Batterys dead, recommend a good charger?
Old Oct 3, 2009 | 01:26 PM
wildone_106's Avatar
wildone_106
Default Batterys dead, recommend a good charger?
Its in the parking garage and I have no one to help jump start it here so I wonder if there's a quick battery charging device out there I can use to get it going again, any recommendations? Thanks.
Old Oct 3, 2009 | 01:35 PM
superchargedg's Avatar
superchargedg
Damn Noobs
Just go and get a jump starter box.....but the only bad part is you have to charge the internal battery for a couple hours before you use it.You can get these at pep boys and most auto stores.
Old Oct 3, 2009 | 01:36 PM
DavesZ#3's Avatar
DavesZ#3
A professional quick charger will probably cost you more than a new battery would. A cheap non-pro model will take a few hours but will get the job done.
Old Oct 3, 2009 | 01:40 PM
wildone_106
Do I have to worry about the 'amps' I saw soem chargers on Amazon that had different ratings like 10/12/2 ect not sure if I have to consider that
http://www.amazon.com/tag/car%20battery%20charger
Old Oct 3, 2009 | 02:59 PM
OMERTAITALIA's Avatar
OMERTAITALIA
if you go to autozone or napa they will test it and if its good theyll charge it for free.
Old Oct 3, 2009 | 05:06 PM
Adrians07Z's Avatar
Adrians07Z
yea .. take the battery out and take it to the auto parts store .. they'll charge it for free
Old Oct 4, 2009 | 07:54 AM
wildone_106
thanks for the replys. Unfortunately Im not close to any auto store where I can lug a battery too so I have to get a charger online and have it mailed to me
Old Oct 4, 2009 | 11:33 AM
winchman's Avatar
winchman
Caution!!! There's a caution in the owner's manual about removing the battery. It says do not close either front door when the battery is disconnected. The window adjusting function will not lower the window, and the roof panel side rail may be damaged by closing the doors with the windows up.
Just curious.
Will removing the battery in the Z trip any anti-theft circuits? I had the battery in one of my vehicles replaced at a Battery Store, and the radio wouldn't work until I had it reset at a dealer.
The dealer said you were supposed to temporarily hook up another battery while switching out the bad one so the system wouldn't be without power.
Old Oct 5, 2009 | 11:08 AM
Lee R's Avatar
Lee R
WALMART!
You have to order something that takes a few days to getthere because you don't live close to any shop/store/dealer etc?
Old Oct 6, 2009 | 02:33 PM
Kunihiro's Avatar
Kunihiro
Wildone,
I use a product called a "Battery Tender", it will keep a constant charge on your battery. You can hook it up directly to your battry and it will send a continuous trickle charge to your battery, then shut down when it's charged. As soon as it detects a charge drop it will trickle charge it back up.
Here's the link:
http://batterytender.com/
As far as unhooking your battery, yes, it is a pain cause you will lose all the pre-set channels on your radio and if it's like Honda's you have to plug in a five digit code to unlock the anti theft code.
But, you can use one of these little thingamajiggies:
You just plug it into your auxiliary plug/port, attach a 9 volt battery, now you can disconnect your battery and don't have to worry about losing your pre-set channels and other stuff that you would lose with a disconnected battery.
I use this stuff on my 71 RS Camaro.
Allen
Old Oct 6, 2009 | 11:16 PM
winchman's Avatar
winchman
Where did you buy that? Got a link?
Old Oct 7, 2009 | 03:22 PM
Kunihiro's Avatar
Kunihiro
Winchman,
I got it out of my Eckler's Camaro catalog. Sure beats having to re-set everything, cause that's a PITA....Here's the link....
http://www.ecklerscamaro.com/product...dept%5Fid=1095
Old Oct 9, 2009 | 06:36 PM
wildone_106
Thanks for the tips & info!
Old Oct 9, 2009 | 08:38 PM
350ZToeRing's Avatar
350ZToeRing
its called a memory saver....you can find them anywhere.
lapham3
Oct 7, 2022 03:15 PM
Rev_Night
Nov 7, 2020 06:00 PM
Depravity
Oct 1, 2015 04:49 PM
