Valvetrain noise (tick) only when warm. Oil viscosity ?
Old Aug 12, 2011 | 05:16 PM
mezer's Avatar
mezer
Default Valvetrain noise (tick) only when warm. Oil viscosity ?
2003 350z
50k miles
When first starting the car in the am, it's fairly quiet. But after it warms up, there seems to be alot of valvetrain noise. It sounds great with the windows closed, but with them open, I can hear the valvetrain noise bouncing off passing cars, and bouncing off the curb beside me. It's fairly loud. But only loud when it gets warm.
Temperature out is around 70+ f
Oil level is good. I'm using 0w30 german castrol which is a thick oil to begin with. Do I try to go thicker? Is it making noise because the oil is thinning? I know 0w40 m1 is slightly thicker them gc
Any suggestions?
Old Aug 12, 2011 | 08:23 PM
tony530's Avatar
tony530
stay with oem spec....lol
Old Aug 13, 2011 | 04:53 AM
mezer's Avatar
mezer
10w40 is with oem spec
Old Aug 13, 2011 | 06:26 AM
no no no. Motor oil is not a magic potion that fixes stuff. If you have internal motor problems then you have internal motor problems. 5 quarts of oil will not fix it.
Old Aug 13, 2011 | 07:09 AM
winchman's Avatar
winchman
According to the 2003 owner's manual, 5W30 is the preferred oil for all ambient temperatures.
What makes you think the noise is coming from the valve train?
Old Aug 13, 2011 | 07:24 AM
mezer's Avatar
mezer
If I had internal motor problems.. wouldn't it show up when engine is cold, or even warming up.
Engine sounds great when cold, and valve train noise starts when it's hot. Which tells me the oil is thinning..
Stethoscope on the heads / valve covers tells me it's valve train noise.
Old Aug 13, 2011 | 10:18 AM
winchman's Avatar
winchman
There is a procedure in section EM of the service manual for checking the clearance between the lifter and the cam. If it's out of spec, you'll need to get a new lifter with the correct thickness for each out of spec valve. I suspect that could get expensive really fast at $18 each.
Does the noise have a rhythm to it, or is a steady tick, tick, tick. A rhythm would indicate only some valves have too much clearance.
Other than the noise, the excessive valve clearance doesn't hurt much, so I'd be inclined to live with it.
I'm still not completely convinced it's valve related.
Old Aug 13, 2011 | 02:22 PM
mezer's Avatar
mezer
It doesn't really sound like a tick. It's NOT a knock.
It's sounds more like a clatter. And the clatter isn't coming from the front (so don't think it's timing chain issue). You can't hear it when the windows are closed. You mainly hear it when you are beside a concrete barrier, and the sound bounces back at you, or if there is a car beside you.
I can live with it. It's just annoying sometimes.
I bet buying another set of heads, and installing those the sound would go away. Unless of course those heads have the same issue, lol
It sounds like this: http://youtu.be/MtfFQYgqJag
Old Aug 13, 2011 | 02:53 PM
terrasmak's Avatar
Exhaust leak, gives you a tick when you drive next to a barrier.
Old Aug 13, 2011 | 03:21 PM
mezer's Avatar
mezer
Sounds just like an exhaust leak driving next to a barrier. But it's not an exhaust leak. Stethoscope says so.
Old Aug 13, 2011 | 07:32 PM
Classy's Avatar
Classy
look at his other thread... He has a full motor build with a turbo going on.
Old Aug 25, 2011 | 02:31 PM
sphynx88's Avatar
sphynx88
I believe I have the exact same noise. Only hear it when warm.. only hear it when windows down and driving next to car or concert barrier. Hear it more right when I increase revs...
thought it was exhaust related but ran a little bit of seafoam through and didn't see anything leaking. I dont hear it in my engine bay at all... seems like its in the front part of the car underneath?
Let me know if you find anything
Old Aug 29, 2011 | 11:10 AM
djamps's Avatar
djamps
Try replacing the fuel dampeners.
Obadabot
Jun 18, 2023 11:31 PM
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
