BornSlippyZ
Almost 5 yrs old and still working!
Old Oct 5, 2009 | 02:38 AM
  #90
jmark's Avatar
jmark
Battery was low on water. I had it swapped anyway. I used a jumper battery to run it over to the mechanic for service. Mechanic told me he was surprised it ran. It was showing less than 5 volts when he tested it. So word to the wise check your LOW maintenance battery. It is NOT NO maintenance. I checked my two classic Z's and there batteries were fine. One is a two year Walmart battery going on 7 years! All three batteries are on battery tenders.
Old Oct 6, 2009 | 11:38 AM
  #91
The Closer's Avatar
The Closer
My 2003 lasted until two months ago, nearly 60,000 miles before it started to fail. Replaced with a yellow top for all the amps and subs in my car.
Old Oct 6, 2009 | 11:50 AM
  #92
haeshik's Avatar
haeshik
Originally Posted by DavesZ#3
You're the exception - not the rule. Typically, all you'll get is about 3 years out of most batteries.
i just replaced mine after 3 years
Old Oct 6, 2009 | 12:39 PM
  #93
ZPirate's Avatar
ZPirate
My battery is still going strong after 6 plus years (I hope I haven't jinxed myself by posting in this thread). I purchased my car brand new in early January of 2003.
Although my car is only driven one or two days a week it stays in a semi-climate controlled garage which probably has contributed to the battery's longevity.
Old Oct 8, 2009 | 09:33 AM
  #94
Chasecbc's Avatar
Chasecbc
I have an 03 Z with 85k miles and the original battery, its time to get replaced tho.
Old Oct 19, 2009 | 11:06 AM
  #95
platinum350's Avatar
platinum350
I just had to replace mine, '03 with 82K on it! Wasn't sure why but my overhead interior lights have stopped working about a month ago. Checked fuses and all, couldn't figure it out. Well, replaced my battery today and their working once again....a design to keep the juice in the battery????
Old Oct 19, 2009 | 11:18 AM
  #96
j.arnaldo's Avatar
j.arnaldo
I substituted mine at just before 60 months...Hadn't thought of it till you mentioned it.
Old Oct 20, 2009 | 08:51 AM
  #97
Uncontested's Avatar
Uncontested
lol figures I see this thread when Im about to ask about batteries since mine just died (03 Z, Had it for 2 and a half years now)
Old Oct 20, 2009 | 09:30 AM
  #98
pcharoe1's Avatar
pcharoe1
Originally Posted by robertinmesa
you are lucky if you get more than 2 years in phoenix.
I have an 06 with 11,900 miles....still with OEM.
Old Oct 24, 2009 | 01:03 PM
  #99
zen350z's Avatar
zen350z
Mine lasted a little past 6 years it had 85k on the clock it just up and died at work. Thats pretty damn good and im in VA, so I get the perfect mix of all the seasons.
Old Oct 24, 2009 | 01:07 PM
  #100
SmoothZ's Avatar
SmoothZ
Senior Super Moderator
Ha! I'm in MN and have been storing my Z for 4 winters (this is my 5th). The battery is still strong as the day I bought the car in March 2004. I've driven the car to Zdayz twice. I've also taken the car down to southern Georgia for a summer. Been to Miami on a long weekend while I was in GA. This car hasn't really ever disappointed me.
