brake warning + VDC off + slip lights
Old Aug 17, 2009 | 05:26 AM
somebody's Avatar
somebody
Default brake warning + VDC off + slip lights
I took my car to the track yesterday.....drove with VDC off.
Now, every time I start the car, brake + VDC off + slip lights come on & stay on......anyone have experience with this issue?......any idea?
Old Aug 17, 2009 | 06:07 AM
zeus2006's Avatar
zeus2006
I have never been in a competition, where the car is put through extensive wheel spin, but I have had a few occasions when the slip light stayed on after some quality donut fun. The light stays on until I shut off the car and has not come back on after restart. So, you got me as to why yours isn't eventually turning off?
Old Aug 17, 2009 | 06:21 AM
dragonfire6's Avatar
dragonfire6
Default ....
Is your car in limp mode??
Could be low brake fluid or not enough meat on your brake pads, which could both be the result after a track day...
I'm sure the mods are moving this to the maintenance section, which is a good place to start looking for your answer...
Old Aug 17, 2009 | 06:23 AM
VO...'s Avatar
VO...
Administrator
Moved...
Old Aug 17, 2009 | 06:31 AM
somebody's Avatar
somebody
no. it's not in limp mode.
The car drives fine.....brake, no problem....fluid is at an acceptable level.
.....it's bugging me.
i wonder if the electronic got "confused"....never drove with VDC off before.
Old Aug 17, 2009 | 06:36 AM
somebody's Avatar
somebody
my buddy thinks my ABS sensor(s) is f'ed...,,which works for VDC + TCS as well......???
any opinions? I'd like to go to the shop with some idea.
Thanks in advance.
Old Aug 17, 2009 | 06:59 AM
The VDC-TCS-ABS computer is finicky. Give it a couple of days before resetting the ECU.
Old Aug 17, 2009 | 07:20 AM
somebody's Avatar
somebody
^ possibly dumb questions;
-why wait for a couple of days?
-can I reset the ECU by disconnecting the battery for a few hours?
Thanks for your input.....
Old Aug 17, 2009 | 08:54 AM
Wait because it may fix itself.
Yes you can disconnect the battery.
Old Aug 17, 2009 | 09:06 AM
somebody's Avatar
somebody
actually, I may have found an answer.....A thread in the brake & suspension section.
Someone had an exact same issue as me....& a bit of brake fluid solved the problem.
https://my350z.com/forum/brakes-and-...fter-hpde.html
My brake fluid is above MIN. level but, not by much. I'll try that tonight.
Thanks again for the input.
Old Aug 17, 2009 | 11:27 AM
Drumhead666's Avatar
Drumhead666
i had the same problem. changed my brake pads. problem solved.
Uriyo_
Sep 8, 2021 08:46 AM
350z82
Oct 1, 2015 06:25 PM
