shifting into 5th grind
Old Feb 3, 2010 | 03:49 PM
randymack's Avatar
randymack
Default shifting into 5th grind
every other time i put her into 5th i can feel a grind in the shifter...nothin bad but its there. Only in 5th...clutch fully deepressed and only every other time or less...ideas?
Old Feb 3, 2010 | 03:52 PM
How many miles?
Old Feb 3, 2010 | 05:47 PM
F34RL355's Avatar
F34RL355
do the gears grinds at all too?
Old Feb 3, 2010 | 06:57 PM
Spike100's Avatar
Spike100
Hi Randy... The problem you describe sounds very much like the infamous and notorious synchromesh problem exhibited in the earlier 350Z transmissions.
If that is the case, the only good fix is a transmission replacement (which isn’t cheap it you are out of warranty… regular or extended).
A search will provide a lot of information about this problem and it’s fix.
--Spike
Old Feb 3, 2010 | 07:01 PM
rich2342's Avatar
rich2342
or it could be a misaligned shift plate. Have that checked first before throwing out the tranny
Old Feb 4, 2010 | 05:22 PM
randymack's Avatar
randymack
i just hit 40,000 miles.
Old Feb 4, 2010 | 05:23 PM
dmroberson's Avatar
dmroberson
Try changing your tranny fluid. I did and the 5th gear grind went away. Have you had the tranny serviced at all yet? I've got 82K on the clock, and I've changed it about every ~40K miles.
Old Feb 4, 2010 | 06:59 PM
Spike100's Avatar
Spike100
Sure about that? Did you do anything else other than simply change the transmission fluid?
Of course careful maintenance is important, but I ask this question because true grinding (with the noise and vibration) happens when metal surfaces contact each other. You would expect this with faulty synchromesh gears or a poorly aligned gate. Those problems would not be fixed by simply changing the transmission fluid (the fluid would need to be very thick goo to eliminate a grind).
--Spike
Old Feb 5, 2010 | 08:40 AM
randymack's Avatar
randymack
I have yet to change the tranny fluid. I Will do that at my next oil change. and,no the gears don't grind... just the grind in the shift.
my brother is telling me royal purple tranny is great in his boxter...anyone recommend?
Old Feb 5, 2010 | 11:53 AM
dmroberson's Avatar
dmroberson
--Spike
The problem went away for me, after I changed the tranny fluid. Didn't do anything else but that... well except change the diff oil at the same time. I figured it'd be a good place to start.
I see your point. If it was, indeed a faulty synchro or misaligned gate, then changing the fluid would make it worse, more than likely. Thanks for pointing that out. Didn't think about it that way.
I personally use Redline in my tranny and diff. I've heard Royal Purple isn't bad though.
MAsSIVrOOM
Oct 20, 2023 10:50 AM
sherm
Apr 11, 2020 05:21 PM
Vigman
Nov 17, 2015 04:34 AM
apex locator
Oct 6, 2015 05:58 PM
