*sigh* Can't remove oil filter
Old Jun 4, 2009 | 10:09 AM
THe Emperor's Avatar
THe Emperor
Default *sigh* Can't remove oil filter
I put the OEM replacement oil filter on by hand last time but now I can't even get it off. I don't have an oil wrench and the oil is already drained from the car so I can't drive to the store. Any advice or tips? From under the car laying on my back which direction should I be turning the filter? I don't want to be tightening it up instead of loosening it.
Old Jun 4, 2009 | 10:12 AM
cheshirecat79's Avatar
cheshirecat79
It would come off the same way a cap of a 2-liter bottle would screw off if it had the same orientation.
Chances are you're tightening it. Usually they aren't on there too tight.
You can try using a big pair of pliars, or if you want to get barbaric on that bastard drill a hole through it and insert a screwdriver, then turn.
Old Jun 4, 2009 | 10:29 AM
ThreeFiveZero Z's Avatar
ThreeFiveZero Z
Lefty loosey, righty tighty...come on now lol
You should always have a filter wrench to give it a snug after hand tightening it.
Old Jun 4, 2009 | 10:32 AM
JasonZ-YA's Avatar
JasonZ-YA
What cheshirecat79 said...........do the screw driver trick.........stab that sucker and then turn!!
-J
Old Jun 4, 2009 | 10:35 AM
only350z's Avatar
only350z
Just punch a screwdriver through it and use it as leverage.
Worked for me when I did my oil change for the first time...
Never happened again.
Old Jun 4, 2009 | 10:47 AM
Spork's Avatar
Spork
I've done the screwdriver trick before, works great, but it's messy.
Now I only use K&N oil filters, and there's a nut on the bottom of the filter for easy removal.
Old Jun 4, 2009 | 10:52 AM
quakerroatmeal's Avatar
quakerroatmeal
Are your hands slipping on the filter or is it really on that tight?
Anyways get somebody to take you to buy the tool wrench if you don't want to make a mess.
Old Jun 4, 2009 | 10:53 AM
ThreeFiveZero Z
I like those Fram tough guard ones. They have this griptape like cap on the end to make it easier to remove.
Old Jun 4, 2009 | 11:04 AM
CancerJCCz's Avatar
CancerJCCz
IBTFramsucksguys...
I like the screwdriver technique never heard of that one before.
Old Jun 4, 2009 | 11:08 AM
THe Emperor
Thanks guys I managed to get it off. After I got my hand and the filter as clean as I could I managed to get a tight enough grip to get it off. Never again will I over tighten my oil filter lol.
Old Jun 4, 2009 | 11:10 AM
mcarther101's Avatar
mcarther101
You can also try sandpaper to get a bit more grip, but it didn't work when I tried that.
Old Jun 4, 2009 | 12:06 PM
J350z101's Avatar
J350z101
hammer + screwdriver.. push it threw and turn.. simple
Old Jun 4, 2009 | 01:02 PM
350 Rookie's Avatar
350 Rookie
Once its done, go buy some Filter Pliers.
Old Jun 4, 2009 | 01:10 PM
Done Deal DR's Avatar
Done Deal DR
The fix is easy...
Get yourself an oil filter wrench with the teeth on them like this, they are only a few bucks and they will get even the most stubborn oil filters.
Old Jun 4, 2009 | 01:19 PM
diablox1's Avatar
diablox1
not knowing which way to turn ftl
Old Jun 4, 2009 | 01:56 PM
SoldzMyZ's Avatar
SoldzMyZ
You can also get those plastic grip thing. It looks like a rubber belt and a hard plastic stick. Just do that and turn. Also useful for opening right bottles and cans.
Old Jun 4, 2009 | 02:24 PM
Done Deal DR
If you've used both, you know those things suck.
Old Jun 4, 2009 | 03:01 PM
blktrack350's Avatar
blktrack350
x2
Old Jun 5, 2009 | 07:09 AM
diablox1's Avatar
diablox1
x3
Old Jun 5, 2009 | 07:45 AM
350 Rookie's Avatar
350 Rookie
x4
