Please help *** VDC / Slip light
Old Mar 29, 2010 | 10:35 AM
maxevo's Avatar
maxevo
Default Please help *** VDC / Slip light
ok guys i have searched around 350z/G35 forums and please dont bash me i did not find the answer that i was looking for.
When i purchused my 350z i noticed that the VDC/Slip lighst where on i asked the person and he said that the car apperantly dosnt have traction control or he has removed it or something
now i have 2 ugly lights always lit on my dash i wanted to see how can i get rid of those 2 lights ? someone told me take out red fuse 50 under the hood but i read up on it and that just disables the Traction/ ABS / VDC , Slip
I just want the lighst on the dash to go away please help !
Old Mar 29, 2010 | 10:48 AM
raycs7's Avatar
raycs7
First, does the car have VDC?
There will be a button under the steering column that says VDC.
2003 to 2005 models had VDC only on the 6 speed track, touring and performance models.
If it doesn't have VDC the dealer can reset it. The cluster could have been changed out.
So first, what year and what trim is your car. Is there a VDC button. Is it clean title?
What size wheels/tires?
Old Mar 29, 2010 | 11:30 AM
Instead of disabling VDC I would want to figure out why the light is ON. But that’s just me.
Old Mar 29, 2010 | 11:35 AM
04silvrz's Avatar
04silvrz
never buy a car with any funny lights on, you are asking for trouble.
Old Mar 29, 2010 | 11:44 AM
hellsoldiers08's Avatar
hellsoldiers08
hmm guy gives a weird answer and you buy the car?? 2nd. are they stock rims or aftermarket? It sounds weird but make sure your tires have the right psi, reason saying if they really low i would say it could make the vdc go off.
just my .02
Old Mar 29, 2010 | 02:18 PM
DavesZ#3's Avatar
DavesZ#3
If you check your owners manual, you'll find that if those lights are on all the time, then you have a problem.
Indicator light
If a malfunction occurs in the system, the
SLIP and VDC indicator lights come on in
the meter panel.
As long as these indicator lights are on, the
vehicle dynamic control function (except the
ABS) is canceled.
Do you have the VDC Off button under the dash, near your left knee?
Old Mar 30, 2010 | 07:33 PM
maxevo's Avatar
maxevo
yes there is the VDC button down there but when i press it dosnt do anything , and second its a 04 track package 6 speed.
Old Mar 30, 2010 | 07:38 PM
ZRated67's Avatar
ZRated67
Are you running stock tire sizes? If not, you need to be running larger rears, while being within 3% from front to rear.
If you are running a square setup, that may be causing your Christmas tree lighted dash.
Don't ask me how I know this.........
Old Mar 31, 2010 | 03:09 AM
DavesZ#3's Avatar
DavesZ#3
That means that you have VDC. If those lights are on all the time, then you have a problem with the computer in the system.
Old Mar 31, 2010 | 03:55 AM
maxevo's Avatar
maxevo
ok thank you guys for the help im running stock tires, plan on sending the car into the dealer for service.
Old Apr 8, 2010 | 04:53 AM
infamous350's Avatar
infamous350
last time this happened to me i needed to add brake fluid
Old Apr 8, 2010 | 05:01 AM
JCat's Avatar
JCat
Another possibility is that one or more of the wheel sensors is not located properly.
My warning lights came on after installing the SPC camber kit.
Old Apr 8, 2010 | 09:15 AM
DavesZ#3's Avatar
DavesZ#3
^^^ Usually, that doesn't occur until you start driving. If you start the car and the lights come on, you have a problem other than the sensors.
Old Apr 8, 2010 | 09:16 AM
DavesZ#3's Avatar
DavesZ#3
The Brake light would be also illuminated, OP only has VDC & Slip lights.
Old Apr 8, 2010 | 09:50 AM
JCat's Avatar
JCat
Mine stayed on . . . .even after re-starting the car.
Perhaps plugging in a code reader might yield some insight ?
Old Apr 8, 2010 | 10:01 AM
Z Infidel's Avatar
Z Infidel
Mine are on as well and it started when a battery cable came off due to a loose terminal during driving. I would be curious as to how to fix it/make them go away.
Old Apr 8, 2010 | 01:28 PM
DavesZ#3's Avatar
DavesZ#3
No CEL = no codes. I don't recall if the ABS unit has any specific codes or not.
Reset of the ECU might clear it. The problem with power glitches like that is something could be fried. Try disconnecting the battery, press on the brake pedal then reconnect it. That should reset the ECU.
Old Apr 8, 2010 | 02:04 PM
MPD47's Avatar
MPD47
It's also possible the previous owner removed the bosch yaw sensor under the center console. Turns on VDC and slip lights, but allows ABS to still function (but disables EBD).
Just pull up your shifter surround and look just behind the shifter and see if the black box is bolted up in there. If it's not, shoot me a PM I have an extra here in my tool box.
Old Apr 8, 2010 | 03:26 PM
ericjackson's Avatar
ericjackson
just an fyi, mine does this when i run low on brake fluid. has happened twice to me in my 135k
loudtoyz
Apr 6, 2023 04:52 AM
Uriyo_
Sep 8, 2021 08:46 AM
350z82
Oct 1, 2015 06:25 PM
Sleeper_Z
Sep 30, 2015 10:25 AM
samansharif
Sep 25, 2015 12:31 PM
