Help! Airbag Light
Old May 24, 2010 | 04:04 PM
Road Warrior's Avatar
Road Warrior
Default Help! Airbag Light
i have a 2004 350z enthusiast...only 25k and my airbag light is flashing at me. tried resetting battery and no luck. manual says could be seat belt tensioner but not sure where to turn other then taking her in to the stealership...which i would like to avoid for obvious reasons.
thanks in advance for any advice
road
Old May 24, 2010 | 04:15 PM
marques1's Avatar
marques1
you need to reset you airbag using the following procedure in the link below. Go to the 7the post down to find the procedure.
link: https://my350z.com/forum/exterior-an...-blinking.html
Old May 24, 2010 | 07:21 PM
350ZTheStandard's Avatar
350ZTheStandard
^ Thanks for the link, my seatbelt light has been flashing since I recovered my leather seats.
Old May 25, 2010 | 07:28 AM
Road Warrior
thank you sir...appreciate you getting me pointed in the right direction...will try this tonight after work.
road...out
Old May 25, 2010 | 01:27 PM
marques1's Avatar
marques1
you guys are welcome let me know how things pan out.
Old May 25, 2010 | 03:20 PM
Road Warrior
worked like a champ marques1....thank you and my350z
i only needed to perform the first step and presto, no air bag light....hope 350ZTheStandard works out the same.
laterz
road
Old May 26, 2010 | 10:26 PM
Ray21's Avatar
Ray21
Angry
Hey guys,
Have the same issue but my light is still blinking.
I did get into a minor front bumper accident but nothing huge.
I can't seem to get the light to stop working. I hope I don't have to make a trip to the dealership
Old May 28, 2010 | 06:58 AM
Road Warrior
you prob need to keep going through the diagnostic that was posted...should be able to figure the problem from there and hopefully you don't end up having to take the car in
Old May 28, 2010 | 07:50 AM
marques1's Avatar
marques1
laterz
road
Your welcome road warrior. Nothing is better than to know that your car doesn't have to go into the dealership, lol. I'm glad things went well for you man.
Old May 28, 2010 | 07:52 AM
marques1's Avatar
marques1
Originally Posted by Ray21
Hey guys,
+1......you probably need to keep doing the reset procedure. Some people weren't as gifted with accordination and it takes them more than one or two tries to get it right. The procedure must be done in a certain time frame...keep at it.
Old May 28, 2010 | 09:54 PM
350ZTheStandard
I tried this tonite and it no workee, I will do it agian in the morning. Me thinks I just didn't do it right.
Old May 30, 2010 | 08:03 PM
marques1's Avatar
marques1
takes a little practice because the timing is essential.
Old May 30, 2010 | 11:30 PM
350ZTheStandard
I tried it twice since my last post & still no dice. I am going to read the schematic in the other thread & have a friend try it again, crosses fingers.
Old Jun 1, 2010 | 07:32 AM
Road Warrior
i feel lucky then to have gotten this to reset. i didn't have a stop watch, but i would just count to myself the time in between turning the key on, and then off, on and then off...etc. hope you guys have better luck with this....i'm sure it is just a timing issue performing the reset procedure.
the following was taken from within the link/thread that marques1 referred that worked for me:
1: put key in ignition
2: turn to the ON position (not engine on but ACC on), SRS light will come on for a solid 7 seconds and then it will start to blink.. as soon as it goes off after the 7 second "on" turn to off position.
3: you'll hear beeps from the car, count 5 sets of beats (5 seconds)
4: turn to the ON position, SRS light will come on for a solid 7 seconds and then it will start to blink.. as soon as it goes off after the 7 second "on" turn to off position.
5: you'll hear beeps from the car, count 5 sets of beats (5 seconds)
6: turn to the ON position, SRS light will come on for a solid 7 seconds and then it will start to blink.. as soon as it goes off after the 7 second "on" turn to off position.
7: you'll hear beeps from the car, count 5 sets of beats (5 seconds)
8: turn to on, and leave on... now if it turns off after the 7 second solid "ON" you are good to go.
if this does not work and your light does something else...there is more troubleshooting that you have to perform that is posted in the link.
loudtoyz
Apr 6, 2023 04:52 AM
Uriyo_
Sep 8, 2021 08:46 AM
350z82
Oct 1, 2015 06:25 PM
Sleeper_Z
Sep 30, 2015 10:25 AM
samansharif
Sep 25, 2015 12:31 PM
