CEL light
Old Oct 2, 2010 | 11:13 AM
silvertouringz's Avatar
silvertouringz
Default CEL light
hi i installed a pop charger and drove for about 70 miles and now the i see the CEL light!! any ideas?
Old Oct 2, 2010 | 11:51 AM
DavesZ#3's Avatar
DavesZ#3
Did you get the code read?
When you unplugged the MAF, was the battery still connected? If so, you need to disconnect the battery, press the brake pedal then reconnect it to reset the ECU and clear the CEL.
Old Oct 2, 2010 | 12:48 PM
silvertouringz
ok i unplugged the battery and will reconnect it tomorrow...let's see what will happen
Old Oct 2, 2010 | 10:31 PM
amr_electron's Avatar
amr_electron
With all my respect to your experience, But unplugging the MAF while the battery is connected will not trigger a CEL .
Old Oct 3, 2010 | 01:29 AM
silvertouringz
ok connected the battery back and the light is gone
Old Oct 3, 2010 | 04:53 AM
DavesZ#3's Avatar
DavesZ#3
You are correct - I was thinking of the throttle body. If you turn the ignition on with the MAF unplugged it will throw a CEL.
Old Oct 3, 2010 | 09:47 AM
ZPHILE's Avatar
ZPHILE
Hey, whatta know, this stuff works!!!
Old Oct 3, 2010 | 11:06 AM
neox's Avatar
neox
Yes, unplugging the battery makes the CEL go off.. but your car still threw the code for a reason so you shouldn't simply ignore it.
In this case he just modified his air intake so im sure the car threw the code because of that change. My car threw a code when I put my intake on, I reset the ECU and the light has never come back on.
Old Oct 7, 2010 | 02:38 PM
AJCaron12's Avatar
AJCaron12
+1, if the key is on and you unplug a lot of things under the hood the CEL will come on, but then become a stored code once you plug the connector back in.
loudtoyz
Apr 6, 2023 04:52 AM
Uriyo_
Sep 8, 2021 08:46 AM
350z82
Oct 1, 2015 06:25 PM
Sleeper_Z
Sep 30, 2015 10:25 AM
samansharif
Sep 25, 2015 12:31 PM
